Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Cub Cadet cc4125 - Worn out, excessive smoke with
Cub Cadet cc4125 - Worn out, excessive smoke with little use. Excessive 1/8"+ Compression ring end gap. Worn oil control ring (no expansion in diameter beyond piston diameter). It's easy to see how the oil easily reaches the combustion chamber from the crankcase. All other tolerances are fine. The parts list shows an entire piston and piston rings, a $35.00 + . The piston is fine - from all the oil between it and the cylinder. Where can I find a set of piston rings only? I may be behind the times and these things are relatively cheap, but it's very difficult to scrap an otherwise operable trimmer due to excessive part costs. I checked with Sears for the Craftsman version. They sell the shortblock with everything but the cylinder. Cylinder dia. =1.255". Compression rings' cross section: 0.032+ thick and 0.040" depth. Oil control rings are 0.010" x 0.040". These of course are separated by the expansion ring. The combined thickness is 0.070".
  • Tom Bee
    Tom Bee Aug 14, 2015
    My Cub Cadet 4125 would start on starter fluid but would not run. The carb had a glob of varnish in it. I cleaned the carb out put it back together with a few skwerts of carb cleaner. It started right up. Runs great I am going to drain the fuel out from now on. store it DRY.
  • 706 Answers
It's not worth the expense and time, just purchase a new one.
Posted on Sep 02, 2016
5 Suggested Answers
  • 125 Answers
SOURCE: excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
Posted on May 25, 2009
  • 323 Answers
SOURCE: Never used trimmer won't stay running.
Sometimes when they set up a long time the gas turns to something that smells like shellac and clogs up the fuel lines and the carb jets. Even though you've put in fresh gas, (1:50 ratio) the carb and lines may still be gunky. If you get it to start by spraying starter fluid in the carb, then its simply running out the starter fluid.
I would begin by replacing all the little plastic hoses from the gas tank to the carb and make sure the primer bulb is in good condition. That done, I'd take off the air filter and spray carb cleaner through it until it ran out. You'll have to crank some, without expecting it to start, but you have to get whatever is in there out.
This will mess up the spark plug, so if you have the old one, put it back in until the cleaning is done.
Press the primer bulb until you know fresh gas is coming out. When it is thoroughly cleaned, put it all back together and let it dry out.
Then try again, giving the bulb 4 or 5 hits. If it turns over on full choke and sounds as though it might run, back off the choke a little. You'll probably need to spray starter fluid in the carb until it is drawing fresh gas.
If you can't get it to run continuously, get a small screwdriver and when you get ready to start, turn the high speed adjustment a 1/4th turn to the right.
Keep trying that until it either runs or doesn't. Keep track of how many quarter turns you make. When it does start, hold the throttle wide open. If you've turned the screw to a point where it won't start at all, turn the hi speed screw back the number of turns you opened it, and then turn it all the way closed, counting the number of turns from where it originally was. After closing it, try a starting point at about 2.5 turns open. Once you get it started at wide open throttle, you have to play with the high speed screw, turning it first open, listening to the sound of the engine. If it starts to sound smoother, continue until it starts to stutter, then go back 1/2 turn. If it doesn't start, or sounds worse when you open it, turn back closed until it smooths out. Once started and it keeps running, run it long enough to get everything burned out.
To get it started easily after the hi speed is ok, then play with the low speed the same way. I would start by closing it (left) and counting the turns. Then go back to that point and open 1/2 turn. Do that until it either starts easily or is obvious it won't start and run well at low speed. Then go the other way.
It takes a while, but it will be worth it once you get it running. If all else fails, you can buy a new carb online for probably $30.
Good Luck!
Posted on Jun 01, 2009
  • 1584 Answers
SOURCE: Trimmer dosen't start.
When you gapped module did you set it to Manufacturers spec.....extremely important, also supposed to use brass feeler blades to gap. Gap is usually 0.010" inch. Also ensure that the flywheel magnets are NOT rusty.
Timing will alter if flywheel key is worn.
Is fuel getting through as the carby has a fuel pump diaphragm in it also.
Have you trieds pulling choke when it splutters, will ID fuel stravation??
Posted on Jan 08, 2010
  • 3740 Answers
SOURCE: Trimmer is producing alot of
This engine does NOT used mixed gas at all! It uses straight unleaded gas. If your using mixed fuel of any mixture ratio in the engine it is really going to smoke badly. What fuel are you using please?
Posted on Jul 02, 2011
My 2011 Kia Cerato "S" has been using a lot of oil. The cylinder head was re-conditioned and engine serviced. The now engine blows smoke every time on starting. What is the probable cause ?
