Question about Whirlpool Duet GHW9150P Front Load Washer
Washer is not working
Whine start my washer it makes click click noise and "DL" signal is showing. It is happening sometimes then I un plug power and shake the machine and plug back start it works. But sometimes not.
  • 53 Answers
This code is for a door lock failure. it can also be a ccu problem as well. some have had luck hitting the back right corner of the machine forcefully to remedy this problem.
Posted on Jul 04, 2010
We have LG top load waveforce washer showing error code dL. At start there is a few seconds noise then error code appears. The washing cycle does not start. What is the problem and how do I fix it.
most likely a Door Lock error. means that the door lock is not working. fairly easy replacement if necessary. might check the lock first to make sure it has connector plugged into it. and that nothing is jammed inside of it. good repair videos at repairclinic.com and appliancepartspros.com or online at youtube.com
Oct 30, 2016 | LG Washing Machines
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
Toyota 4runner washer fluid does not come out
Open the hood and listen when some helper operated the "squirters".
You should hear a high-pitch whine that the washer pump makes.
No noise? Bad pump or bad wiring or corrosion at the terminals of the pump.
Noise heard?
Hoses are plugged up.OR the hose fell off the bottle and the bottle is empty.
You can use a small wire from a wire brush to un plug the squirt nozzles on the hood.Use pliers to feed the wire into the nozzles-you may poke your finger(sharp!).
Un plug the hoses that lead to the hood and apply air pressure to the hose from the windshield washer bottle.
Washer fluid is not toxic in small doses.
Feb 22, 2013 | Toyota 4Runner Cars & Trucks
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Laptop
Not uncommon... the power switching chip that regulates standby and other power regulation to the board must be faulty or fried. Must replace motherboard.. Try removing battery.. sometimes batteries will short or try to draw too much power and put the chip on the fritz..
best wishes.
www.techvisitor.com
Oct 29, 2008 | Computers & Internet
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Error codes
f dl refers to a bad door lock. do you hear a faint clicking noise when you try start the machine and after maybe 30 secs of clicking the" fdl "comes up???or perhaps the door makes the noise to lock but never does lock,in which case sounds like a bad latch assy.. although the fault for the door latch it could also be the CCU not energizing the door lock. try taking off the top of the unit by removing the 3 screws along the back of the top assy (they are torx 20 screws) form there youll see the main control board mounted to rear wall and if you look straight down the right front side youll see the wiring for the door lock itself. disconnect power to unit!!!!! first unplug and replug all the wire harness on the door latch and then also the pink wires on the module itself, maybe just a loose connection. try it now see what happens
Mar 17, 2008 | Whirlpool GHW9100L Front Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
130 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
