I have a maxell memory stick 2mb and it keeps on telling me that the lock is on, this stick doesnot have a switch to turn it off it will not leave me delete anything off the stick can anybody help
    Scholar:
  • 50 Answers
Check the properties on the individual file. are u trying to delete Propritory files on the Maxwell ? or your own files.
Right click on the file, then choose properties, see if its read-only. Also, check the security tab to see what permissions ur user name has. edit modify accordingly.
this may help.
djEnigma
Posted on Apr 17, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
H0W DO I REMOVE WRITE PROTECTION FROM A MAXELL MEMORY STICK
1. Open Start -> Run...
2. type diskmgmt.msc and press enter
3. right click on the partitin you want to format (where the leter and size is)
4. select 'Delete Partition...' and confirm
5. right mose button in the same place and select 'Create partition'
6. select primary partition
6. select size, file forma, disk leter, label etc should be all right if you leave defaults.
7. click ok
Dec 20, 2012 | Electronics - Others
My sony cybershot 3.2pixel camera tells me that the memory stick is locked What can I do to fix it.
The lock switch is located on the bottom of the Memory Stick, next to the connectors (see picture below). Move the switch to the other end of the arrow to unlock the Memory Stick.
Sep 16, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
I am using window 7 enterprise my computer can recognize the sony memory stick pro duo adapter with 1 GB card but cannot open it neither can format it. please tell me any solution.
check the small lock switch on the adapter usually located on the edge of the adapter. check and see if in lock or open position. if its in lock position toggle the switch to open position and you should be able to read as well as write date to and fro from the sony memory stick pro duo adapter. good luck
Sep 08, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Please can you tell me how to operate a Maxell or any memory stick?
You put the memory stick on your usb at the pc and you can find a new partition on my computer . After this you can copy files on it or do anything you want !
Mar 24, 2011 | Maxell 4 GB USB 360 USB 304 - 503201 Hard...
Can't write onto my card through adapter, only works through the phone. "write protected" keeps coming up. No lock on adapter.
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
>>>>DOWNLOAD FORMATTER CLICK HERE <<<<
Jul 14, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Maxell (messenger) 8GB USB memory stick inaccessible
sorry do not beleve that you can save that part if you can copy what is left try to than format it then reinstall on it jim
Mar 26, 2010 | Computers & Internet
Maxell 8gb stick now has Raw file system?
Hi
No unfortunatley this drive has been corrupted and will need to be replaced
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Electronics - Others
Mp3 not playing on samsung m110 solid
this phone has only 2mb memory so its very difficult to get a mp3 of very less size thats in kb . this phone doesnot support expandable memory so it is difficult to play mp3 songs
Jun 13, 2008 | Cell Phones
Yes i bought a memory card 2MB for my LG CU500v & when I insert the card into my micro sd slot on the back of my phone & turn it back on it says that the card is not ready. what am i doing wrong?
simply turn off the phone before inserting it then turn it back on again.
But let me inform you that your phone memory supports up to just 1GB(hope you are not mistaking 2GB for 2MB: there is no 2MB memory in the system)
just purchase a micro SD card of up to just 1GB (nothing more)
and also make sure it is working before you leave the shop.
good luck.
May 12, 2008 | Lands Phones
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
