Question about LG 22.4 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Smooth Black
Blown Fuse I have a blown fuse on the back electrical panel. How can I remove the fuse?
  • 53 Answers
Find the main braker to the house. Pull it out, or flip it off. It's probubly right above the fuse. Plug some thing in several outlets, to make sure all power is off. Then use a pare of needle nose pliers, to get the fuse out. Make sure all power is turned off to the house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jul 04, 2010
Brake light issue
I believe it deserves mention here that about 98% of all brake light malfunctions do not have anything to do with a blown fuse. In fact, fuses are NOT the CAUSE of electrical circuit malfunctions at all. Electrical circuit malfunctions cause fuses to blow. It is very important when diagnosing electrical circuits, that you understand this basic "cause and effect", so you do not waste time and effort looking for the wrong source of the problem. If there is a blown fuse involved in your brake light problem, you need to find out WHY. Simply replacing a blown fuse will not fix the problem that caused the fuse to blow and will only result in another blown fuse.
With that said, the fuse that protects your brake lamp circuits is Fuse 6B (20 Amp) in the instrument panel fuse block.
HINT: This fuse also protects your hazzard flasher circuits. If these work (front or rear or both) the fuse is not blown.
Jun 02, 2012 | 1994 Buick LeSabre
What can cause a no power condition to ac compresor on 1996 Lincoln town car?
Instructions1 See if the problem is as simple as a blown fuse. It is probably a blown fuse if the temperature controls on the dashboard seem to work correctly but have no effect on the air. The fuse box in a Lincoln Navigator is located by the brake on the left lower side of the steering wheel. Pry off the fuse panel cover and find the blown fuse.
2 Have a look at the control panel next, if the controls are not working at all. First disconnect the negative battery cable. Detach the shift lever cover, and then the electrical connector. Unscrew the screws holding the trim cover on the shift panel. Disengage the four clips to pull the trim panel off.
3 Unplug the electrical connectors, remove four more screws, open the audio unit cover the whole way, disengage the clips in each corner and remove the climate control panel.
4 Listen for the blower motor to be properly working while the engine is running with the air conditioning controls turned to high. Adjust them from low to high to make sure the blower motor noise increases and decrease accordingly.
5 Find the blower motor in a Lincoln Navigator underneath the passenger side lower trim panel. Push the carpet back. Unplug the electrical connection from the blower motor, remove four screws and pull the motor out.
Thanks
Apr 02, 2012 | 1996 Lincoln Town Car
My fuse blew in my Samsung 53" Plasma TV. I changed it, but it's blown again? What should I do next?
The fuse blown because theres a short circuit connection in the PCB power supply of your television.Please check the power supply inside,remove the back cover to see the power supply section.unplug first to avoid electric shock.Will you check the bridge type diode first.If the bridge type diode or diodes is shorted the fuse is always blown.Using digital tester check diodes,regulator transistor,and other transistor around the power supply.
Jul 16, 2011 | Televison & Video
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Over the range microwaveoven worked flawlessly then bang it quit.it looks like its been unpluged but no. I tested the electrica outlet and ther is power. Is there a reset button within the microwave that...
    you have a blown fuse.unplug the microwave. remove the vent by unscrewing the 2 screws holding it in place. gently pull vent grill forward to remove. open the door, and remove the screw holding the control panel in place. remove the metal plate being held in place by that screw. inside that panel is your blown fuse. remove the fuse and replace. reassemble the microwave. plug it back in.
    Feb 08, 2011 | Panasonic Microwave Ovens
    Hello, I think the fuse has blown in my series 80, Kenmore electric dryer. Can you please tell me what it looks like and the location of it. Thank you.
    It's a thermal fuse and it is white plastic about an inch and a half long. has 2 wires going to it,usually lt.blue, If you remove the back panel of the dryer it is located near the dryer exhaust above the high limit thermostat.
    If the thermal fuse is blown the dryer will not run.
    Hope this helps.
    Dec 11, 2010 | Kenmore 62802 Electric Dryer
    DRYER STOPPED RUNNING. ALL CONTROLS WORK, BUT WON'T START. HIGH LIMIT SWITCH GONE?
    It's either of the thermal fuse on the blower housing or the thermal fuse on the heater enclosure is blown. These thermal fuses are wired in series with the motor and therefore, if any of them is blown will cause the motor not to run and hence the dryer not to work except the controls.
    Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
    Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
    Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
    Bypass the thermal fuse on the blower housing by disconnecting the wires and taping them together or connecting a jumper wire between them. Close the door then plug and start the dryer.
    The dryer should start and heat up if the blower housing thermal fuse is the culprit. Otherwise, the other thermal fuse on the heater enclosure is blown. Unplug the dryer then bypass the thermal fuse on the heater enclosure in the same way the first is bypassed to confirm it.
    Plug the dryer back then restart it. The dryer should start to confirm that the heater enclosure thermal fuse is blown. Replace the thermal fuse (part number 307473) together with the high-limit thermostat (part number 303396).
