Question about Dishwashers
Kenmore 13823 dishwasher run endless and can noot stop itself.
  • doublewood77 Jul 04, 2010
    Thank you. Kenmore 665.13823 dishwasher ran endlessly and couldn't stop wash cycle.
  • doublewood77 Jul 06, 2010
    Thanks macmarkus.
    It would literally run until the cancel button was pressed. Also, we have not done any change of hot water supply, drainage or plumbing since the dishwasher (Kenmore 665.13823) was installed 3 years ago.
  • Dishwashers Master
  • 2,605 Answers
Hi, Can you open the door and look to the side for a white or silver in colour label and provide the complete model number, the number you've provided ( 13823 ) is only a partial model number. Thank you. macmarkus :)
Posted on Jul 04, 2010
  • Mark MacDonald
    Mark MacDonald Jul 05, 2010
    Hello again.
    How long do you allow the unit to run before canceling the cycle, 2 hours, 3 hours or more ? Or if you do let it continue will it literally run until the cancel button is pressed ?
    Has there been any significant changes to your installation, hot water supply, drainage or plumbing ?
    macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jul 06, 2010
    Hello again,
    Based on what you've described I suspect you're having an issue with the heating element or the heating circuit. It can run for hours trying to heat the water, but if an open circuit exist's it will just run & run without being able to heat.
    Are you able to answer another question ? Does the water appear hot after it's been running for a couple of hours, or luke warm or cold ?
    macmarkus :)
Kenmore dishwasher blinking E2F2
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Then you have to wait 2 minutes while your Kenmore dishwasher runs its diagnostic test.
Then press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop any lights from blinking.
Jan 29, 2015 | Kenmore Dishwashers
Refresh control panel
Instructions
    • 1
    • 2
    • 3
      Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
    • 4
      Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
      Hope this will be of help to you
      Have an awesome day
Feb 08, 2012 | Kenmore Dishwashers
Dishwasher won't stop running
The controls have failed. The knob that you turn or the button that you push. They are not hard to replace but the parts are reletavely expensive and the labor always get you. My Kenmore did this and the part was half of what I paid for it when new. I replaced the dishwasher. See if you can find a retired handyman to at least look at it before you go get another one.
Sorry!
Dec 30, 2011 | Maytag Dishwashers
My Kenmore washer would not stop filling with water. i checked and the pressure sensor hose was of the switch, i rehooked it, but it still does not stop filling with water. do i need to do something...
Hello.
Kenmore washer come in a variety of s and styles,including extra-large dishwashers and dishwashers that are accessible for thedisabled.
A Kenmore washer automatically resets itself every time a washingcycle completes.
If you want to reset an Kenmore washer in the middle of acycle, you can easily do so. Resetting a Kenmore washer takes only a fewseconds to complete.Instructions.
1 Press the"Start/Stop" button.
2 Hold the buttonfor three seconds and release.
3 Select the program and options on the frontpanel you want the dishwasher to use. Press "Start/Stop" to restartthe dishwasher. You have now reset a Kenmore washer Thanks.
Jul 30, 2011 | Kenmore Washing Machines
Can start dishwasher but gets stuck on same time and water does not fully drain, can you please advise what solution there is thanks
When you say gets stuck - does the dishwasher stop all together or keeps running endlessly with same time displayed on the display.
Can you try with another cycle like rinse only. Does it complete cycle and fully drain water?
If so, the diswasher heater could be packing up. If you use hot water connection then see if you can increase inlet water temperature and run the normal cycle again.
Dec 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Loud noise starts as soon as water starts coming into dishwasher. Stops when water in or water draining. What could it be?
This hammering is usually from restrictions in the water line or inside the valve on the machine itself.
Try taking the water line off of the machine(with the water supply turned off) then disconnect the line from the dishwasher and flush water into a bucket from this line until it runs clean. Reconnect, if it still makes the noise you will need to replace the inlet valve on the dishwasher. Let me know if this was helpful or if you have questions please.
Thank you
Jun 14, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Need to clean dishwasher
try cutting the power off your dishwasher for 5 minutes,hopefully the board will reset itself
Mar 29, 2010 | Dishwashers
Dishwasher issues
You should always turn the hot water faucet at the kitchen sink first before starting dishwasher. If you don't your entire wash is cold water. This will also cause the water temp mode to take forever to heat the water to the 140 that is factory set. Hope this helps.
Feb 02, 2010 | Dishwashers
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
