Question about Samsung ML-2240 Laser Printer
Hi have samsung ml 2240 printer top light is flashing green orange and red and the bottom light is flashing red have changed the toner cartridge but printer still not working
Its of Paper count problem. tourn of printer power and open the back cover and find the IC 366...... ita a small 8 pin ic just short Pin NO 1 And 4 just restart the printer ur problem has been resolaved
Posted on Jul 28, 2010
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
Refilled my starter cartridge ML-2240 and put in new reset fuse
Did you change the chip? These cartridge have a chip that tells the printer it has received it's new toner. You can get the chips cheap from a variety of sources online. Just search for samsung 2240 reset chip.
Good Luck
Feb 24, 2010 | Samsung ML-2240 Laser Printer
Iam using samsung mlt-2240 printer after refill the toner it was no working red light blinking in the printer.
You have to reset your printer. I think You have refilled the toner cartridges.
www.nakshatraworld.com
Jan 02, 2010 | Samsung ML-2240 Laser Printer
Red status light flashing, but none of the toner colours are lit
It means you have to reset your printer
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 16, 2009 | Samsung CLP 300 Laser Printer
Flashing Red & Green lights - Samsung ML 2510
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Oct 09, 2009 | Samsung ML 2010 Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
Tonner exhasted and cartriges does not supportes
yes you change your printer cartridge . Your printer toner chip is disable. You buy a new toner
Jul 20, 2009 | Samsung ML-2240 Laser Printer
The red light is flashing and I can't resolve it. The printer is still functional, but I noticed that the paper is coming out very very hot.
go to samsung website and see if they have smartpanel for this printer,download to pc and run,will solve your problem
Jun 23, 2009 | Samsung ML-2851ND Laser Printer
I have a samsung ml 2851 nd that won't print, and says the toner cartridge is low - I replaced with cartridge 209 (which office max said would work) and it still flashes the red light and says there is...
The counter needs to be reset most likely. I can\t locate a reset code & steps for you. Try calling samsung and ask about the toner reset you replaced the cartridge and its still showing the count from the old cartridge.
Apr 23, 2009 | Samsung ML-2851ND Laser Printer
Samsung ML-2240 Laser Printer Logo
2,650 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