    Unplug the dryer and unbypass the blower housing thermal fuse then plug it back and restart it. If the dryer fails to restart, replace also the blower housing thermal fuse (part number 33001762) together with the cycling thermostat.
    Reinstall the front panel in reverse steps of the removal steps to complete the repair.
    Aug 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    1990 Plymouth laser. Where is starter relay located? I've already looked under radio panel where books say but not there.
    Fuses There are a number of fuse blocks on these vehicles. The multi-purpose fuse block is located inside the passenger compartment of the vehicle, under the instrument panel, towards the left of the steering column. The dedicated fuses are located in the engine compartment at the left rear corner (if equipped with A/C) and also in front of the right strut tower. Blade type fuses are used. A blade type fuse has test taps provided to allow checking of the fuse itself, without removing it from the fuse block. A test light can be used. The fuse is okay if the test light comes ON when its one test lead is connected to the test taps (one at a time) and the other lead is grounded. Change the position of the ignition switch so the fuse circuit being tested has voltage applied to it. Fig. 1: A test light can be used to test the fuse 89576g47.gif
    When a fuse is blown, there are two probable causes as follows: One is that the fuse was blown due to a flow of current exceeding its rating. The other is that it is blown due to a repeated ON/OFF current flowing through it. Which of the two causes is responsible can be easily determined by a visual check as described below:
    1. Fuse blown due to current exceeding rating: As seen in the illustration, a fuse that is blown due to an exceeding current has a section missing. If the blown fuse looks like this, do not replace the fuse with a new one hastily since a current heavy enough to blow the fuse had flowed through it. First, check the circuit for shorting and check for abnormal electrical parts. Only after the correction of such a shorting condition, the fuse is to be replaced with one of the same capacity. Never use a fuse of a larger capacity than the one blown. If such a fuse is used, electrical components or wiring can be damaged before the fuse blows in the event that an overcurrent occurs again. Fig. 2: View of a fuse blown due to overcurrent 89576g48.gif
      Fig. 3: State of a fuse blown due to thermal fatigue 89576g49.gif
    2. Fuse blown due to repeated current ON/OFF flow: The figure shows a fuse blown due to repeated current ON/OFF. Normally, this type of problem occurs after fairly long period of use and hence is less frequent than the above type. In this case, you may simply replace the fuse with a new fuse of the same capacity. Fig. 4: The lid on the fuse block in the engine compartment has the identification information 89576p40.jpg
      Fig. 5: Remove the fuse panel lid by unfastening the clips and pulling it up and off the panel 89576p02.jpg
      Fig. 6: Pull the suspect fuse up and out of its receptacle and check the element 89576p03.jpg
    Jun 25, 2010 | 1990 Plymouth Laser
    My spacemaker stopped working and no panel lights. It's not the circuit breaker. Any ideas? model JVM140001
    Could be the fuse inside the microwave is blown. You will need to unplug the microwave and remove the front control panel. Inisde the microwave housing you will need to trace the electrical wire coming into the unit. Usually you will find the in-line fuse located on the black power wire. You can pull the connectors off the fuse and test it with a continuity tester. If the fuse is blown replace it but make sure you use the same amp rated fuse as you removed. If the fuse blows again then there is an electrical short somewhere in the microwave.
    Dec 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    AFTER 12 MONTHS ON NO PROBLEMS IT WONT WORK. IT DOESNT GIVE ME DISPLAY LIGHTS OR ANY.
    most likely the internal fuse
    be soooooooooo carefull in replacing this , the capacitor inside the machine can store a huge charge
    1. Turn off all electricity to the microwave and unplug from the wall socket. Move the unit to a well-lit location to better see the appliance.
    2. Step 2 Usea schematic for the particular model of microwave being worked on tolocate the area containing the fuse to be replaced. Fuses can belocated behind the microwave door or behind a panel either on theinterior wall or an exterior panel. Often the fuse will be behind apanel located under the louver vents on top of the microwave.
    3. Step 3 Removethe panel according to the manufacturer's instructions. Use a screwdriver to remove screws and set aside for replacement.
    4. Step 4 Locatethe blown fuse and check with a voltmeter. This step ensures that theproblem with the microwave is indeed a blown fuse and not anotherissue. Check for current between fuse connectors.
    5. Step 5 Take the blown fuse to a local hardware or store such as Lowe's or Home Depot. Staff can assist in finding the exact replacement fuse for the model being repaired.
    6. Step 6 Placethe new fuse into the panel in exactly the same fashion as the blownfuse came out. Replace any panel using the removed screws and returnthe unit back to its proper location.
    7. Step 7 Plugthe microwave into the wall socket and turn on all electricity. Testthe unit by ensuring the clock and all other features function.
    Oct 21, 2009 | Emerson Microwave Ovens
    LG 22.4 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Smooth Black Logo
    111 people viewed this question
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
