Question about Compaq 17" Flat Screen CRT Monitor
Initial poor picture quality
When I first switch on the computer,initially screen picture and desktop icons are dark which is very difficult to see ,but as the time psses by picture quality becomes usual as good as is normal.I tried with the monitor contrast and brightness control but in vain. After I again stop the computer and again started the computer but then there is no problem for the rest of the day but again when you switch on the computer on the next day at the initial opening of the computer that darkness of the screen is happening and goinh away as the time passes by. give me the solution.
  • 518 Answers
How old is the moniter as it sounds like either dirty connections or the pixels are getting a bit tired
Posted on Jul 04, 2010
Cannot enter bios in the standard way with F2. I believe IDE controller is set to disable
Turn on your computer. If your computer is already on, then reboot it.
You need to see the initial display screen to get into the BIOS.
Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information.
The majority of Gateway computers use the F1 key.
If, for some reason this does not work, then use the F2.
All of Gateway's desktops use the F1 or F2 keys.
hope this helps
Sep 17, 2012 | Gateway GM4019E PC Desktop
My screen only displays after 4 /5 hrs
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Jul 23, 2009 | Computers & Internet
Dark blue screen with words: Cable, Digital TV, No SIGNAL. Brand new TV.
that says it all... no signal look at your owner's manual to set it for TV
May 22, 2009 | Initial DTV-322 32 in. TV/DVD Combo
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Have hp note book s/n ey349et#abu screen not working just blank
First of all the serial number does not help identify the model of your computer, Second, when does the screen go blank? From initial start up, after it starts up? Is the screen illuminated or dark? Please understand that since I can't see you computer you must give me more, rather than less, information to help you.
Oct 19, 2008 | Computers & Internet
Ok I have a G3 ibook recently my screen has lost some of its color quality. When I power up all is fine until the initial screen saver kicks in then it goes to what can only be described as old color...
Step 1.After you come to desktop .right click and then select properties.> then for the color settings it should be 32 bit..you will find that option in the last tab..
Step 2. open 'Run' type dxdiag > after whic a window will open now check all the tabs and set the hardware accelaration to full.
Hope this resolve the issue..
Sep 02, 2008 | Computers & Internet
Evesham 8640 Laptop Screen Failure
Most likely the backlight has failed however replacing the backlight is impractical and the screen should be replaced.
Jun 23, 2008 | Computers & Internet
Gray screen
mine too. polaroid tla-01511c
Jun 16, 2008 | Initial Televison & Video
Very dark screen
If the desktop could be seen (albeit very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Toshiba.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 07, 2008 | Toshiba Satellite L20-S310TD Notebook
JVC TV AV27D305
Assuming the CRT is still OK, it could either be:
1. Screen Voltage is low;
2. G2 B+ is out (common problem is a mega ohm resistor open);
3. a resistor gone high (or open) in the DA converter of the controller IC circuitry.
Any of the above would require extensive knowledge of electronic circuitry and components, use of a DVM and a soldering iron. Perhaps your best bet may be to seek the services of a professional.
Pls likewise consider the age of the TV (if a couple of years) and/or the downtime and cost of repair,. it may be more practical to purchase a replacement unit.
Mar 02, 2008 | JVC AV-27230 27" TV
Compaq 17" Flat Screen CRT Monitor Logo
71 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
