Question about Mi T M WP-3000-4MHB Pressure Washer
What oil do i use in the pump? The oil is milky and needs changing.
  • 760 Answers
Well you can use direct recommended from Ace Hardware see link.
http://www.acehardware.com/product/index.jsp?productId=1340266
They recommend 250 hours, but i'd change more often, like you said when it's milky. If it begins to get water in the oil sooner, that indicates your piston to crankcase seal is beginning to leak.
Posted on Jul 04, 2010
If oil in pressure washer is milky colored will it hurt pump to run till oil change
Milky appearance in oil is due to water mixing with the lubricant. An internal seal has failed. Have your pressure washer checked by a small-engine mechanic immediately.
Apr 13, 2018 | Garden
My car was running hot so changed the water pump and spark plugs and now car is still running hot and my motor oil is milky looking and smells like gas
You have a blown head gasket ! The milky looking oil is coolant getting in there ! Mite smell like gas because some of that is getting in there also ! It over heated ,warped a cylinder head ! Milky oil How to tell if your oil is milky
Sep 14, 2015 | Cars & Trucks
G2500vh engine problems
Hi Derek.
It is almost impossible for the engine oil to become "milky" under normal circumstances. If you have changed the oil and have used the wrong type, it may become aerated and appear milky. The only other way for water to be added to the sump is through the oil filler. I doubt this is the case as it is a neglect thing and indicates that someone has run the machine without the oil filler caps. Hopefully this is not the case, but as the engine has a low oil level sensor, it might be the reason why it wont start. It's a safety device.
There is no way that the engine oil can be contaminated by water from the pressure pump.
If you mean that the water pump oil is milky, this means that the seals have failed between the pump and the transmission. Difficult to check in a G2500. If this is the case the machine has probably been used beyond the manufacturer's intent and has overheated.
Nov 12, 2013 | Karcher Garden
I have a 2004 dodge intrepid 2.7 today the oil light came on when I open the oil cap I seen milky color so I decided to change oil and it was thin and milky and also drained about 2 gallons from oil drain...
have a coolant system pressure test done as there may be corrosion behind the water pump impellor that is letting water out into the sump. Check all aluminium fittings that connect to the oil system for corrosion
Oct 27, 2013 | Cars & Trucks
The royal star I just got has a milky look to it, the cyclebarn mech. said that it was just condisation(sp) and to run it about 500 miles and change the oil, and filter!!!!
The better thing would be to change the oil and filter now. Why wait to lessen the problem. Yes, it is water that is turning the oil a milky color. The real question is whether the water is just condensation or is it a water leak at the internal water pump. I'll bet this is the first time you ever prayed for condensation. Best wishes. Please rate my answer. Thanks.
Jul 01, 2011 | 2005 Yamaha Royal Star Tour Deluxe
Oil milky white in pump
it may have a slow water leak inside the pump.
change oil and monitor the new oil.
if it goes milky the next time you use it then it has a bad leak and the seals will need to be
replaced,otherwise the bearings will rust & seize
Dec 18, 2010 | Honda Pressure Washer PSI 3000
Milky oil leaking from left side caseing?
If water gets inside the gearbox, it will emulsify due to the "blending" caused by the gears and crankshaft. It turns the oil a milky color. The water can come from a bad oil seal on the water pump (if the bike is water cooled), or from condensation inside the gearbox. Sitting out in the rain, pressure washing or riding in creek beds can also be the water source. Find the water source and fix the seal or otherwise remedy the exposure. You will need to do an oil change. Please rate my answer. Thanks.
Sep 13, 2010 | Honda NSR 125 R Motorcycles
Milky oil on my wr450f 2004
your water pump seal and oil seal have failed on the water pump shaft. Replace both seals noting which way the seals face. replace the water pump shaft if it is scored. Chaz- Moto DC
Jan 20, 2010 | 2004 Yamaha WR 450 F
Water pump leaked coolant into oil is motor done or can i just replace pump
It should be OK after a few oil changes. I would keep a close eye on the oil to make sure it isn't turning milky or foamy. If it starts knocking, you may have a more serious problem.
Apr 12, 2009 | 2001 Chrysler Sebring
Mi T M WP-3000-4MHB Pressure Washer Logo
480 people viewed this question
Top Mi T M Garden Experts
JOHN LAPIER
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
