Question about GPS
SPLASH SCREEN FROZEN ON TOMTOM GO 500 - GPS
  • Anonymous Aug 31, 2008
    just frozen!
  • Anonymous Dec 26, 2008
    Tomtom starts up with splash screen and is frozen there. Started after connecting to computer and updating software. Resetting doesn't fix it.
  • 515 Answers
710 frozen on tom-tom splash screen
1. Activate the TeleType GPS program
2. Select Tools>GPS Status>Status.
3. Look closely at the GPS output that is displayed in the View Status menu. Data should be flowing even when the GPS receiver has not locked in the position.
The data string that begins:
GPGSV... is "bad data" because the receiver has not locked into the satellites.
Whereas:
GPGSA... is "good data" indicating that the receiver has locked into the satellites. Remember - "A-Okay"
4. Once the data is flowing, go outside away from buildings, select the Satellites tab (Tools>GPS Status>Satellites), and watch the satellite signal strength
Nov 27, 2007 | Tomtom GO 700 GPS Receiver
Tomtom ONE XL doesnt go past start up screen
You may want to try operating your TomTom from TomTom Home. This has seemed to work for a lot of people who do not have backups, as you are connected to their site. Apparently, a file or two are updated, and you are back in business. Here's an example:
"Though not using a 720 my 500 wouldn't startup after upgrade to 7.16. Always stuck on the first splash screen.
After conncting to Home I chose Operate my Go and another file was downloaded. After this the device would boot up norammly when not connected to my PC.
Might be worth a try."
Jan 26, 2009 | Tomtom ONE GPS Receiver
Start up screen
I had this same issue on my 930. You need to edit the bitmap with paint and make sure the dimensions are the exact same as the splash file. Rename the new splash screen with the same filename for the old startup screen and delete the old. That should fix it
Jan 04, 2009 | Tomtom One XL GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
Tomtom go 500
  1. switch tomtom on .
  2. tap screen where the satelitte bars are ( bottom right )
  3. You should have a status bar on right of screen with a battery symbol , under that is a satelitte signal bargraph , under that is a " version number ".
  4. tap screen where version number is
  5. all details including device number should now show on screen.
GOOD LUCK
Dec 05, 2008 | Tomtom GO 300 GPS Receiver
Frozen screen
I have had a frozen screen on my TOM TOM - I solved this problem by resetting the TOM TOM. I did this by pressing the pinhole reset buttom on the back of the unit - labled RESET.
Nov 27, 2008 | Tomtom ONE GPS Receiver
Frozen startup screen
jump up and down on it about 27 times sorry 28 and see if that helps, it did me - i then went and bought a MAP
Oct 24, 2007 | Tomtom One Europe v2 GPS Receiver
Frozen tomtom
Try the reset button on the hole in the bottom of the unit. I had a frozen unit after attempting to upgrade and this made it work. Use a paperclip to press into the hole, it will reset the unit.
Feb 25, 2007 | Tomtom GO 300 GPS Receiver
GPS Logo
1,105 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
