Question about Vtech Cordless 6041 Phone
Battery not Charging
It appears that the charger is not working as the charging light is not flashing.THE HAND SET DOES NOT CONNECT WITH THE BASE UNIT.
    Sergeant:
  • 129 Answers
Hi :) about battery mayb just a little pro only. u can try to check yr battery charging detect point.i mean the gold colour :) or the charger oso have the gold colour detect point.(it same position detect with yr battery point oso) well,check the both item Point wt i write as above.if it look some dirty ?? juz take some tissue paper clean it up :) Ps: after clean still not work,pls check the charger wyre. good luck :)
Posted on Jul 04, 2010
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
Asus1000ha flashes between AC Mode and Battery Mode
Based on your explanation I will try to answer your problem.
It seems you have a problem with charger regulator. When you plug your charger into AC outlet then this regulator will detect the current that flows through voltage sensor then the Vreg pole will command the regulator to open charging circuit.
In plain English: Your computer has a problem with power regulator IC which located near the battery poles.
Aug 11, 2017 | ASUS Eee 1000HA PC Notebook
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
Camera not charging charging light flashing
If the charging light is flashing then this indicates that the charger is okay. But if the camera is not charging still then one of two things could be the problem either the battery has not been properly fixed in its base therefore the power being supplied by the charger is not sufficient enough and therefore the battery does not charge.
On the other hand the battery could have run out of juice completely therefore not be able to retain power anymore.
Hope this solution has been helpful?
Feb 08, 2011 | Cameras
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Sep 27, 2010 | Panasonic KX-TG2356 Cordless Phone
No charge
The brake and the motor are all one piece. To replace the brake means to replace the motor.
Dec 06, 2008 | Pride Jazzy Select 6 Indoor Power...
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
In Use LED flashing constantly
Your phone may have lost registration to the base. 1) Try disconnecting the power to the base and then re-connecting the power with the cordless phone in the base. Give it a few seconds, then see if it works. 2) Try removing the battery, wait 10 seconds, re-install the battery and set the phone in the charger.
Jul 07, 2007 | Sony SPP A940 Cordless Phone (SPP-A940)
Vtech Cordless 6041 Phone Logo
367 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
