Question about CP International WAP-0006 (WAP0006) 802.11b/g Wireless Access Point
Web configuration dows not work after reset
After reset the wap-0006 looses the options in drop-down lists.
On the first try i configured the Mode to "AP" and changed the ip address.
But later i planned to try "Universal Repeter" mode but after resetting the box the web configuration program changed and no options are now visible in the drop-down list for "Mode", it looks like the device has lost all memory of the available options.
    Scholar:
  • 143 Answers
Perhaps you have to search for an upgrade to the WAPs firmware. The manufacturer may have a page in the web config that allows it to search for an updated firmware. If not, you should be able get one from the manufacturers website and apply it yourself from the download. The web config program should have an option to do so.
Posted on May 13, 2008
I cant reset password for my dlink 1155..dlinkap
Hello visit the homepage:
http://www.dlink.com/us/en/support
And download a user manual.
Or:
Resetting your D-Link router's Wi-Fi password is easy:
  • Type your router's IP address -192.168.0.1- into your Web browser.
  • At the login screen, select "Admin" from the drop down menu and enter your admin password.
  • Once you access the Web configuration screen, click "Setup" in the top menu.
  • Select the "Wireless Settings" link on the left-hand side.
  • From there, click on the "Manual Wireless Connection Setup" button.
  • Scroll down to the field representing my "Pre-Shared Key". If you don't see it, select a security mode from the dropdown menu at the bottom of the screen first.
  • Type in a new password. (I use a hybrid WPA/WPA2 security mode.)
The Forgotten Admin Password
If you forget your Web configuration password, you're stuck: you have no way to change any settings on your router. Your only recourse is to use a paperclip or other pointy object to reset your router to its factory settings. With the
paperclip, hold down the tiny reset button on the back of your router for about five seconds. Your router lights will blink to confirm the factory reset. You can now use the router's default password to log into its Web configuration screen (look in your router manual if you can't remember what this is). Once you're in, be sure to change this password to something unique.
Remember to save your settings when your done.
Good luck
Nov 24, 2012 | Computers & Internet
Router
Or:
Good luck
Nov 24, 2012 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
Jun 04, 2011 | Quintum Tenor DX2060 (501-0122-00)...
Send me sumsung champ all secret codes ....??? m nt getting exact codes pls help me soon
General Diagnostics: * *#0*# - LCD Test Menu. * *#06# - Show the IMEI number. * *#367# - DB Profile Setting Menu. * *#1234# - Displays the Firmware Version * *#9324# - Phone Monitor. Press up and down to display more. * *#0228# or *#9998*228# - (BAT) Battery statistics. Press up and down to display more. * *#0289# or *#9998*289# - (BUZ) Buzzer test. * *#0638# or *#9998*638# - (NET) SIM network ID. * *#0746# or *#9998*746# - (SIM) SIM Information. * *#0778# or *#9998*778# - (SST) SIM Service Table. Press up and down to display more. * *#0782# or *#9998*782# - (RTC) Real Time Clock Display. Press the "#" key to refresh * *#0842# or *#9998*842# - (VIB) ******** test. * *#1111# or *#9998*1111# - Displays the Software Version. * *#1234# - Displays the Firmware Version. * *#2222# or *#9998*2222# - Displays the Hardware Version. * *#4357# or *#9998*4357# - (HELP) Code help screen. Press up and down to display more. * *#4777*8665# - GPRS Test and Configuration Menu. * *#5002*8376263# - Additional handset information. Press up and down to display more. * *#9998*76# - (PN) Production Number. * *#9998*377# - (ERR) NVM error log. Press up and down to display more. * *#9998*667# - (MMS) MMS Debug. * *#9998*968# - Yamaha test. * *#9998*982# - Edit IM settings * *#9998*2576# - (BRKN) SIM Error. * *#9998*3323# - (DEAD) Forced Crash. * *#9998*5282# - (JAVA) Java Profile Menu. The "Install MIDlet" password is "235282′ * *#9998*5646# - (LOGO) GSM Logo set. Press up and down to set.
WAP Configuration: * *#82# - Display WAP User Agent. * *#92782# - Edit the WAP User Agent. Default setting is "SEC-SGHD807/1.0 TSS/2.5′ * *#827# - Display WAP UA Profile. * *#927827# - Edit WAP UA Profile. Default is setting "http://wap.samsungmobile.com/uaprof/d807_10.xml"\
Digital Audio Interference: * *#3243948# - Digital Audio Interference (DAI) OFF (Resets Phone) * *#32436837# - Digital Audio Interference (DAI) ON
Bluetooth Configuration: * #*3888# - Bluetooth test mode * *#232337# - Displays Current Bluetooth MAC address * *#7263232337# - Changes Bluetooth MAC address. A random number is chosen and you will lose all your previous bluetooth connections. Use with caution!
