Question about Freezers
I have a samsung RS21DCNS fridge freezer the fridge side is to warm approx 13 deg instead of usual 3 i have defrosted cooling fan as it was noisey but still no good
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
HELLO THIS VIDEO IS QUITE GOOD AND MAY HELP YOU .??..#">
Posted on Sep 15, 2010
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Samsung RSH1 power onto unit ok as lights working but no cooling in either fridge or freezer. This followed a power trip to the main electrics.
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Regards.
May 02, 2011 | Samsung Freezers
SAMSUNG FRIDGE FREEZER NOT COOLING. ICE BUILDING UP ON REAR PANEL, MODEL RS20CCMS,
Fan unit or defrost element has failed, usually the defrost element, not a hard DIY, just be very careful. Check fan is running first and that it is not part of the new icy growth inside the freezer, regardless, you will need to defrost this glacier first before you can do anything and PLEASE dont resort to a blow torch, there is plastic and pressure gas in there. Just be patient and watch the fins on the cooling unit, you could shave with that stuff. Good luck, any probs, call me on 08 9523 0552. Russ
Feb 27, 2011 | Samsung Freezers
I have a samsung cool n cool fridge freezer. The freezer has an electrical smell and certain items are are defrosting??? Temp. Has dropped a degree and is now at17 deg.
Sounds like the defrost heater under the freezer coils has burned
out.Remove back freezer panel and check heater with ohm meter
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Freezers
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
Whirlpool side by side fridge not cooling
Yes, only part that gets could is in the Freezer. If block by ice (usually) this will not allow the cold air to go into the ref., if so, defrost problem. Check amount of ice on coils in back of Freezer. Should only be a thin frosting.
May 02, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Side by side refrigerator is not cold. Bottom freezer is.
if the freezer is cold and the fridge is not then it can be several things. The freezer could have a bunrt out defrost heater, defrost timer faulty, fan not working in the freezer??. all of these things will stop your fridge getting cold, but your freezer will still be around minus 9 deg c. you wont get any air into the fridge as the coil in the freezer is prob all iced over. Dont worry about the heat on the door frame as it is only the anti sweat heater
May 01, 2009 | Maytag Freezers
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Samsung side by side American style fridge/freezer
make sure your fan is running in freezer section. you should hear it
Dec 02, 2007 | Freezers
Freezers Logo
315 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
