Question about Husqvarna Designer I
Designer 1: upper thread shredding while embroidering
HI, I hope someone can help with this problem. I have had my machine about 1.5 years and in Dec started having trouble with it in the embroidery mode. The upper thread is being shredded until it breaks. I had the machine cleaned and serviced in Jan thinking that would help but the problem persists. I've re-threaded using every possible configuration, changed needles, changed types and brands of needles, changed stichplates, bobbin thread, speed... everything I can think of. I am using Sulky thread, it is new and the problem persists with any color I use. I do not have the problem when sewing, only embroidering.
Any help would be appreciated. Thanks.
  • Kathy1226 Jul 31, 2008
    I have a similar problem while embroidering. My Designer 1 keeps beeping that the thread is broken when it isn't and at times the thread starts to shred. I haven taken it into three different repair shops and none of them are competent. Unfortunately, they are the only ones around here. I've tried calling Husqvarna viking in Ohio and all they say is to box it up and ship it to them. I am not going to ship a $5,000.00 sewing machine anywhere. One repair place here said it is caused by the "check spring sensor" and needs replacing. I am so frustrated with this machine and would not buy another Husqvarna. I hear very good things about the Baby Lock Elegante so if you are thinking about a new machine - stay away from any Husqvarna Viking!
  • Susan Kotarski Apr 15, 2014
    I had the same problem. Switching to a #80 Ballpoint needle sloved the problem!
I too, have the same problem withmy Designer 1. I just bought ISACORD brand polyester embroidery thread to hopefully solve this problem, but I believe it must be a tension problem. I have a "date" with the repair lady on Friday (11/22/08) and if it gets repaired I will re-post what the problem was. Still love the machine WHEN IT SEWS!!
Posted on Nov 16, 2008
    I switched to a #80 ballpoint needle, problem solved.
My brother pe770 jamming up and i get this error msg that says check and rethread upper thread
I find that most problems for me have been from poorly wound bobbins or very dense designs. With the dense design, when nearing the end the hoop starts catching/jumping up with the needle, breaking thread. I use software to decrease density one or two increments then embroider. Clean out the bobbin shuttle and the upper thread path. Change needle & make sure your stabilizer is appropriate for the fabric. If too lightweight it tends to shred causing issues.
Sep 05, 2014 | Sewing Machines
The thread on my ellisimo gold keeps shredding
try changing the needle
and also check for burrs on the needle plate and in the bobbin
area
Jan 14, 2013 | Sewing Machines
Brother pe770 bobbin thread is showing on top of fabric.
First check threading. If it is done properly, then it's probably because it is dirty between the lower tension blade and the bobbin case body. Remove this blade, clean, reassemble and it shoud work.
Dec 26, 2011 | Brother PE770 Computerized Sewing Machine
I have a designer 1. recently when i go to embroider, it starts fine then just goes hay wire and put teh embroider all over the place- not like the pattern. Sound to me like the emb. unit? thanks kathy
Hi Kathy, I'm sorry your Designer 1 is not feeling well.8*( It sounds like to me you need to get your embroidery unit re-calibrated by your local technician. When was the last time you had your machine serviced? Are the designs you are trying to embroider stock designs or your own designs? Have you tried resetting your machine by turning it off and back on again and let the machine calibrate again? (Take the hoop off before you do this and put it back on after you have selected your design) and try it again. Also how old is your machine? They had a recall on Des 1 purchased between 1999-2004 for a power supply problem. The serial # and recall info is on the Viking website at- www.husqvarnaviking.com. Also do you have enough clearance around your machine where the hoop is not hitting anything while it's embroidering that will throw it of big time! Hope something here helps you! If I can help you further you can also email me at- kats2sew@hotmail.com Happy Sewing!! Kathy ( from 1 Kathy to another)
Nov 02, 2010 | Husqvarna Designer I
Can not adjust the upper thread tension tight
If you are adjusting the upper tension on your machine and yet there is no difference to the sewing, it seems to me that maybe your upper thread is not in the tension disks correctly. Re-thread taking care to make sure the threads bed down into the tension disks. I pull off about 2 foot of thread from the spool and put my right-hand finger on the thread very close to the spool (the idea is to hold it down so it doesn't move) then use my left hand to take the thread through the thread run. Once I get close to the needle, I tug the thread a little and you can hear/feel it go into the tension disk.
Sometimes it looks like the top thread is the problem, but in fact it is the bobbin which is at fault. Re-insert your bobbin again taking care to click it into its tension slot. If you are still getting bad results, try loosening off the bobbin tension. Use a tiny screwdriver to turn the tension screw (the one just on the outside of the tension slot). Turn it no more than 1/5th of a circle at a time (to the right to tighten, to the left to loosen) then put bobbin back in and test. You should not need to adjust it more than two or at most three times. If you do, something is seriously wrong with your machine's tensions and it needs to see the Sewing Machine Doctor.
May 25, 2010 | Husqvarna Designer I
Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
May 21, 2009 | Husqvarna Designer I
Tension on upper thread?
It sounds like the machine needs to be timed, seek out a sewing machine repair shop for this service.
Jun 07, 2017 | Baby Lock Ellure
Sewing Machines Logo
490 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
