Question about Health & Beauty
Which is the commercial reference (not the number of part IEC) of the Q1 of the control board of (assy 44465) of centrifuge GP8R IEC?
  • nguerrero6 Jul 05, 2010
    It wanted to obtain a concise response it brings over of my question and I need urgently the help of an expert who could find out the commercial reference or a reference of replacement of the component Q1 of the board controller (assy 44465)of centrifuges GP8R brand IEC.
    Thank you for the help. The response was completely satisfactory.
    Nelson.
  • 2,272 Answers
Control Board Reference:-- The exact commercial reference for the Q1 of the control board is  Q1 :---2N7000-------- For Q2, Q3, Q4, Q5, Q6, Q10 :-----------IRFZ46n.
Reference Part
C1, C9, C19, C20 NIC NRSA 100 M 35V 5X11 TR
C2, C4, C6, C7, C8, C10, C18 NIC NCMA10 Z5U 103 M 100 TR
C3, C14, C16, C17 NIC NCMA30 Z5U 105 M 50 TR
C5 NIC NCMA20 Z5U 104 M 50 TR
C11 NIC NRSA 222 50V 18X36 TR
C12 NIC NRSA 101 50V 8X11.5 TR
C13 NIC NRSA 330 35V 5X11 TR
C15 CAP NOT NEEDED
C21 NIC NRM 105 K 100
CAP1, CAP2 EXT
CLIM1 MELEXIS US5881UA NONLATCHED
HALL SENSOR
CR1, CR2, CR3 P6KE15CA
CR4 1N5240B
CR5, CR6, CR7, CR8, CR9, CR10, CR11, CR12, CR13 DIODE UF4002
D1 GBPC2501W
F1 REAR PANEL FUSE 2 AMP
IEC INPUT CONN1 REAR PANEL LINE CONN.
L1 5 TURNS ON TORROID
LED1 FRONT PANEL LED
LID SAFTY SW1 LID SAFTY SW.
LID SW1 FRONT PANEL LID OPEN SW.
MOTOR1, PANEL1, POWER1 MOLEX 26-48-1086
PULSE1 FRONT PANEL PULSE SW.
Q1 2N7000
Q2, Q3, Q4, Q5, Q6, Q10 IRFZ46n
Q7 TECOR S2015L
Q8, Q9 IRFZ34N
R1, R19, R29 4.7K 1/4W 5%
R2 470 OHM 1/4W 5%
R3, R4, R9, R11 10K 1/4W 5%
R5 390 OHM 1/4W 5%
R6 47K 1/4W 5%
R7, R26, R28 100K 1/4W 5%
R8 1MEG 1/4W 5%
R10 2.2 MEG 1/4W 5%
R12 39K 1/4W 5%
R13 NOT USED
R14, R24 1.5K 1/4W 5%
R15 1K 1/4W 5%
R16, R17 3006P-102 BOURNS
R18 180K 1/4W 5%
R20, R30 3.3K 1/4W 5%
R21 2K 1/4W 5%
R22 200 OHM 1/4W 5%
R23 820 OHM 1/4W 5%
R25 1 OHM 10W 5%
R27 68K 1/4W 5%
R31 82 OHM 1/4W 5%
R32 82 OHM 1/4W 5%
R33 130 OHM 1W
RP1 BUSSBOURNS 4605-101-102
RP2 BOURNS 4604-101-103
RP3 BOURNS 4606-102-681
RP4 BOURNS 4604-101-272
-------------- Reference Part SAFTY1 :-HEADER 4 PIN NOT USED SOLENOID1: LID OPEN SOLENOID 24 VAC SPEED1 :FRONT PANEL POT 100K T1 :TRANSFORMER TIMER1 :FRONT PANEL TIMER SW. U1 :ATF16V8BQL-25PC U2 :LM7815T U3 LM339CN U4 LM7805T U5 ULN2003N U6 LM555CN U7 MOC3010 U8 MAX954EPA U9 CD4093BCN WH1, WH2, WH3, WH4 PAD
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 05, 2010
    thanks for your help, I am satisfied with your answer. I hope continue working with you for future questions.
    Nelson
    Guru:
  • 468 Answers
I am not an expert on it or in simple words I have no idea what you meant? but I have foudn this link for you, hope you will get your answer
http://labsurplus.com/used/1cen.html
Posted on Jul 04, 2010
WHAT TYPE OF TRANSISTOR Q1 ON THE BOARD NEXT TO THE SYSTEM CONNECTOR
Your best bet is to contact Vestax Support directly. Their USA phone number is 1(888)498-4788 Mon-Fri 10am-5pm PST
Feb 05, 2015 | Vestax Vci 100 Midi Controller
Why do my brake lights stay on when the car is off?
Bad swiitch or short in wiring. Your brake lights will work with the car off when you press the brake pedal.
Oct 18, 2014 | IEC BRAKE SWITCH ASSEMBLY Part for...
Service manual
Try this... I've found a few sources online but most require membership in their particular user forums. This pdf is the operation manual, but it has a fairly comprehensive maintenance section that I believe may contain what you need.
https://www.artisantg.com/info/PDF__546865726D6F5F49454343656E747261475038525F4D616E75616C.pdf
Dec 03, 2013 | IEC Centra-GP8R Centrifuge, Table Top
Brake switch location
were is the brake light switch on a 04 work hours chassis
Feb 15, 2013 | IEC BRAKE SWITCH ASSEMBLY Part for...
Power board part number
It's unclear which board you are referring to, so I'll include the likely two.
Parts 4120-6201-05 and 4120-6202-05 are both labelled "Power Supply (PU1)". I believe this is likely the board you are referring to. It is the small orange board in the top-back of the printer. It is unclear why there are two part numbers for it. However, I suspect they may both be for the same type of board with one containing optional, upgraded components.
Part 4120-0109-04 is labelled "PWB Assy (PWB-A)". I am assuming this means power board assembly. It is the small board in the back of the printer, in the lower-left (looking at it from the back). This does not look like it would be called a power board. It looks more like a logic board.
Jun 06, 2009 | Minolta magicolor 2200 DeskLaser Printer
Amana sxde25j high voltage board blown..
hi there,
you can try to this store to order the parts to be replaced part number & description was also indicated in HERE.
just let me know, for further assistance,
Apr 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
MAH5500BWW, serial number 73913001ZS CONTROL BOARD
that part no longer availabe separatly, you need to pruchase a "neptune repair kit" which consitst of the motor controller, and new motor assy. part number 12002039... i know sears sells, dont know about the shipping
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Health & Beauty Logo
65 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
