Question about GE GSH22JFR Side by Side Refrigerator
Not really a problem. I am just wondering what the running wattage is and what the startup wattage is. I am trying to figure usage for my emergency generator.
  • 53 Answers
It's on the face plate, at the bottom of the refrigerator
Posted on Jul 04, 2010
What do i have to know about watts in order to work out each appliances power usage aday
Add up all the wattages of the appliances you are using when they come on and go off including lights. fridges. freezers, fans , stoves, tools and every thing. add them all up and you will get thousands of watts called kilo watts . see how many you use per hour and you will get a kilowatt/hr usage rate. Find out the power cost per kilowatt/hr and multiply the usage by the cost and you have your answer. Or you can get a wireless transmitter that is clamped around the input line to your premises and it transmits to a receiver to inside your house (mine sits on the fridge) and it tells you the cost as everything is running . press the mode button and you get progressive cost and other modes are there as well. It is great because if I forget and leave the pool running I can see at a glance that something drawing a lot of power is running so I can check it out and turn it off. Ask you power provider about it or a good electrical shop.
Oct 07, 2013 | Computers & Internet
Oster Fpstdh0101 4tray Electric Food Dehydrator wattage
well, I'm guessing on the tag or label it shows something like this
120V ~ 60 hz 10.5 amps or
120V ~ 60 hz 10.5A or
120V ~ 60hz 11A (some manufactures round up if it falls into the same wire gauge)
120Volts ~ 60hz 1260w or
120Volts ~ 60HZ 1260 watt
120V stands for normal operating voltage
"~" means ac current
60 herzts stands for how many cycles
So if your unit shows only amps, it's really simple to figure out wattage
take the voltage shown, in my example it's 120, then multiply the amps, in my example it's 10.5. So 120 X 10.5 = 1260 watts
W = V * A
and vice versus, if it only show wattage and you needed to know what gauge wire you needed to run a receptical to operate it
AMPERAGE = VOLTS / WATTAGE
Mar 07, 2013 | Oster Fpstdh0101 4tray Electric Food...
Upon starting my dell inspiron mini 10 I have to wait 17 min before I can use the start button. ctl+alt+dell show me the process running: system idle process is the only process running, the CPU usage...
Do you have any antivirus program installed? If you have, check if it set to scan during startup. This might be the reason why your computer is slow during startup since a full computer scan can definitely eat up memory usage.
Hope this helps.
May 22, 2011 | Dell Inspiron Mini 10 Notebook
Hi. I have a 5000 watt inverter in my truck. The alternator in the truck is a 150? amp alternator. I also have 3 deep cycle batteries (about 150 ah each) to run the inverter. Is this overkill for my...
A 5000 wat inverter is very large. Your alternator could not supply it alone without the batteries. The moderate to low usage is the key. Calculate the wattage of the load you want to connect. Depending on what else you're doing with the truck, lights, heater, air condition etc, you could probably draw somewhere between 1,0000-1500 watts on that alternator. Rember even if your alternator is rated for 150amps (large alt) it is not a 100% duty cycle. Alternators are usually around 50% duty cycle, so figure about 75amps continuous, or around 900 watts. That's considerably less than your 5,000 watt inverter. Buy a generator.
Jul 01, 2010 | Inverter Aims Pure Sine Wave Power...
On switching on computer it comes up with RUNDLL Error loading thxr.wgo The specified module could not be found. I don't know what it means - I just keep clicking OK but we are having problems with the...
thxr.wgo was detected as a Trojan. You really need to remove the file. From your explanation it sounds you have already removed it but there are some startup entries which are trying to execute it.
To remove the startup entries you can try running hijackthis ( you can google and download ) uncheck the option which has the the filename "thxr.wgo" I recommend not to go for any other options until you know how to use hijackthis.
Refer the link to understand usage of hijackthis.
http://www.bleepingcomputer.com/tutorials/tutorial42.html
May 17, 2010 | Lenovo Computers & Internet
Hi i was wondering what bulb to put in the headlight and front light as the 12V5W burns out really quickly(2 days) headlight lasts alot longer however not the brightest.
The wattage shouldnt cause them to blow, the most common reason is vibration, followed by high voltage. check the voltage , should be around 13v running
May 06, 2010 | 2001 Daelim VT 125 Evolution
Macbook pro, high CPU usage caused by HPImager? HELP! :S
Try going to system preferences, then click on accounts, then click on login items, and then delete all the startup programs you see there. It doesn't delete the actual programs. It just deletes them from automatically starting. Also, there is a free utility that you can use to adjust fan speed upon startup. Its called SMC fan control and you can Google it for download.
Jan 26, 2010 | Apple MacBook Pro Laptop Computer with...
RAM usage seems high. Even right after startup,
it's just normal;but try to figer out if you are running memory intensive program disable them if you don't need it and moreover scan your PC with a good antivirus for anti malware they are usually memory hungry program.
i recommend to use A-squared anti malware from www.emsisoft.com.
here is the link
http://www.emsisoft.com/en/
hope this helps you
Dec 07, 2009 | Dell Inspiron 1525 Notebook
CPU usage very high, mouse very slow man
hi,
you haven't mentioned whether your mouse started moving after you deleted the applications..
Anyway to lower your CPU usage, you can do the following...
1. Run 'msconfig' without the inverted comas in the run dialog box. ( start--> run )
2. Select the startup tab... you can disable all application at startup to load the system faster. or you can select the application that you thing is unnecessary. this needs a restart.
3. Next try to press Ctrl, Alt , Del at the ssame time to launch the task manager. First you will be seeing the application that is running. Go to the next tab that is the Processes tab. under this you will see all the processes that is running and utilsing how much resources . Below on the status bar of that window you will see the cpu usage... Now identify the processes that has the highest memory usage... right click and select end process tree. the process will be stopped. Remember not to end the explorer.exe process. Most resources is utilised by Anti-virus softwares like norton, also by web-browsing and graphics opertaions....
hope to get rated as fixya!!
regards
bzoy..
Jan 03, 2008 | Acer Aspire 3000 Notebook
Washer Power Requirements
Hello kgodsave,
You are not really going to run everything in the house while using your washing machine, isn't it? If your machine runs on 1 horse power (HP) motor (which is unlikely), thats already 746 watts. say you are running some little wattage appliances say total of 1,000 watts. Double that figure and you get 2kw. A 2kva to 3kva generator would be ideal...got plenty clearance for unexpected load.
Dec 21, 2007 | Washing Machines
GE GSH22JFR Side by Side Refrigerator Logo
106 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
