Question about Danze & Single Handle Tub And Shower Faucet
There's no set screw or plate covering the set screw. Not sure if handle just snaps on or what Danze Parma faucet
  • 760 Answers
You didn't indicate exatcly what model. Check this link, and follow the install instructions. It tells you how to secure each type (3 different methods) One is a screw in the side with a cover over the screw.
http://www.danze.com/tech_specs.asp?show=D500058BN then click on install notes
Posted on Jul 04, 2010
Our Danze D225558 Parma Single Handle Lavatory Faucet is suddenly running very slowly. What needs to be fixed?
First check the aerator to see if it is clogged. If not, it might be the cartridge that is clogged.
Feb 11, 2017 | Danze Plumbing
How to pull the lever off the top
There is a set screw under the handle lever maybe covered with a small cap or bottom type cover. remove that cover if it's still there and loosen the set screw and pull the handle off.
Feb 12, 2011 | Danze D403412 Melrose Single Handle...
Water is dripping out the back of the the Danza 61/9 kitchen faucet
Just in case you need to do so.
  1. Turn the water off. The water control knob is located under your sink and is connected to the drain. Turn it counterclockwise to turn off the water.
  2. 2
    Open the faucet to relieve any differences in pressure. Pull up on the faucet as you would if you were turning it on.
  3. 3
    Plug the drain of the sink with its stopper to prevent any parts from going down it.
  4. 4
    Turn the faucet handle sharply to one side to reveal a small cover plate. Pry the plate off carefully with a flat-bladed screwdriver.
  5. 5
    Unscrew the screw that is located behind the cover plate with a 4 mm allen key.
  6. 6
    Lift the handle off and remove the cap beneath it.
  7. 7
    Firmly grip the exposed cartridge with your hands and pull up to remove it.
Read more: How to Remove the Cartridge from a Danze D403412 ' eHow.com http://www.ehow.com/how_7640485_remove-cartridge-danze-d403412.html#ixzz1D76xWEgn I your case I think all you need are new o-ring seals on the spout. once you have the handle off and have gotten to the cartage grab the spout and turn back and forth while pulling up and remove the spout you will see the o-rings. I would get the repair kit before you start. The video below is not your brand faucet but the o-ring replacement is about the same. http://www.youtube.com/watch?v=AipEYoYiIhc
Feb 05, 2011 | Danze D403412 Melrose Single Handle...
How do you tighten or remove handle on a danze shower faucet
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
Jul 02, 2010 | Danze & Single Handle Tub And Shower...
How do I remove the handle to check the Cartridge on a Danze D307456 Bannockburn Widespread Double Handle
You need to hold handle lever and unscrew the bottom escuteon plate you may need a small strap wrench it will turn counter clockwise. On some older models there was a set screw on the handle which you would use an allen wrench
Nov 13, 2009 | Danze D307456 Bannockburn Widespread...
The pullout faucet wobbles when returned to the base.
check that nothing blocking hose return weight under sink
Oct 06, 2009 | Danze D405058 Parma Single Handle...
Danze pressure balance single handle shower faucet (D500558BN) pipes vibrate when adjusting hot and cold water.
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Jun 10, 2009 | Danze D500558BN Parma Shower w/ 4"...
No water to single hole faucet after installation
the cartridge has trash in it.remove and clean,will work after that is done.
May 24, 2009 | Danze D222158 Parma Single Handle Hole...
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze & Single Handle Tub And Shower Faucet  Logo
458 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Chris Brown
Chris Brown
Level 1 Expert
Are you a Danze Home Expert? Answer questions, earn points and help others