depends on how the head was reconditioned
were new valve guides installed along with new valves
were the stem seals correctly fitted
was a compression test done to determine the wear condition of the engine
smoke on start up is oil in the combustion chamber from valve stem seals , worn rings , sump pressure from excessive blow by through the line to the air inlet
check for oil leaks ( filter etc ) but using a lot of oil indicates ring problem, excessive bearing clearance overloading the oil control ring
try using a heavier grade of oil 30w 50 or oil for worn motors
Dec 04, 2016 | Kia Cars & Trucks
Would a bad pvc valve cause a 2008 Ford Fusion to smoke when going up hill
not necessarily
the purpose of the PCV valve is to vent the compression gases that by pass the rings into the sump back through the inlet manifold and so have the fumes burnt before going out the exhaust pipe
There fore it stands to reason that if you have worn rings/ broken ring or cylinder scored then there will be excess compression gas to the sump which tends to boil off the oil or actually burn the oil fumes in the sump and this excessive smoke will find its way back into the inlet manifold and if too much ,out the exhaust as smoke
when going up a hill that amounts to extra compression being exerted on the rings and pistons and a larger part of the compression gas into the sump and out the rear as smoke
I suggest that you have a compression test done to gauge the condition of the engine, an oil pressure test done with a mechanical gauge to measure the oil pressure to determine the condition of the bearings as excessive bearing clearance will overload the weak oil rings and that will also cause smoke out the exhaust
you have not mentioned the mileage done by the motor but as it is 2008 model and calculating the average mileage covered for that year vehicle I am thinking that the motor may be a bit worn
however the suggested tests done by an accredited service shop will give fairly good results to determine the next move
Jul 23, 2015 | Ford Cars & Trucks
Car has excessive oil consumption
Manufacturer specs specify one quart for every 3,000 miles. How much is yours using? Engine braking can make that amount go up as well due to the fact that your engine is producing it's highest amount of vacuum during engine braking.
Mar 09, 2015 | 2013 Subaru XV Crosstrek
When starting toyota fortuner 3.0 liter blowing blue smoke what is causing this
It is oil smoke. The most common causes are worn valve guide seals, a faulty PCV valve, or, worn or broken oil control rings on the pistons. Only 1 or 2 cylinders need be at fault.
Check the PCV valve for fouling. Have a compression test done. If readings are low or irregular, pour a few ccs of engine oil into the suspect cylinders thru the plug holes. If compression readings then improve, it is probably the rings at fault.
Less common causes are worn big end bearings spraying excessive oil up the cylinder walls, or a leak from the head gasket, oil to cylinder.
Apr 30, 2014 | 2004 Toyota Camry
Abnormal exhaust smoke
definitely an oil consumption problem. How many miles? Could be worn rings and or valve guides. The oil light on when hot indicates low level or possible or weak oil pump. Check compression for possible head gasket or cracked head. I wouldn't drive it untill diagnosed.
Mar 14, 2014 | 1996 Audi A4
My 2001 xj cherokee TD blows excessive smoke when the engine is under pressure.
Sounds like a broken oil ring. As far as the engine stalling, if your really low on oil the motor will shut down so as not to damage any bearings and other internal parts. Does the engine seem to be turning over faster and taking longer to start than usual and take a little longer to stop when you turn the engine off. If so you could have an issue with the compression rings in one or more cylinders. Do a compression test. If the #s are near where they should be it's likley oil rings. If the #s are low it's likley the compression rings. Either way if its one of those issues you'll need to overhaul your engine
Jan 17, 2014 | Cars & Trucks
Oil blowing muffler
If the oil smoke is only at start-up, it is due to worn valve seals and/or valve guides. If it stops in less than 40 seconds, this is normal wear. If the smoke persists longer, a valve service is required.
If your engine is burning oil continuously, it can be due to the following: 1. The crankcase is over-filled with oil. 2. Excessive wear on valve guides/seals. 3. Piston rings/cylinder excessive wear or damage. 4. Oil contaminated with gas due to defective/dirty carburetor inlet valve or damaged float.
Solution1. Check oil level. If the oil level is high, check if is is watery and has a strong gas odor. If so, drain completely, refill, install new oil filter and service carburetor.2. Perform compression test. While every engine is different, 80-100 PSI is acceptable. If it is lower, add about 1 ounce of oil into the cylinder and retest. If compression increases significantly, the rings are worn. Hone cylinder and replace rings.
May 06, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have the Cub Cadet CC4125. The head for the line is very wasteful.Line will not stay in the spool. I also have Toro with the spool type head on it,and this is more efficicnt. Does Cub Cadet have a spool...
If the head is shot, go to Home Depot and in the garden center, you will find many replacement type heads. They may have one that will fit your machine, because they carry universal replacement string heads. Check them out because they are cheaper than the small engine repair shop.
May 26, 2011 | Garden
I have a Cub Cadet cc4125 string trimmer not starting
need a little more information .. but look for the following .. take out the spark plug and look inside with a flashlight ... if the piston is moving with the rotation of the flywheel then you likely have a blown head gasket .. if there is no compression there wont be a load on the pull cord .. a cracked or damaged piston can also do this .. ... if the piston is not moving when you rotate the flywheel then you likely have a bad "shear key" sometimes called a "shear pin" .. thats usually a half moon shaped small metal part that keeps the flywheel locked rotationally to the crankshaft .. it is designed to shear off if there is an excessive sudden load on the engine .. the flywheel will then spin without turning the crankshaft .. the same thing will happen if you have broken the connecting rod .. (a rod failure is often preceded by lots of clatter from the engine) .. the head gasket or shear key are much more likely to be your problem .. if you cant see in the spark plug hole you might try using a straw to feel the piston motion .. its possible that without the spark plug in place the piston might move even with a bad shear pin .. because with no compression the piston will move freely .. if thats the case you can stop the piston motion with a wood dowell thru the spark plug hole .. if it moves in spite of your dowell resistance then consider the head gasket option ..
Sep 19, 2009 | Garden
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
303 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
