Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
How do I replace the primer bulb on my lawnboy silver series self propelled mower? I purchased one but cannot seem to figure out how to replace it.
    Problem Solver:
  • 6 Answers
You must remove the engine cover (three torx screws) then you can pull the line off the plastic bulb disk and remove it from the cover by pushing the side clips.
Put silicone on the bulb disk and force the bulb on to the disk. I had to use a vice to hold the disk, it is a very tight fit. When you get the bulb on the disk, reinstall it in the engine cover and reattach the hoses. The gas tank hose will probably need to be pushed on to the carberator and the gas tank also. This is hard work but is the only way you can instal the bulb.
Posted on Sep 20, 2010
I need to download an owners manual 10323 lawnboy mower
Hi Nancy,
here is a link to a page that should help. It looks like you may have to purchase the download:
https://lookup3.toro.com/request/sendreq.cfm
Good Luck!
Jim
May 25, 2016 | Garden
My lawnboy silver series is not getting any spark
If you are getting no fire it is going to either be your coil is grounding out through the kill wire somewhere or your coil has gone bad. Try unhooking your kill / ground wire directly from the coil then check for fire. If you still have no fire then you will need to replace the coil. Hope this helps.
Aug 26, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Lawnboy silver series is not etting y spr
ask qustion again be specific is rear drive not working let me no
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Why isn't the carborator not getting gas?
if mower has been sitting the jets could be clogged up or float my be stuck. if mower is used often there may be a hole or rip in primer bulb
Apr 18, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
LawnBoy Silver Series 6.5hp (manual start) self-propelled. Spark Plug does not have spark. Took plug out, clamped brake bar and held plug on engine for ground in plug boot. What can I do to get spark back?...
Disconnect small wire at ignition module. Then check for spark. If no spark, replace ignition module. If there is spark, then there is a short in the kill wire or engine control cable is not adjusted correctly.
Aug 19, 2009 | Garden
Rerunning the belt on an o6 self-propelled Lawnboy
You may have to loosen the adjustment a bit to let the transmission tilt farther forward. Do not loosen the other nut on the adjustment, that way you will know how far to re-tighten the one you loosened when you have the belt on.
Apr 12, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
2,770 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
