Question about Fisher and Paykel Dishwashers
Single unit drawer is locked and power while switched on at outlet does not illuminate indicator
    President:
  • 1,891 Answers
Need to know brand & model # t help . but sometime's if you turn power off at fuse panel . for 15 min it will reboot prosser and this may correct problem . hope this helps mm
Posted on Jul 04, 2010
I lost the fuse diagram for my dads 95 dodge grand caravan. Can anyone help me out with one?
#1: Panel Illumination
#2: Guages,Right High beam headlight and the high beam indicator
#3: Rear Wiper, Left headlight High Beam
#4: RH park, backup lights switch and relay,Speed porpotional steering module,power door lock switch illumination and daytime running lights(Canada)
#5: Power Door locks,Power Mirrors,vanity,dome,map,ignition and trunk lights,sunroof,radio,power antenna,body control module and power for the data link connector
#6:Heated mirrors,heated rear window indicator
#7: Instrument cluster illumination,park and tail lights
#8: Cigarette lighter,Radio Amp and horns
#9: Power door lock motors
#10: Not used
#11: Radio
#12:Left low beam head light
#13,14,15,16 not used
Apr 05, 2016 | Dodge Cars & Trucks
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Jan 20, 2016 | GE Refrigerators
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Fischer and paykel drawer dishwasher has no power to drawer, power at outlet, was flashing F1 prior to shutting down, thanks
If you have a double drawer unit then please confirm what is happening with the other drawer. Most likely the base of the dishwasher under the bottom drawer has flooded and brought down the power with it. The power board sits under the bottom drawer. BE CAREFUL NOT TO TOUCH THE DISHWASHER BEFORE SWITCHING OFF THE MAINS POWER SUPPLY TO THE DISHWASHER AS THE CIRCUIT MAY BE LIVE AND GIVE A SHOCK. You will have to take the bottom drawer out and see what is happening under it.
Jan 16, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dish draw **** up with a service code f 1 , what does this mean
This can mean several things. If you have double drawer dishwasher then you need to confirm if you get the F1 message in both drawers or just one.
If both drawers then it is caused by water leakage and flood switch activiates. If only in one drawer then the power supply to the other drawer is blown.
For single unit drawer it means flood switch triggered.
Dec 26, 2012 | Fisher and Paykel 24 in. DS-603 Built-in...
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Shredded a few sheets of paper. clicked off. Have power at outlet. No damage to cord or connections. No auto reset of internal overload protection, amount of paper shredded far too few to trip...
Hi, make sure the cutters are not jammed with paper. To reset turn the unit to reverse for 2 seconds then auto then off. Allow to cool for 25 minutes then retry. Also make sure the base is locked in properly. Hope this helps, regards Phil.
Jul 08, 2011 | Fellowes Office Equipment & Supplies
MY DISHWASHER IS LOCKED. IT PEEPS BUT IT DOES NOT OPEN
Please provide the model number of your dishwasher. If it is the double drawer unit which one is having the problem. If it is a single drawer unit then is there anything on the display.
Most likely the filter pcb at the base is faulty. This provides power to the actuator motor that controls the lid seal lock. You can pull open the drawer - with slight force. There is no way you can diagnose the problem without opening the drawer. Turn the mains power off first.
Nov 28, 2010 | Fisher and Paykel Dishwashers
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Dec 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
12 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
