Question about Samsung Televison & Video
Blueish tint on Samsung Plasma TV PS42Q7HX/RAD
We get a blueish tint on Samsung Plasma TV PS42Q7HX/RAD. The TV is approx. 4 years old and this does not appear all the time but recently it has been occuring more often. It does not seem to appear the same place and moves around the screen.
5 Suggested Answers
SOURCE: my tv is hitachi 55pd plasma
Hitachi did in fact stand behind their product and resolved the problem. My hats off to them! Panel was replaced due to faulty ribbon cable supplying signal from one of the drivers. Unfortunately for my specific issue there wasno other solution as the ribbon cable in sealed inside the glass panel.
Posted on Jan 17, 2008
SOURCE: Blue screen
Are you using component video cables? If so, check that these aren't loose on either end. Next I'd consider that whatever video cable/input might be bad, and switch cable or cable type... i.e. switch from component to HDMI or vice-versa. Then change up the source (cable box versus DVD player). If you're still seeing blue at this point, the TV internals are the bad.
Posted on Aug 19, 2008
SOURCE: plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Posted on Aug 21, 2008
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
Mits. rear projection tv ws65905 picture has blue color tint
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Jun 01, 2015 | Mitsubishi WS-65905 65" Rear Projection...
I have a 4 year old Toshiba-56HM195 with blueish haze.I have place the engine light 3 rme in 3 year bulb 3 time in 3 year it's been a year seen I dn it which one is going out .
Yuor covergence board is bad and you need to have a tech replace the convergence IC's on the board and bad electrolytic caps, or buy a new one at www.partstore.com
Nov 26, 2011 | Toshiba TW56X81 56" Rear Projection...
Moved tv across town and tv now has a blueish tint on left side of tv. bulb was changed and problem still there?
This is a issue with your optical eng. Sony knows that they are bad, call sony and they should atleast comp you the part
Dec 17, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My whole screen has a blueish green tint
  • Make sure the plugs are hard into the sockets, one loose pin can cause strange colour problems.
  • A faulty signal cable between PC and monitor can also cause colour problems, try a different cable if possible
  • Try it on a different computer to find out whether the computer or the monitor is the problem. If it's the monitor and none of the above works, it will need service or replacement. If it's the computer, your video card is likely to be the problem.
Apr 09, 2010 | Samsung Syncmaster 940BW LCD Monitor
I am experiencing a blueish tint towards the left side of the screen on my Sony Wega. Is there a solution for this? We moved the TV briefly to connect a DVD player, and when we reset the TV on the stand,...
Projectors with three LCD circuit boards can overheat over time and damage one of the color panels (circuits). This happened to my Epson. It costs too much to replace the panel, which means the projector is terminal. This bleeding color may start small and get worse over time. I hope that this is not the probelm that you have...
Jul 18, 2009 | Sony Televison & Video
Bluish tint that starts in lower left corner and goes across scre
i have blueish on right lower corner of screen.... what causes this
Mar 05, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Monitor is blueish
If the Blueish problem appears try play around with the VGA cord and see if the Colors comes back, if not, try hiting the monitor to see if the lines and color problem comes bcak to normal. If not your monitor's circuit board needs some dry solder, it could be the cold solder problem. Cheers.
Jan 21, 2009 | LG Studioworks 700S 17" CRT Monitor
Blue screen
Jul 23, 2008 | Panasonic TH-50PX75U Plasma HDTV
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
Televison & Video Logo
155 people viewed this question
Jerry Greenberg
Jerry Greenberg
