Question about SVP DV-12T Flash Media Camcorder
Can't take a pic, delete or anything
It says SD Protect. I have 3 discs and all are on unlock so this isn't the problem.
    Novelist:
    Champion:
  • 216 Answers
Greetings Cinmo7,
One solution some have suggested is to put a thin piece of scotch tape over the slide lock to "trick" the camera into thinking it is not locked. However, if three of your cards all are giving you this error, this leads me to believe you may have a problem with your actual camera, because the sensor that reads the cards is in your camera. You may want to have it looked at by a professional camera repair person.
Thank you,
Agent Dort
Go Ahead. Use Us.
Posted on Apr 17, 2008
  • 4,234 Answers
There is a small microswitch on the inside that should be closed when a disc is available for writing. This switch is defective. While a simple repair for an experienced tech, I would not recommend you open this up unless you are experienced. The switch will be a surface mounted part.
Dan
My olympus cam t-100 Showing d error of write protect, actually i was replace my card last nite from my cell to cam or i can also delete all pics from cam. how can i recover back same like before i do
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 27, 2012 | Olympus "T-100 - Digital camera - compact...
Memory card is write protected
You should be able to read the card whether its protected or not. In fact I always protect the card before putting it into my computer so as to prevent the computer from doing anything to the card.
Feb 26, 2012 | Nikon Coolpix S3000 Digital Camera
Genx usb flash 128 Mg is write protect how i can remove write protect
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 27, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Inserted 4 GB memory card. new camera trying to take a pic and I keep getting the message card protected.
Memory cards particularly SD or SDHC have an option to protect the files from accidentally deletion. This is done by moving the small part of the memory card to the 'lock or unlock' position. Try to look for this small switch on the side of your memory card.
Dec 26, 2010 | Vivitar ViviCam 35 Digital Camera
Can someone tell me what to do when my GE 5x optical zoom 14.1 megapixel A1455 digital camera will not let me take pics or anything. It keeps saying (Write Protect) whenever I try to take pics. Please...
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 27, 2010 | GE A1455 Digital Camera
My cique says sd card locked help I can't do anything w pics how do I know what I can delete of sd card? It was in my blackberry before thank you
take the sd card out and there is a small switch on it that says lock...slide it the other direction and it will be unlocked
Aug 08, 2010 | Motorola Mobility CLIQ Cell Phone
When i attempt to delete pics from the camera it says card locked, how do i unlock the card
if you use an sd card on this camera you have to remove it and see that aside it has a locking device ..like a slide with 2 positions...probably yours is on locked and this protect the content and do not let you delete ...also look in the menu cause it might have a protection also ....somewhere related with the memory ...but most probably ..is the lock prom the card itself...
Nov 01, 2009 | Polaroid I533P Digital Camera
Power Shot A630 says card locked, will not take or delete pics
There is a switch on the side of the SD card, slide to unlock position then go to the SETUP menu, format the card (before doing that, make sure you have saved all pictures from the SD card to your computer)
this post may help
http://www.fixya.com/support/t2167722-screen_saying_memory_card_protected
May 08, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Can't take a picture
Greetings Cinmo7,
There is a small tab on the side of your card that might have gotten into the locked position. This can prevent you from deleting your photos or taking pictures, much like punching out the cutout on a cassette. Take your card out of your camera and slide the tab to the unlocked position.
Thank you,
Agent Dort
Go Ahead. Use Us.
Apr 17, 2008 | SVP DV-12T Flash Media Camcorder
Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Nov 29, 2006 | Nikon Coolpix 5200 Digital Camera
SVP DV-12T Flash Media Camcorder Logo
42 people viewed this question
Top SVP Video Cameras Experts
Andrew Taylor
Andrew Taylor
Vladimir Frolov
Are you a SVP Video Camera Expert? Answer questions, earn points and help others
