There is a black tubing where the exhaust hose goes therefore i can not get the exhaust hose on.what is this black hose for? do i have to reroute this?
  • 53 Answers
There is no exhaust hose on a A/C unit. That black hose, or seal tight, has wires in it. Are you talking about the hose from the drain pan. If that is what you are talking about. Put a water hose on the drain and blow out the blockage. make sure the drain hose by the condensor outside is not barried. Put a 90% fitting on the end of the out side drain hose faceing up, to keep water in it to keep out critters.
Posted on Jul 04, 2010
Stop leaking?
There should be rubber hoses at either end of the metal pipe to allow for engine ,movement. It would be black steel pipe and it rusts out from lack of coolant conditioner.. A final fix for this would be to take it to a muffler/ exhaust shop and have a new pipe bent to shape made out of exhaust stainless steel tubing
Mar 14, 2014 | 2000 Ford Windstar
Where does the elctric air pump hose go and the two vaccum lines go
The electric air pump has two lines intake air and exhaust air the exhaust air goes to a diverter valve on some models then travels to metal tube and separates to the air check valves on the injection tubes to the exhaust manifolds. the diverter valve has the vacuum line on it which goes to the electric switching valve and then to manifold vacuum.
Nov 08, 2013 | 1999 Oldsmobile Bravada
Hard to start then black smoke out exhaust rough idle
Check the fuel pressure regulator. It may be bad. Pull off the vacuum hose to it and check for any sign of gas in the hose. A busted diaphragm in the regulator could let extra gas into the intake through the vacuum hose. The black smoke indicates it is getting too much gas-running rich.
Jun 12, 2012 | Cars & Trucks
My 1987 deville has been missing the intake hose that brings fresh air into the air pump. the hose before the inline filter is the part i need but can't determine if anything else is missing as w
The A.I.R. (Air Injection Reaction) System was included on California-emission equipped vehicles. The system is designed to provide additional oxygen to continue the combustion process after the exhaust gases leave the combustion chamber. The system begins with the outside air inlet, which is a short, L-shaped open-ended rubber hose running from the lower front passenger fender well into the canister. The black plastic round canister is located in the front passenger-side engine compartment, adjacent to the EECS (Evaporative Emission Control System) canister, which looks similiar, but the EECS canister has electrical connectors on the top. While the charcoal canister of the EECS is a sealed unit, the A.I.R. canister has a twist-off lid to access the disposable filter. The inlet hose goes into the canister, air then passes through the charcoal filter, and travels into the outlet hose (also made of black rubber), which then connects directly to a metal tube coming up the front of the engine. Please contact me if you need a diagram or photos.
Mar 13, 2012 | Cars & Trucks
How do i change my oil in my 1999 Harley fatboy
From the right side of your bike, look for a large hose coming out of the backside of the oil tank at it's lowest point. Follow the hose down behind the transmission on down to a clip on the lower tube of the frame behind the exhaust pipes. There is a metal plug in the hose. Simply take the hose out of the clip and reroute it below the frame. Remove the plug and the oil tank filler cap and the oil will drain out. Refill with three quarts of 20W50 oil.
Good Luck
Steve
Mar 12, 2011 | 1993 Harley Davidson FLSTF Fat boy
EGR VALVE 1999 MERCURY COUGER
SECTION 303-08: Engine Emission Control 1999 Cougar Workshop Manual REMOVAL AND INSTALLATION Exhaust Gas Recirculation (EGR) Valve Removal
  1. Remove the air cleaner outlet tube.
    1. Disconnect the intake air bypass hose.
    1. Disconnect the positive crankcase ventilation hoses.
  1. Disconnect the tube from the exhaust gas recirculation valve.
  1. Remove the exhaust gas recirculation valve.
    • Disconnect the vacuum hose.
Installation
  1. sxu~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: When cleaning the gasket faces, do not allow debris to enter the intake manifold or exhaust gas recirculation valve.
    Clean the gasket faces of the intake manifold and exhaust gas recirculation valve.
  1. Install a new exhaust gas recirculation valve gasket.
  1. Position the EGR valve and install the bolts.
    • Install the vacuum hose.
  1. Connect the EGR tube.
  1. Install the idle air control valve. For additional information, refer to Section 303-14A . For additional information, refer to Section 303-14B .
Sep 15, 2009 | 1999 Mercury Cougar
P0344 Camshaft Position Sensor A Circuit Intermittent (Bank 1 or
The camshaft sensor is located right above the crankshaft pulley on the passengers side of the front cover of the engine. It will be a 3 pin sensor either gray or black in color. There is a pointer that is attached to the sensor and it is either gold or silver in color. There is also a recall out on this camshaft sensor. If the color of the sensor is black then it should qualify for the recall. If you get in touch with a Ford dealer they should be able to help you with your recall if the sensor is black since it is a safety recall. As far as your exhaust pressure sensor it is located on the front of the engine right by the heater core hose a little to the passengers side of the center of the front of the engine. there will be a tube attached to the bottom of the sensor that goes from it to the front of the exhaust manifold on the very front of the passengers side exhaust manifold.
Apr 10, 2009 | 1999 Ford F250 Regular Cab
Toyota 1988 camry
Egr Valve is usually attached to plenum with a tube that runs to exhaust minifold. If you dont know what those things are then. Find the black tube that runs from the front of the car to the front of the motor. there should be a big square box where you air filter goes in the middle of that tube. Well where that tube connect on the front of the motor. That is called the throttle body. the big block of aluminum is called the plenum. Bolted to that plenum is going to be a space ship looking thing that has one rubber hose a wireing plug that plugs into it and a long tube that is attached to the bottom that goes down behind the motor to your exhaust. There should be 2 or three nuts or bolts that hold it in place. Sorry if I overexplained this but I do not know how much you know about the car......Good luck!
Dec 26, 2008 | 1988 Toyota Camry
Dryer exhaust not blowing out of vent tubing
open it up follow the vent,it is either blocked or came off.
Dec 08, 2008 | Splendide 2100 Vented Washer-Dryer
Heating & Cooling Logo
259 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
