How can I scan a document then print it with larger print?
  • Jack Woolfe Jul 05, 2010
    I have documents in my computer that I need to print out with larger text. Please tell me how I can increase the size of the print?
    My printer is Canon PIXMA MP270.
    Regards Jack
  • 6,993 Answers
Scanning a document for printing can be very confusing. I hope that I can help shed light on this process to ensure that all of your documents will print out correctly from now on.
You can follow the below steps. Lets assume you are using a flatbed scanner and your document is one page.
  • Figure out the print quality you need. For example, if you are printing on a home laser printer, your print quality is probably about 75 LPI (lines per inch). If you are scanning a document for a professional press, your print quality can be up to 150 LPI. If you cannot find this number, don't worry. Move on to the next step and we will solve this problem later.
  • Open your scanning software on the computer connected to your scanner.
  • Place your document on your scanner per scanner instructions.
  • Looking at your computer screen where you opened your scanning software. There should be a preview button. Click on it and it should scan in a preview image of your document.
  • Select the edges of your document in the preview.
  • In scanning options leave all brightness/contrast options alone. This should be done through a photo editing program. If you do not have one, at least scan the document in once to see how it turns out before messing with these options. If your document is black and white, select black and white. This keeps your file smaller and it also makes sure that your document will actually print black and white.If there is a 'scan to size' option, choose the size of your document. This ensures that if it scans in a little too large or small it will automatically adjust to the size you need. If you are wanting to resize the image drastically then see Step 7.
  • Using the print quality obtained in the first step, double the LPI number to get the DPI amount you need to scan to. For example, the laser printer I referred to earlier had a LPI value of 75, which means you will be scanning at 150 DPI. If you could not find this amount, or if you are using an inkjet, then scan at 300 DPI.
    You may be thinking, "My scanner has the capabilities of scanning at 1400 DPI. Why don't I just do that instead of trying to figure out what I should be scanning at. Plus, that would mean better quality anyway."
    Well, actually it won't mean better quality because we are scanning at the highest quality your printer can print. In addition to this, it would create a HUGE file. You would be waiting for your printer to print for a LONG time, which could also result in freezing your computer (or the print shops computer, depending on where you're getting your document printed).
    The reason your printer has those options in the settings is because DPI is based on the dots per inch at a particular image size. If you wanted to make a 300 DPI 16x24 poster of a 4x6 image, then you would actually have to scan the image at 1200 DPI to maintain the image quality.
  • After you finish with your settings, select scan.
  • SAVE!
Good luck.
Posted on Jul 05, 2010
    Wallsorumi
    You misunderstand the question.
    I have the scanned document in my computer, I need to print them out with larger text.
    Can you tell me how I can increase the size of the print?
    They ar save as JPEG
  • 4,737 Answers
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Posted on Jul 04, 2010
  • 2 more comments
  • Jack Woolfe Jul 04, 2010
    Nonontech
    I put the question wrong .I have a scanner, I know to use it.
    The question is, having scanned a document and it's in my computer. How can I print it with larger print?
  • Lebanon Raingam
    Lebanon Raingam Jul 04, 2010
    Could you please let me know what photo editing programs can you use? like photoshop, corel draw, etc.., You can change the print size using default Paint program in the windows desktop, but it's better to change the resolution using photoshop or corel draw (corel draw is better..). Just let me know any photo editing program that, i'll assist you step by step..
    Thanks.
    I don't know what photo editing program I have, How do I find out?
    I have documents in my computer, I want to print them with lager text.
    Regards Jack
  • Lebanon Raingam
    Lebanon Raingam Jul 05, 2010
    So you mean your scanned documents saved on your computer is in text format? like ms-word etc? I am confused, i thought you were talking about scanned photos, I am sorry for my mis-assumption, anyway let me try to assist you again. If it's saved in microsoft word format, just increase the font size, that'll do the trick or it you've saved them in the Pdf format, you'll need to convert them to microsoft word format so that you can edit them. If it's in jpg/jpeg format, you need to edit using photo editor, by default, windows has a built-in photo editing application called "Paint" but it's not so handy since no enough tools to morph, clean image file.
    I don't know in which format you saved the scanned documents. If you can let me know, i will be able to help you further, else i'll opt out. I don't want to spend much time on this.
    Thanks.
What to do to make the print larger on my printer?
You need to make the printer larger IN THE DOCUMENT before you send it to the printer.
That process will vary, depending on the type of document you are printing.
Mar 17, 2015 | Office Equipment & Supplies
Make font larger on HP1510 printer
What font are you referring to? Have you prepared a document in a word processing program, or added text to an image file, and are disappointed because you want to see the text printed larger? If so, your best solution is to edit the document or image and change to a larger text size. For example, most text documents will normally default to either a size 10 or 11 text which is readable but small. Changing to size 12 or 14 will make the text look larger onscreen, and the text will also print larger. The font name and font size should be displayed on one of your processing program's toolbars, and is easily changed to a different font name or size. If you are simply copying an already printed document and want the text to appear larger, you should refer to your printer's User Guide. If you don't have the User Guide, you can download a free copy at this link:
HP PSC 1510 All in One Printer User guides
Nov 15, 2014 | HP PSC 1510 All-In-One InkJet Printer
Want to make print larger
You'll need to make the print larger in your document, Alvin - on the computer, not at the printer.
Aug 23, 2014 | Office Equipment & Supplies
Scanned document is 8.5 x 14 even though setting says 8.5 x 11
You probably have the PDF programme page size settings incorrectly set to the larger size = why only able to print some of the length. As a solution, use a photo programme (Photoshop, Elements or the excellent FREE Faststone Image Viewer to resize the image so it will then print on your paper but so doing will reduce, slightly, the width to suit the revised shorter length to preserve the proportions/balance between length and width.
Apr 01, 2014 | Epson WorkForce WF-2530
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
I would like to know please how to make the font bigger. I have gone to 'Length' but cannot confirm the size I need, thank you
To print a document with a larger font. For example, if it is a Word document open the document and click on Format - Font then change the font size to a larger size. Then Save the document and then print your document.
Mar 31, 2011 | Office Equipment & Supplies
When printing a duplex booklet, the printout is reduced in size with larger margins than in original document. How can I get it to print regular size?
It happens when the documents is on A4 size and the printer is set to print on letter size (which is smaller in size). Hence the printer automatically resizes the prints which result in larger margins and print as compared to the actual document.
Therefore, when you print the documents (Press Ctrl+P) you have to select the paper (A4) from the print properties.
Hope it helps! Good Luck!
CreativeTECH
Mar 02, 2011 | Brother MFC-9840CDW Laser Printer
Hp laserjet 3055 scans larger than print area
When you place a document for scan, you must select the portion you want to be scanned.
You must also set the resolution which is set to 300 by default, if you want a actual size then set the resolution to 75, which is 3% larger then actual image.
It will reduce size in KB or MB of your image and it will be exact size.
Similarly, when you want to print, you must select option "Exact Fit" and print your document.
Everything will be normal.
Cheers
Nov 06, 2009 | HP LaserJet 3055 All-In-One Printer
Want to scan to pdf a document larger than one auto-feed tray
I'm just thinking off the top of my head but there is an option in copying called 'job build' in special functions. This enables you to add many document sets into one print job. This may also work for scanning although i can't remember trying. Try it.
Feb 16, 2009 | Canon IMAGERUNNER 6570 Copier
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
