Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Dryer start button doesn't work
Dryer start button doesn't start the dryer but you can hear the timer activating though only while you hold the button depressed
  • 53 Answers
Door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Posted on Jul 04, 2010
I have a Whirlpool dryer, model ler5644awo.When I set the timer and press the start button, you can hear the timer running but, the drum doesn't and the heating elements don't heat.could it be the...
Hello, welcome to FixYa.
Based on your post I understand you have a Whirlpool dryer that you stated "
set the timer and press the start button, you can hear the timer running but, the drum doesn't and the heating elements don't heat", correct ?
Having said that, by far and away the most common and the first thing I'd look for on these dryers is the fuse which is located on the blower housing, not likely the timer or start switch.
**Unplug the dryer from the wall before performing any service or removing any panels...safety first**
You can use the link below for a tutorial video to locate, test and replace the fuse that is specific to your model.
**please check the part with an ohm meter or "jump it out" (if you know how, if not, check the second link it will show you) before replacing it...the timer or start switch is possible, just not as likely as I mentioned**
http://www.youtube.com/watch?v=aUQQJAxkZ0g&feature=relmfu
http://www.youtube.com/watch?v=3nicyh6EUHc
Let me know if I can assist you in any other manner going forward and I'll be glad to do so.
If this info provided solves your problem, please take a second to accept my solution and rate it accordingly. Good luck and thank you for choosing FixYa today.
Regards,
Macmarkus :)
Oct 30, 2011 | Dryers
DRYER DOESN'T DO ANYTHING. I HEAR CLICKING IN THE TIMER AREA WHEN HOLDING THE START BUTTON DOWN AND NOTHING ELSE. IS THERE A WAY TO BYPASS THE TIMER TO MAKE SURE THAT'S THE ISSUE?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Maytag Dryers
My Dryer is a Maytag MGD5570, just under 4 years old. The dryer has power (light is on), but when I push the Start Button, nothing happens. I checked the Thermal Fuse with a continuity tester and it is not...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 03, 2011 | Maytag Dryers
Maytag Gas Dryer has power (light is on), but when I push the Start Button, nothing happens. The Dryer is a Maytag MGD5570, just under 4 years old. I checked the Thermal Fuse with a continuity tester and...
I had the same problem. Here's a quick test you need to do. It will take two individuals (unless you're extremely talented) Open the dryer door and push in the door switch... and hold it in. Have the other person push on (and hold) the start button on the console. At that same time everyone is pushing the switches take a free hand and reach into the dryer and try to spin it. Sometimes just a little push (assistance) is all it takes and..... bingo the dryer starts up! If that's the case... your motor is on its way out or it's gone. Usually due to the bearings on the motor being badly worn.
Feb 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
When dryer is started the timer can be heard and if the door switch is activated, the heating element will heat, but the drive motor does nothing. belt is ok
try holding the door button, have someone push the start button and you spin the tub at the same time. If it starts, it is most likely the start capacitor on the motor. If it does not start, look at door button, start switch/button, and lastly, the timer.
May 01, 2010 | Whirlpool ET8CHEXSQ Dryer
DRYER WONT START
HELLO THERE:
The most common problems with this problem is that there is a fuse that has blown in the dryer or that the door switch has failed and needs to be replaced or the timer switvch or the motor it'sef has went out (NOT LIKLEY) THOUGH
Or THE dryers push start button is faulty
so please check these things out and replace any parts that are found to be defective
Hope this is very helpful for you best regards Mike
Jan 09, 2010 | Whirlpool ET8CHEXSQ Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
387 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
