Question about Raytheon VHF 53 CB Radio
I have a Raytheon Model 210 Radio for my boat. The saddle that holds the Mic. Broke. Part no G623759-2 Is there some where you can buy the part. ray Marine said it is discontinued.
Raytheon R21XX/R41XX Radar home use or testing ? boat,ship radar
That model is meant for marine (boat) use. You can pre-test it anywhere as long as you are providing the proper power source. It's meant for 12vdc. If you have a marine battery, or a car battery handy, just power it up from that. You do not want to plug it in to household current, you would fry it in a matter of seconds. I would suggest hooking it up to the power 12v outlet in your car of truck to test it.
Jun 08, 2014 | Raytheon Radio Communications
Gentlemen: I have a vintage 1997 Raytheon marine VHF radio on my 1997 Pursuit, not sure of model number as boat is in storage, but it is pretty basic, along with a full slate of Raytheon electronics of...
Hi Jim
Your VHF lives in a fairly harsh marine environment and you're correct in thinking "tuner cleaner" might be the answer. I believe that your volume control is simply dirty. I would suggest using silicone spray (WARNING- Use ONLY the safe for plastics type.) to clean it. I've had good success just removing the control knob and blasting the pot, working it back and forth. You MIGHT wish to do this with the power off however, unless you have a great set of earplugs.
You mentioned that you have a handheld VHFas well. Any chandlery will carry an adapter (about $10) to let you hook your portable to the big antenna should a problem with your marine VHF arise. We've had the occasion once to have to do this and we were glad we carry the handheld aboard at all times.
Cheers!
Apr 12, 2011 | Raymarine Ray218 Marine Vhf Radio E43032
Need a mike holder for my ray 53 vhf
Go to the Nearest Truck Stop they have many types of Mic holders i am sure one will work for you.
Aug 21, 2010 | Raytheon VHF 53 CB Radio
Have power to my Ray53 DSC VHF on my boat but no sound
Sounds like a bad speaker. Try plugging in an external one and see if that works if so replace the bad speaker.
Jul 29, 2010 | Raytheon VHF 53 CB Radio
I need a power connector for a Ray 53 radio. It
first off for the metal mounts
http://www.cwrelectronics.com/product.php?id=11552
http://www.kenselectronics.com/lists/pwrcord.htm
Dec 12, 2009 | Raytheon VHF 53 CB Radio
Receiver works fine, but nothing out mike, either hailer or transmitter functions. How do I troubleshoot the mic?
make sure that you havent pulled one of the wires loose inside.. it is pretty easy to do.. I did it myself and didnt realize it until i had the same problem.. check where the mic. plugs into the radio first, if that is okay then it may be in your mic itself.. what kind of mic do you have it hooked up to
Jun 23, 2009 | Raytheon VHF 53 CB Radio
Nothing comes out of speaker
does the remote/extention speaker work?
if yes , your internal speaker is faulty > replace it
If no , the external speaker socket is faulty > replace it
May 25, 2008 | Raytheon VHF 53 CB Radio
Help need a new mic
I tried to locate one for you on eBay, but had no luck. You best bet would be to go to the Raymarine website, and find a local dealer or contact Raymarine directly. Here is a direct link to their customer support page:
http://www.raymarine.com/Default.aspx?site=1&section=3
I hope this helps, if you need anymore assistance, please dont hessitate to reply here or email me at:
rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Mt. Vernon, TX
May 21, 2008 | Raytheon VHF 53 CB Radio
Raytheon VHF 53 CB Radio Logo
296 people viewed this question
Top Raytheon Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Raytheon Radio Communication Expert? Answer questions, earn points and help others
