FixYa.com
Tags:
Camera Lenses
Generic problem for all Camera Lenses
Digital camera setting for Quantary eBox Studio...
posted by Wordworker on Apr 17, 2008
I have a Kodak digital camera and a Quantaray eBox Studio. For the life of me, I can't figure out which light source to set in my camera...or even where to set it. In P mode, I can go to White Balance and choose Auto, Daylight, Tungsten, Fluorescenty, or Open Shade...but whatever I've done with the camera, I can't seem to get true subject color.
Any suggestions?
Comment by Wordworker, posted on Apr 29, 2008
Thanks for the advice. But I just did a session with the camera on the P setting and White Balance set to tungsten, using the eBox lamps for a light source, and the colour came out true. Far crisper focus, too.
Thanks, again.
-Wordworker
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
jerryg50
Rank:Wiz Wiz
Rating: 84%, 523 votes
Not all light sources are absolutely accurate unless you are in profrofessonal studio conditions, and the lighting has been set up using colour and intensity references with proper metering.
I would suggest to use the camera in the auto mode for the colour ballance.
If the camera colour ballance is unacceptable when compared to another camera under the same conditions, then the camera obviously needs to be serviced.
Jerry G.
Rating Locked! (?) Wordworker has rated this solution as Thanks for Trying
This Problem Also Relates To: Sony 100mm f/2.8 Lens Panasonic 1/3 INCH C-S MOUNT 2.2MM,F-1.2, WIDE-ANGLE LENS (PLA22T3DN) Lens Converter Canon 75-300mm f/4-5.6 III USM EF Lens Canon EF 24-70mm f/2.8L USM Lens Canon EF 400mm f/4.0 USM Lens Canon EF 600mm f/4L Lens Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Can you Help with these Camera Lenses problems?
Camera Lenses
tamron adaptall
I have recently bought a tamron... Answer This...
Tamron 75-300mm f/4.0-5.6 LD Lens for Minolta...
How do you go from zoom to...
Hi I have model 672D and it... Answer This...
Kenko K15X-AFDGN 1.5X AF COMPATIBLE...
Kenko 1.5 extender Nikon, used...
had Nikon put on a new cover... Answer This...
Minolta 35~70 AF Zoom Lens CAMERA
Minolta 35-70 AF zoom lens...
My Minolta 35-70 AF f4 zoom... Answer This...
Schneider Macro 150mm f/9 G-Claron Lens with...
older schneider angulon 90 mm
my newer lens has a switch on... Answer This...
Repair Service
Find Camera Lense Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
