Question about Iomega 250GB Ego Portable HD Red 250 GB Hard Drive
How I can format muy new hard drive in Windows 7
  • 487 Answers
Hi, you should not need to format your new hard drive, they arrive ready to use. If you require the format just plug you device in, go to hard drives where there is an option to format or repair
Posted on Jul 04, 2010
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: New Hard Drive trying to
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Posted on Feb 18, 2011
Format hard disk C of netbook
Important: It is recommended to take a backup of all the necessary data you have on your C: drive before you format it. Formatting the drive will erase everything on it.
The steps to format hard drive can vary depending upon which version of Windows you are using. You can refer to the following links for instructions:
For Windows 8 / 8.1:
http://pcsupport.about.com/od/windows-8/fl/format-hard-drive-windows-8.htm
For Windows 7 / Vista:
http://windows.microsoft.com/en-in/windows/create-format-hard-disk-partition#create-format-hard-disk-partition=windows-7
GuruAid.com
Feb 26, 2015 | Computers & Internet
System formating
How to Format a Computer with Windows 7 Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out various programs that will ZERO out the drive.
To format your hard disk during Windows 7 installation, you'll need to start, or boot, your computer using the Windows 7 installation disc or USB flash drive.
  1. Turn on your computer so that Windows starts normally, insert the Windows 7 installation disc or USB flash drive, and then shut down your computer.
  2. Restart your computer.
  3. Press any key when prompted, and then follow the instructions that appear.
  4. On the Install Windows page, enter your language and other preferences, and then click Next.
  5. If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
On the Please read the license terms page, if you accept the license terms, click I accept the license terms, and then click Next.
On the Which type of installation do you want? page, click Custom.
On the Where do you want to install Windows? page, click Drive options (advanced).
Click the partition that you want to format and click Format.
If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the Delete option for each partition. Once you have deleted all of the partitions, select the Unallocated Space partition and click Format.
Pick the formatting option that you want.
When you've finished formatting, click Next.
Follow the instructions to finish installing Windows 7, which include naming your computer and setting up an initial user account.
If you do not want to reinstall Windows 7, you can cancel the installation at this point and keep your newly formatted drives.
This information has provided by, youc an also find instructions for other operating systems here: How to Format Computer
Jan 26, 2015 | Computers & Internet
Recovery of my r51
The O.S is corrupted and you want to format the HDD of your Laptop.before formatting backup your all data,so that you can easily format and install new O.S.
Laptop Hard Drive Recovery
Laptop Data Recovery Laptop Hard Drive Recovery
Feb 14, 2014 | Lenovo ThinkPad R51
Help how to format lenovo ideapad s300 in windows 7
If you want to format your entire hard drive (and reinstall windows) You'll need to insert the appropriate windows disk. If you want to reinstall 7, insert your windows 7 disk and boot off of the disk (When booting, it should start by showing a screen that says "Press any key to boot from CD..." and you can just press a key on your keyboard. From there, follow the on screen instuctions. When you get to the drive partitioning step, select your hard drive and partition you want to format. You can delete the partition you have and make a new one if you want to totally clean the computer (WARNING: This will literally delete everything on your computer. Everything). From there you continue and finish the setup (it may run for a while). And you have a fesh new hard drive and operating system install.
Sep 12, 2013 | Lenovo IdeaPad S300 Laptop Computer -...
I want to format my c drive with the help of Dos command prompt , installed win 7 ultimate.
Formatting hard drive When booting from a Windows installation CD select the option to install Windows then you (can either delete the existing partition/s then create a new partition then you) can format the hard disk. After formatting the hard disk you can abort the Windows installation if you do not want proceed to install Windows.
You should be able to use the Windows 7 installation CD to delete the existing partition, create a new partition and format the new partition and then install Windows 7.
Apr 03, 2013 | Computers & Internet
I just upgrade to Win 7. Now everytime when powering up the machine, there are two boot options like this: Previous Windows Operation System Windows 7 (with Windows 7 highlighted) Of course I...
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer.
When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
-G33k
Jun 11, 2011 | Microsoft Windows 7 Ultimate for PC
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
Want to comp re format hard drive and then install
well if u have windows 7 disc, then u can use that to boot the computer from the disc n then it will give u option to format the hard drive and install the new os.
u will have to boot the computer from the windows 7 bootable disc.
Nov 01, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
Open Questions:
Iomega 250GB Ego Portable HD Red 250 GB Hard Drive Logo
297 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
