Question about GE Monogram ZISS480DRSS Stainless Steel
Icemaker is stuck on dispensing ice cubes and
Icemaker is stuck on dispensing ice cubes, ice just started falling out on its own and cannot seem to unstick the lever or turn it off. Had to put a plastic cup inside of door to plug hole. Any easy fix-it ideas? Thank you.
  • 53 Answers
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Icemaker is on cube but is still crushing ice it seems like it is stuck on crush,the light is on cube.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Nov 13, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE side by side CAN17 ice maker...white ''finger assembly'' that pivots has broken two fingers, and the ice cubes are stuck in the cube dispenser. Any ideas why this happens, and how to fix it without...
You will need to replace the icemaker. The sensor that activates the heat coil in the icemaker is bad. The heat sensor allows the cubes to be released from being frozen to the ice tray. Check ebay for a new icemaker. About one third the price of manufacturer for new factory unit.
Oct 27, 2009 | GE Refrigerators
Our GE Monogram Icemaker will only dispense crushed ice
Aug 29, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Whirlpool refrigerator icemaker does not dispense ice cubes
I don't think the ice maker liked the water being turned off. Usually there is an arm that will raise up to a catch position that will turn the ice maker off. I hate to say it, but ice makers are best to replace than repair. The internal parts are difficult to change, and with a new one you will have no problems. They are not too hard to change. Shop around for a good deal, I use e-bay.
Apr 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Ice maker does not stop working and overfills, then ice dispenser does not work and pushes door open.
Continuous ice production, too much ice in the bucket, ice cubes overflowing the bucket, ice cubes falling behind the bucket or ice lifting the chiller shelf can now be resolved by installing a redesigned feeler arm. The new arm is designed with a slight curve to cycle the icemaker “OFF“ before the cubes overflow the ice bucket. Order part number WR49X10103.
Jan 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISS480DRSS Stainless Steel Logo
160 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
