I've asked the question several times and have had some good suggestions however a solution hasn't been found and now I find that the "experts" that have engaged in responses have now seemingly ceased their discussion/suggestions. I have a MP730 printer, a TX1000 HP Pavillion laptop. A linksys wireless router hooked up to a desktop. At one time the laptop could print wirelessly to the printer. Now it isn't able too. It does however work obviously when it's wired to the printer. All the drivers have been reinstalled and the printer works fine. The only issue is the laptop no longer speaks wirelessly to the printer. I've tried all the suggestions repeatedly yet no go? I still need help. Anyone have any more great ideas? Thanks.
  • 1,555 Answers
It would have been easier for me if you would have told me the Operating systems on your PC and laptop. Anyways I'm asuming that your pc has windows xp 32 bit and your laptop has windows 7 64 bit. If this is the case then here's your solution
Try the following: install the printer on the 64 bit machine via USB, the reconnect to your XP machine. Now go to the Devices and Printers folder, right click on the MP 730, Printer properties, Ports, Add port, Local port, Create port and select \\XPcomputer\printer (where you supply the appropriate share name for the computer and printer), OK, OK
If this is not your OS then kindly let me know.
Posted on Jul 11, 2010
  • sc_ross Jul 16, 2010
    OS is Vista 32bit
  • Aruna Singh
    Aruna Singh Jul 16, 2010
    The solution will work with vista 32 bit also.
How do I change the water pump?
what vehicle is it? let me know then perhaps i can help,
May 14, 2017 | 1990 Nissan Pulsar
Coolant indicator light will not shut off even after adding coolant 2003 malibu
If the system is indeed full of coolant then the coolant sensor may be faulty or dirty. I've replaced several of these for this problem. If the coolant is dirty or hasn't been changed for some time then that will contribute to the sensor problem so it may be a good idea to flush the cooling system and install new/clean coolant at the same time to avoid future problems. Good luck, hope this helps!
Oct 07, 2011 | 2003 Chevrolet Malibu
I ordered 7 Superman Black Aztec tees from Goodguycomics on 8/27/2011. My transaction # is 98T34544482761673V. I have yet to receive a thing, and when I e-mail Goodguyscomics they fail to acknowledge my...
hi betty, since you haven't recieved your tees, & you've email them, then here's what I suggest
go to paypal & login to your account
& either use the help section to find the resolution center or
look under accounts & you'll see the word overview across to the right you'll see the resolution center, just click on the tab & start a dispute about items not recieved
I've had to do disputes several time & got results
good luck
Sep 11, 2011 | PayPal Accounts
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't...
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Jul 24, 2011 | Lexmark X4650 InkJet Printer
Hello there, I have a Nikon Coolpix L4, and I'm trying to use a 4GB memory card in it that was most recently used in a Canon digital camera. I'm getting the error that "this card cannot be...
Sorry to tell you, but your older camera will not work with 4GB or higher SDHC cards. Your camera was designed before SDHC format came out. You'll need to use 2GB or less standard SD cards. These are relatively inexpensive these days, and are easily found on Amazon, just in case your local store no longer carries them. For others reading, there are several other possible causes for memory card problems, with troubleshooting steps that may be viewed here.
Jul 09, 2011 | Nikon COOLPIX L4 Digital Camera
I've tried, in vain, every recommendation that has been suggested. I've emptied the toner bin, changed out the toner cartridges, bought a new USB cord and installed it in a different port,...
Hi
There might be a problem with the paper sensor. Check the rear portion of the printer where you get the paper out try to open the back of the printer and check if the sensor is working well. Usually it will be stuck and need to be released. And if you can just give a little bang on the back of the printer this may cause the sensor to trip and start working.
DO NOT FORGET TO RATE MY ANSWER
Jun 29, 2011 | Samsung CLP 300 Laser Printer
A couple of times I've found that the dishwasher tablet I'm using (Finish) hasn't dissolved correctly. I found it in the cutlery box the last time. I've been putting it on the 65 degree...
I am guessing you are using the Centigrade temperature scale ... which would be 149 degrees F. 149 is way hot in terms of regular house hold use. Probably just right for a dish washer.
I would expect most tablet detergent would disolve properly at this temperature and with proper water pressure in the machine. You should have plenty of both in this machine. May I suggest you give liquid dish washer detergent a try to see the results?
Jun 01, 2011 | Dishwashers
I have an lg viewty ku990 it won't turn on even when it's fully charged. The lg symbol briefly flashes
Hello . I`ve just posted a reply to a similar complaint here .I am no expert with new mobiles, and found that the man in the Vodafone shop got my Nokia 1661 going today by pressing the same red Power button that I had tried for an hour to wake the screen . Try asking any kid you see, they come hard wired it seems . I don`t know your model.Good luck .
Jun 14, 2010 | Cell Phones
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
