Question about Car Audio & Video
Barracuda car alarm is in valet mode..how to deactivate it
5 Suggested Answers
SOURCE: viper auto alarm stuck in valet mode
Doctor C,
I to have suffered the trial and tribulations of the viper car alarm experience and am happy to pass on my knowledge.  I found this answer online after googling "viper valet mode"
"The LED is solid now, correct? This means the unit is in Valet mode. To get out of it, turn the key to the "on" position then back off, and just press your black program button hidden under the dash.  The installer should have shown you where they installed the black program button."
Good luck
Scott
Good Luck
Posted on Oct 19, 2007
c renner
  • 43 Answers
SOURCE: AUDIOVOX CAR ALARM
Try looking under your dash for the alarm brain. You should see a red wire with a fuse inline in all likelihood - remove that fuse and try to start it.
Posted on Feb 24, 2008
insanegtp
  • 112 Answers
SOURCE: Car Alarm
Key on, push the button, if that doesn't work, please post with model #, you can find that by looking under dash and finding system...
Posted on Jan 24, 2009
SOURCE: uniden vs1100xr car alarm will
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Posted on Apr 18, 2009
How to reprogram excalibur omega147 remote
Try this :
Programming the Transmitter
To program a transmitter, turn on the car's ignition and then press the valet switch five times to initiate programming mode. With this step there is typically a brief siren sound accompanied with a red indicator light. Press the transmitter button to shuffle between different modes and functions. To change a particular feature, use the disarm/unlock button or the arm/lock button. Pressing the disarm/unlock button turns the selected feature off, while pressing the arm/lock button turns it on. The action comes with either one or two chirps - one for a confirmation and two for a deactivation.
To switch from one security feature to the next, press and release the valet switch number until it corresponds with the identified feature. For instance, tap the valet switch three times to access the third listed feature. The switch chirps and the indicator light flashes the same number of times as the selected feature (in this example, three times).
Some of the programmable features include setting the type of light output (steady or flashing), alarm cycle, and bypass function. To exit from the programming mode, turn on the ignition and wait 10 seconds. The Excalibur alarm system automatically switches off after 10 seconds of inactivity.
Most Excalibur alarm systems come with a controller that allows for easy remote use within a specific range (decided by the particular model). To lock the door of the car, press and release the arm/lock button. Pressing and holding the lock button activates the remote panic option with systems that offer this feature. To release or deactivate any of the security features, hold the unlock button to deactivate remote panic and unlock the doors or press and release to simply deactivate the doors.
or this :
http://www.carid.com/images/omega-security/security-systems/pdf/rs350edpb-operation-guide.pdf
Jun 23, 2016 | Vehicle Parts & Accessories
How can I deactivate the alarm on my car short term? Is there a fuse I can take out to make the alarm stop altogether?
If the alarm is factory wired, you may not be able to because it may set off the immobilizer and kill the ignition system. If it's after market then you need to either read the paperwork that came with it and learn how to go into valet mode or you need to contact the manufacturer of the alarm system and ask them. But they'll want to know model and serial number.
Nov 01, 2013 | 2008 Nissan Sentra
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
When car battery replaced - car alarm no longer chirps when armed. However the remote does lock and unlock doors.
Sounds like your alarm is now in valet mode. Consult your alarm user's manual on how to remove it from valet mode.
Jun 29, 2011 | Hyundai XG350 Cars & Trucks
I reeplaced the fuel pump, fuel filter, and fuel pressure regulator. thinking that was the problem! But was told that the alarm might be the problem so i pressed the alarm twic and the truck started but...
You must put the alarm on a valet mode to see if the alarm is causing this problem
To enter or exit Valet Mode
1. Turn the ignition on
2. Turn the ignition off
3. Press and release the valet switch within 10 seconds
The status Led will light solidly if you are entering valet mode, and it will go out if you are exiting valet mode.
To enter or exit Valet Mode using the transmitter:
1. Open any vehicle door.
2. Press and realese lock and unlock buttons at the same time
3. Press and realese Aux button
4. Press and realese the lock and unlock button at the same time again
The status led will light solidly if you are entering Valet Mode and it will go out if you are exiting Valet Mode
Now when in Valet Mode try to start the engine, if the problem persist the alarm has nothing to do with it
Jan 11, 2011 | 350 HV ESP Security System 350HV ESP
I have a 1997 honda accord with an aftermarket audiovox car alarm installed. I want to disable the alarm or at least disable the kill switch. The key fob is going bad, I do not have a manual. It is not...
Look for some sort of toggle switch associated with the alarm system. (something small similar to this [http://www.mouser.com/images/ckcomponents/lrg/7000_toggle_series_new_SPL.jpg]) They call this a valet switch and it's located somewhere hidden and out of the way - usually under the dash - but still in an accessible spot. This basically disables the alarm. Typically, you'd turn the key on (but engine off) then flip the switch. This will put the car into valet mode and basically disable it. There is also usually some sort of LED light associated with the system - again typically blinking when the system is armed - but it will be solid once in valet mode. The clicking you are hearing is the relay that is triggering things. I'm assuming someone got tired of the alarm sounding and got rid of the siren it or clipped the wires to it - hence why your only hearing the clicking and seeing the light flash.
Mar 21, 2017 | Car APS95BT2 2-Button Code Learning...
Alarm sounds when unlocking my 1995 ford mondeo
make sure it is not in valet mode ,check batteries in remote from 7to 10 feet
Apr 04, 2009 | 1995 Ford Escort
I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Feb 03, 2009 | Viper Security and Remote Start System...
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
This procedure is:-
Sep 28, 2008 | Car Audio & Video
Viper auto alarm stuck in valet mode
u can open the drivers door if u have a 2 key remote just press lock aux lock again pretty fast and u should be great.
Oct 15, 2007 | Viper RCVGC022 Remote Control
Car Audio & Video Logo
336 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
