Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
How do I know if my heater is set for 120 vs 240
Raypak Rp2100. How do I know if my heater is set for 120 vs 240 volts wiring?
  • 760 Answers
I think the only thing powered its the transformer. You connect L1 to Black and white to W and leave the red empty. If it's 120V and you connect L1 to Black and L2 to Red if it's 240V and leave W empty. See attched link to manual, and schematic inside. http://www.raypak.com/uploads/6000.52AG.pdf
Posted on Jul 04, 2010
My Raypak RP2100 has a Low Voltage message on the display. what might be wrong?
if this is a new heater check wiring if connected up 120 volts you have to change wiring to the ignitor and transformer check inside the front panel
Sep 30, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Raypack pool heater trouble codes
check flame sensor if wired 120 volt see wiring on inside of panel
Jun 22, 2014 | Raypak Rp2100 Digital 336k Btu Propane...
Raypax 2100 pool heater will not stay lit?
dirty or bad flame sensor if wired 120 volt try reversing black and white wire
Sep 01, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
New Versa 130 won't stay lit
if wired 120 volt then make sure wired correctly they come wired for 220 volt if 120 volt have to change wires if wired correctly change black and white its not rectifing
May 18, 2012 | Raypak Pool & Spa
System clicks off while in demand
make sure wiring is correct if 120 have to rewire or switch black and white wires after checking wiring
May 18, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
No power seems to be getting to the heater (raypak 2100) no lights on the control panel and system not heating. all power checked and working.
check the tranformers primary and secondary sides..... should get either 120 or 240 on primary side......24 volts on secondary side
Sep 21, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
165 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
