Question about MagLite Mag-Lite& Flashlight
Battery stuck in 3 AA battery Minimaglite
Well, other than banging the barrel on a piece of wood, does anyone have any OTHER way to get a battery out of a 3 AA minimaglite? This is a design flaw if you ask me, and I would NOT recommend these lights to anyone else, what good is it if you have to throw it away when the first set of batteries run out and are stuck in the barrel?
    Novelist:
  • 145 Answers
The battery has to make contact with the bulb as well as the end cap, so if you take the end cap off and the batteries don't come out that end I recommend pulling the bulb assembly apart and taking them out that end. And the next time you put batteries in coat the outside of them (not the terminals) with electrical grease (like you put on car batteries) to prevent them from sticking in there again. Note: if both ends are removed you can use something like a screw driver to push the batteries straight through and out the other end.
Posted on Jul 04, 2010
Woods 59744 battery operated in wall timer
59744 is not in-wall timer.
It fits over ordinary wall switch and uses AA or A battery to mechanically open and close switch
http://waterheatertimer.org/Woods-timers-and-manuals.html#59744
Gene
h
Nov 22, 2013 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Demo mode on hyper dash extreme
On box it States that it needs three AA
batteries required It has a demo battery installed on two of the six battery contacts Remove the black battery box or demo battery and install 3 AA batteries and it will function as normal
Dec 26, 2012 | Wild Planet Hyper Dash
Hello ! enyone knows if are a different batteries then AA type? tks
Sure, there are many types of batteries. The standard barrel shaped batteries come in
AAA
AA
C
D
The "button" type batteries are designated in different ways by their manufacturer.
Can I help you find a battery type on the Internet?
Jan 02, 2011 | Cameras
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
We are trying to get the ignition barrel out of a Ford Escort. 1996 model (R Registration). We has a small piece of wood stuck in the ignition and can not get it out. Please could you help?
you need to remove the cowl under the wheel,and drill the bolts out with a thin bit,then use an easyout to remove the 2 bolts.the barrel will then fall out.....how on earth did you get a bit of wood into the barrel?????
Sep 12, 2010 | Ford Escort Cars & Trucks
What battery is used for the Sheng Bang HD-1688 clock. It is an unusual size.
I do have a Clock with a Sheng Bang HD-1688 Clockwork. There is a normal AA 1.5V battery in it.
Kind regards Marcel van ****
Jan 31, 2010 | Hammacher Schlemmer Brian The Brain
How to get a battery out of a maglite.
both ends of your maglite unscrew.  Tap the stuck battery out with a piece of wood and spray in a bit of WD 40
Apr 05, 2009 | MagLite Mag-Lite& Largehead Flashlight
I have a mini Maglite with one battery stuck in the barrell
I had a similar problem. My wife put two AA rechargeable batteries into her mini maglite. Apparently the AA rechargeables have a slightly larger diameter than alkaline batteries. One of them was stuck in the barrel. I was able to remove it by first removing the lens and bulb so as not to break it. Then I slammed slamming the barrel down hard onto the carpet on our floor. This hard shock jarred the battery loose and it came out of the barrel. Hope this helps someone out.
Jan 15, 2009 | MagLite Mag-Lite& Flashlight
How do you change the bulb in a minimaglite
1. Unscrew the "bell" (top) of the flashlite. 2. Remove the bulb by pulling upward. 3. Replace with new bulb (be sure you have the correct bulb . . . it will have two small wires protruding from the bottom). 4. CAREFULLY insert new bulb through hole in the bottom of the reflector. 5. Screw the top of the flashlight back on.
Oct 22, 2008 | MagLite Camping, Backpacking & Hiking
MagLite Mag-Lite& Flashlight Logo
233 people viewed this question
Top MagLite Electrical Supplies Experts
ken skalski
Karl Kittsteiner
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
