I NEED TO KNOW IF THE CA2000 PRE AMP HAS THAT CLICK TO LET YOU KNOW IT'S POWERED. AND HOW TO CONNECT IT TO THE AU-717 AMP
  • Anonymous May 03, 2008
    how do i get my pioneer sx-205
    off mute?
  • 4,234 Answers
Typically pre-amps do not have a relay. Any muting that is done is done using transistors.
Dan
Posted on Apr 17, 2008
I've been given a Technics sl-bd22d turntable, an Arcam amplifier and a Cambridge 551P pre amplifier. How do I connect them all together?
Depends what type of sockets these have. If the Pre-Amp has a RCA phono sockets you just need some RCA leads. I don't know if the Arcam Amp works with any pre-amp. But if it does, it's likely to have the same type sockets as the others. So you just buy another two RCA leads and connect it up.
Apr 19, 2013 | Audio Players & Recorders
Preout section cannot ingage
If you are using a pre out to a sub woofer, you need to make sure that the sub has it's own power amp or it will not work. You also need to go into the user menu and tell the amp that you are using a powered sub. Otherwise it will not turn on the pre amp output
Jun 20, 2012 | Denon Avr1610 5.1-channel Home Theater...
How can i use a pioneer PL-Z93 turntable with a pioneer A-717 amp?
Hi, there is no reason for the turntable not to work with your amp. This amp has 2 phono inputs. Moving magnet and moving coil. Your tt likely has a moving magnet cartridge fitted so connect via that input. Cheers John. styluscity.com
Nov 14, 2011 | Audio Players & Recorders
Can i connect a seperate power amplifier to my onkyo tx sr608? I have a "pre-out" for my subwoofer hookup, can I use that to go into my amp? I want to power my front main speakers with the more...
Nope, you would need specific pre-outs for external amps for the front channels. That is what the sub pre-out is and a powered sub IS an external amp.
How much bigger an amp were you considering? 100 watts is pretty good and to make an appreciable (audible difference) you might have to double it.
Read this paragraph:
http://en.wikipedia.org/wiki/Audio_power#Power_and_loudness_in_the_real_world
Dec 31, 2010 | Audio Players & Recorders
Can i link my amp (Beringer EP2500) to a Studiomaster Vision 8 powered desk. If so, would i link it the same way, straight from amp and into the main L & R outputs. Susan
I'll think you can link your EP-2500 to the powered mixer, but absolutely not into the main outputs.
Look if there's a pre-output on the console, that is one way to connect your amplifier
The other way is the master insert connector, then you have to use a stereo jack and connect the amplifier to the ring and ground from the jack.
Good luck,
Gerard
Feb 03, 2010 | Audio Players & Recorders
Subwoofer pre-out wires
Sorry for the stupid question but is your subwoofer a powered sub? The subwoofer out is just a preamped signal that drives a powered subwoofer. Let me know then we can go from there.
Jan 28, 2010 | Audio Players & Recorders
I don't know where to connect the main in & pre amp jacks??? to the EQ???
Not sure I understand your question, but I will try.
Your CD players, tape decks, etc., connect to the INPUTS on the preamp.
The LINE OUT on the PRE AMP connects to the LINE IN on the POWER AMP.
The pre-amp does some amplification and then it passes the signal along to the power amp, which will do the heavy lifting - driving the speakers.
The connection is usually through a shielded RCA plug cable. THere will be 2 cables from the Pre amp to the power amp - one for the left channel and one for the right channel.
The OUTPUT Of the power amp will connect to the speakers using large, stranded wire cables, sometimes with "banana" plugs that simply plug into the terminals on the power amp and the speaker.
Let me know if this gets your started.
Sep 28, 2009 | Audio Players & Recorders
I have a sansui au-717 ampand the left speaker side dosen't work for either A or B speakers. already swapped speakers so I know it's not a speaker problem..........
the amp will most likely need to be replaced but the pre amp will need to be checked first
can you perform these tests ?
electech
Nov 26, 2008 | Audio Players & Recorders
Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Nakamichi AV-7 Receiver
I am trying to hook together a computer and a turntable(Turntable has its own pre-amp) & I need a diagram on what wire gos where?
OK. Since there is a pre-amp, all you need to do is to connect pre-amp output to Line-in input on the PC. This may be a bit of challenge as the connector on the pre-amp and computer are of different types. Usually, you need a cable with RCA connectors on one end and 3.5mm stereo pin (same pin as you have for stereo headphones) on the other.
Aug 17, 2008 | Sony PS-LX250 Turntable
53 people viewed this question
 Grubhead
Grubhead
