Question about Cycling
I cant tell wether or not my bike speedometer is at the right speed or not
  • 53 Answers
Posted on Jul 04, 2010
Speedometer, turn signals and horn quit working, speedometer light doesn't work
Hi, Brian I do not know what type of bike you have but this is what I tell all my Harley friends with electronic speedometers the vast majority of speedometer issues is caused by the speed sensor and or the wiring, a faulty speedometer sensor and or connection will automatically interrupt proper turn signal and flasher operation. On Sportsters the sensor is located on top of the engine case behind the rear cylinder, on big twins, it's located on the right side of the transmission case between the starter end cap and the transmission top cover. Remove the bolt/***** that secures the sensor and lift the sensor out of the case. Inspect it for damage and contamination, if there appears to be no damage wipe the end of the sensor clean and reinstall, you can go for a short quick test ride to see if the speedo is working. If the issue still exists grab your test light and unplug the harness connector from the sensor, check for power (red wire) and ground (black wire) continuity coming from the speedo, there is also the connector that plugs into the speedometer, also, look for corroded, broken or loose pin/sockets. If everything checks out OK then replace the speed sensor. Good luck and have a nice day
Mar 28, 2016 | Motorcycles
How do I Fix my speedometer on my 06 Heritage Classic, it jumps all over the place. When you disconnect the battery it will go back to zero. When you hook the battery back up to the motorcycle and turn the...
Hi Anonymous, always check your instrument fuse before performing the next procedure, try cleaning your speed sensor located on top of the transmissions right side between the top cover and the chrome starter end cap on Twin Cams and on top of the engine case between the rear cylinder and the starter motor for Sportsters. Remove the the bolt that secures the sensor and pull it out of the transmission. Inspect sensor for obvious damage and repace if necessary. If sensor has no damage then wipe clean any obvious contamination like micro fiberous material with a clean rag and reinstall, torque bolt to 8 ft lbs.
Apr 14, 2013 | 2006 Harley Davidson FLSTCI Heritage...
First harley, speedometer quit working it lights up show everything but speed . where doz it go to fron meter?
The speedometer sensor is on the transmission. It's exact location depends on the model of your bike. Look on the top on the right hand side of the transmission.
Good Luck
Steve
Apr 27, 2011 | Harley Davidson XL 1200 C Sportster Custom...
My friends 2009 Honda CBR 1000 shows about 8mph less than my 2010 Yamaha Majesty. Are there know issues with the Majesty? Could there be something wrong with my bike's speedometer? I just bought it 2...
Sometimes there is some variance between identical new motorcycles. I had friend claim that his BMW speedometer was accurate and my Honda was off by 5 mph. We had the same brand(Dunlop) and size of tire. I changed my tire, same brand(Dunlop), same size, different "style" and now both speedometers read the same speed . This tire was the same number size but mounted stood taller than the old tire. What my friend failed to realize was that his cycle came stock with a Metzeler so he was not reading accurately either. So do not dismay, your friend may not have the correct height tire on his bike. You will have to make some speed runs past on of those signs that tell you how fast you are going and see how accurate your machine is. My 2009 Suzuki DR200 reads 2 MPH slow by the police speed signs.
Sep 11, 2010 | Yamaha YZ 450 F Motorcycles
Our Yamaxa XS1B's speedometer has been revised by an
I can't give you reliable instruction on opening it up. Have you thought about asking your Bologna speedometer man for suggestions? How about contacting Yamaha or the manufacturer of the speedometer if it is not Yamaha who makes it.? As i said, the best I can tell you is to be careful when you disassemble it. Any chance the speedometer could be replaced with a newer Yamaha speedometer that has a Km/h dial? Your original posting is still on FixYa. You might want to re-post to get the issue back on the front page. Just copy original posting then paste it into the new posting.
Jan 16, 2010 | 1971 Yamaha XS1B
Speedometer stopped working on 2001 Victory Motorcycle
THE SPEED SENSOR IS LOCATED AT THE RIGHT SIDE OF THE ENGINE ABOVE THE DRIVE BELT. I HAD THE SAME PROBLEM REPLACING THE SENSOR SOLVED THE PROBLEM.
Apr 16, 2009 | 2001 Victory V 92 C Deluxe
Speedometer not working properly 2003 v-max
Easily checked. Get a friend to drive at an indicated speed in a car or another bike. Good reference point. If the speedo is driven by a cable remove at both ends and inspect for frayed wires on the inner cable. Just slide it out of the outer housing.
Mar 19, 2009 | 2003 Yamaha V-Max
Cycling Logo
21 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
