Question about Konica Minolta magicolor 2300DL Laser Printer
Magicolor 2300 32-bit win7 drivers not available?
  • 518 Answers
All I can suggest is unplug printer,turn computer on then off.thenplug in printer and windows might see and load a windows driver
Posted on Jul 04, 2010
What is ch usb dvr 4channel driver for win7 64bit?
There might not be one for a 64 bit OS .You might check their web page to see if a 64 bit driver is available, if not then it will only work on 32 bit computers.
May 29, 2014 | DekCell EasyCap 4 Channel USB 2.0 DVR...
Drivers win7 64 bit
tried the vista x64 drivers? http://support.asus.com/download.aspx?SLanguage=en&m=M2N-MX&os=22
Offical Win7 64bit drivers are not available for this board.
Otherwise you can check for your chipsets (Which gpu chip, which audio chip, which LAN chip etc.) and take a look at the site of its manufacturers. (For example its often realtek for lan chips.)
Dec 25, 2013 | ASUS M2N-MX Motherboard
Page count
Konica Minolta Magicolor win7 64bit driver
Oct 25, 2013 | Konica Minolta Magicolor 1600W Printer
Is my linux computer compatible with windows xp software? are the parts interchangeable? example= installing a linux video card in a windows 7 tower?
Most devices that have Unix drivers will also have drivers available for some versions of Windows. Asus lists XP drivers for this board: http://www.asus.com/Motherboards/AMD_Socket_754/K8V_SE_Deluxe/#download . The K8V-SE Deluxe motherboard is not listed as Win7 compatible (but it's not listed as known incompatible either). To test if this board is Win7 compatible, update to the most recent BIOS, then use a Win7 install DVD to search for drivers and other support. (I know the Windows Update disc confirmed that my WinXP box would support Win7.)
For moving components into another computer, you will need to identify the exact device that you want to move and the slot/interface for that device. For example, since ASUS K8V-SE Deluxe motherboard has an AGP video card slot, it will not fit in a newer tower with only PCIe or PCI slots. If your Win7 tower does have an AGP slot, you may need to look in will amongst the drivers for "legacy cards". Finding an XP driver will be fairly easy. The Windows 7 driver may not exist and Win7 may not run without an external video card (if it can load at all).
I hope this helps. If you are looking at a different motherboard or wish to check specific components, please add a comment with the make and model of those parts. I'll be glad to try to find additional information. Include in your comment whether the Win7 tower is/will be running Windows 7 32-bit or 64-bit. Drivers for the 32-bit Windows are more common since they don't need the signature. (To check if a Windows machine is currently running Win7 64-bit, click Start > Control Panel > System and Security > System. If the title ends with x64, it's the 64-bit OS. Otherwise it's the 32-bit version.)
May 11, 2012 | ASUS K8V-SE Deluxe Motherboard
Ethernet drivers looking P5LD2 motherboard OS win7 help my please thanks
I am not sure if the motherboard has been certified for Win7.
However the Vista LAN drivers are available from this site.
Sep 15, 2011 | ASUS P5LD2 Motherboard
W7 does not recognise it and ati drivers does not work
This card doesn't support Win7 - it's only Dx8.0 compatible and Win7 needs a card that is at least Dx9.2 compatible.
Get a new video card.
May 30, 2011 | Abit R9250-128CDT RADEON 9250, (128 MB)...
Can I upgrade the drivers for this board to run win 7 64 bit
no drivers are available from any mfg of any hardware....all of the drivers have been given to MS by all mfgs.....
so if u r runing win7...then i am sorry MS will first validate ur Win7 for genuine OS...then only they will alow u to get the correct driver for any HW....
so contact MS for any driver for you PC....else do as i do...
have dual boot ...
C: for WinXP
D: for Win7....
so any activity that i cant do in win7 i fall back on XP to do...
Sep 27, 2010 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
I need a driver for lide80 canoscan scanner
What OS do you have? The drivers (supported OS versions) for the LiDe 80 are available here: http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_80#DriversAndSoftware . If you have Win7 64-bit, the Vista x64 driver doesn't work even in the compatibility mode.
If you want a work-around for the 64-bit OS, Win7 Pro and Ultimate allow you to download and install XP mode free. This takes two programs, Virtual PC and the XP mode, that you download from Microsoft and install. This will run a virtual computer under Win7 and you can install the scanner to the virtual computer. To share files with the real computer, you should store them on external media.
Alternatively for Win7x64, you can install any of the other Virtual computer programs (Parallels, VMWare, etc) with a licensed older version of Windows. Then do the same as above. Another option is a dual boot computer with the older licensed version of Windows with the scanner installed to the "machine" with the older OS. I don't see a Unix driver for this scanner so you need a valid copy of Windows.
I hope this helps.
(If you have Win7 x64, the only other options are 1) to try and get Canon to extend their drivers (since they do support Win7 32-bit) or 2) get a new scanner.)
Sep 15, 2010 | Canon CanoScan LiDE 35 Flatbed Scanner
I have installed my Lexmark X4650 under Windows 7, and although it works fine - including the wireless connection - the Ink Status doesn't feedback to the computer. It's not exactly critical, but it's...
Under Windows 7 the main problem is the 64bit to 32 bit bridge with the driver being 32bit and Win7 being 64 bit. (I assume you are using the 64 bit edition of Win7 - as this is what I have and is doing exactly the same)
After contacting Lexmark I was told they are in the process of updating their driver website pages, to include an updated driver for the X4650 for win 7 the 32 and 64 bit.
Until they release the update, it is something I have to live with too. :-)
Hope it answers your question.
Mar 12, 2010 | Lexmark X4650 InkJet Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
286 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