Reset Codes: Data in the phone will be deleted! * *2767*3855# - Full reset * *2767*2878# - CUST reset * *2767*927# - WAP reset * *2767*667# - MMS reset * *2767*36245# - Email reset
Feb 28, 2011 | Cell Phones
COMPUTER WAS TURNED OFF IMPROPERLY. TURN-ON WAS IN SAFE MODE NOW EVERYTHING IS LARGER AND BLURRED
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
always click APPLY after making any changes
don
Feb 02, 2011 | Computers & Internet
There is about 3/8 of an inch of the desktop shown on the bottom of screen when in full display . Resolution is correct. I uninstalled Open Office 3.1 with Revo Uninstaller about an hour ago and it has...
control panel,display,desktop you can select a different desktop from the drop down list also settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
hope this helps
Jan 05, 2011 | Computers & Internet
AIRTEL GPRS settings for HTC Touch P3452
THIS SHOULD HELP U......
On Windows Mobile 6.x, the steps to configure are as follows:
1. Activate Airtel Live by sending the following SMS to 121: MASALA ACTIVE.
2. The service takes atleast 3-4 hours to get active. Restart the phone and resume configuring.
3. Tap Start -> Settings.
4. Select Connections Tab and tap Connections.
5. Select Advanced Tab, tap Select Networks button to bring up Network Management.
6. Under "Programs that automatically connect to the Internet should connect using:" drop down, tap the New button.
7. In the General Tab, type the name of the settings as Airtel Live
8. Select Modem tab, tap New...
9. Type the name of connection as Airtel Live, select the modem as Cellular Line (GPRS) and tap Next.
10. Type Access Point Name as airtelfun.com and tap next.
11. Leave username, password and domain blank and tap finish.
12. Select Proxy Settings tab. Tap "This network connects to the Internet". This should enable the next check box option.
13. Tap "This network uses a proxy server to connect to the Internet".
14. Type the proxy server as: 100.1.200.99 and then tap Advanced...
15. Tap HTTP, leave the server as 100.1.200.99 and change the port to 8080
16. Similarly tap WAP, Secure WAP and Socks, type the server as 100.1.200.99 but leave the port to defaults. These are optional settings.
17. Tap OK to close the Advanced proxy setup screen.
18. Tap OK to close the New connection screen.
19. The network management screen should now list the new connection you have created in the drop-down. Tap OK to close this screen
20. Tap OK to close the connection screen.
Now you are ready to fire your favourite browser. I have tested this on PIE as well as Opera 9.5 and it works for me.
If PIE reports "Request not authorized by the WAP Gateway", you will need to change the user-agent to anything you can think of using "Advanced Config" tool (thanks to dsixda for suggesting this). I had set it to HTCP3452_Mozilla/4.0 under Advanced Config -> Internet Explorer -> User Agent Custom Base.
I think Airtel has intentionally blocked Mozilla/4.0 user-agent on WM phones. It may be that they cannot restrict Windows Mobile based phones from accessing websites on standard HTTP. On other phones I had tried, I could not get other sites to work with the same settings.
Enjoy Airtel Live for free.
Mar 23, 2009 | HTC Touch P3452 Smartphone
Resetting fulbond wireless AP
problem solved when im using access point manager to accessed my wap.
the default password is "default". for unknown reason the wap seems cant be access thru http, even i enter the right password. the http page tell me that the password is wrong. But when i used access point manager from www.teletronics.com i can log in to the wap and configure it using the same password that i used on the http page.till now still dont know what's wrong with the wap.
since it's working fine im not trying to find out anymore.
the default password is working too on telnet and others but it still dont work on http page and i dont
see any configuration that restricted access to the wap thru http access.
Nov 21, 2008 | Arris WA840G 802.11g/b (49832000100)...
Linksys wrt54gs
ok do one thing at first remove the power adapter from the router and put in at same time when you put in the power adapter cable at that time you have to press the reset button give in the back side of the router you have to do at least press the button upto five sec. after then you have to configure agian your router .
after configuration your router then go to the wireless option in ther enable the the wireless secutiy. and one option is there in wireless secutiy in that the wep,wap, wep+wap keys is there .enable the wep key and protect your router.
Jun 24, 2008 | Computers & Internet
Samsung U600- WAP and MMS settings for T-Mobile
I have had a similar problem when I first got my unlocked phone. I have T-mobile as well, and once they find out you have a phone device not purchased by them, they are not very helpful - they will give you their default mms settings(same ones listed on their site). I tried those settings and they did not work on the particular unlocked phone I had. I did some extensive web searching and came across a few settings that worked with my phone. I will list them here. Hope they work for you!
*MMS Settings: Home URL - http://216.155.174.84/servlets/mms
*Protocol Type - WAP
*WAP IP Address - 216.155.165.50
*GPRS Access Point - wap.voicestream.com
*GPRS Username - Leave Blank
*GPRS Password - Leave Blank
*Authentication Type - normal
*T Zones - http://wap.myvoicestream.com
Nov 03, 2007 | Samsung Cell Phones
CP International WAP-0006 (WAP0006) 802.11b/g Wireless Access Point Logo
226 people viewed this question
Top CP International Computers & Internet Experts
David Payne
David Payne
Are you a CP International Computer and Internet Expert? Answer questions, earn points and help others
