Question about SKYPE Lands Phones
When I try to sign in on the phone, the 7,8,and 9 keys don't work. I press 7, hoping to make an S and the 3 letters 7 can create don't show up as choices on the screen, as they do with the other numbers. Anywhere i can get skype repairs?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Reinstall your skype.
Posted on Jan 20, 2014
CORDLESSGURU
  • 106 Answers
SOURCE: Only shows the number 1
You have a short in your button assembly or a bad cpu. If it is not a spill or moisture from something like that you have some serious electrical problems. JennD has some different issues, physical damage it sounds like. Both sound like they need to go in for repair. You can google cordless telephone repair to find a solution unless your phones are nearly new and you want to try the warranty route. Good Luck, Guru
Posted on Feb 07, 2008
SOURCE: Uniden DSS7955
Dear FixYaTeam,
thank you, but I do not need help anymore. I have been able to get in touch with Uniden Service and was told to go:
menu
global setup
select
dial mode
select
select tone
select
It did work.
Regards
Zdena
Posted on Jul 07, 2008
SOURCE: GE dect 6.0 28300 'net in use'
I found the answer - I have two Skype DUal phones - I just disconnected from the mains power supply and then reconnected - FIXED - Enjoy
Steve
Posted on Nov 15, 2008
Muzzi_123
  • 749 Answers
SOURCE: Philips 321 voip phone, problem calling out with skype
some things to consider
Have you topped up credit on skype?
dialing code correct uk +44, mobile number +447958475236 ect?
if this does not work look in your manual and reset your phone and try again
regards
Muzzi_123
Posted on Apr 04, 2009
  • 33 Answers
SOURCE: I have a Samsung flip phone. My phone cannot make
go to the customer care center he will give you a new one its a product default
Posted on Sep 16, 2009
3 drives, and win7 can only find one drive
Hi
You give no specification information about either the drives (SATA or IDE) or the computer.
If the hard drives are IDE, look at the jumper settings and ensure that the Primary drive is set to Master, and the Secondary and Tertiary drives to Slave.
You don't say if the Win 7 is a recent upgrade and all 3 drives showed in the previous operating system or if all 3 drives showed previously in Win 7.
See if Win 7 can see all the drives and the status of your hard drives in Disk Management:
Start > (Category View) Control Panel > System & Maintenance > Administrative Tools > Create & Format Hard Disk Partitions > Disk Management
Without more background information, this sounds like BIOS settings issue.
Enter BIOS by tapping the appropriate key POST screen (usually DEL or F2) and look to see if the RAID or IDE/SATA configuration settings are correct and try different settings > F10 > Enter.
If none of these solve the problem, look internally and check your hard drive data and power connections (it is easy to work inside a computer and forget to reconnect hard drive cables). Try alternative SATA or IDE cables.
I hope this helps.
Aug 28, 2011 | Computers & Internet
How could i restart a g1>?
1) Turn Off the Phone
2) Remove Battery
3) Remove Sim Card
4) Put battery and sim card again
5) Turn On the phone
6) Press Menu
7) Factory Data Reset (Remember that: This action will reset the phone to its initial factory state, erasing all data and wonloaded applications, so BACKUP BACKUP BACKUP first you try this).
Press "reset phone"
HARD RESET
1) Turn off the Phone
2) Press HOME + POWER KEYS (keep them holding for about 25 secs)
until you see a screen with a phone and a triangle.
then
3) SLIDE YOUR KEYBOARD TO OPEN IT
4) press ALT + l ( TO SHOW YOU OPTIONS)
5) Press ALT + W ( TO FORMAT ALL DATA)
Note: When I write the sign + you don't have to press the + sign, it means that you need to press both keys @ the same time.
Note2: Don't do this if you don't have a Data Plan or your 2G or 3G is not working, why? because you will not be able to sign in again without a working Data Plan (2g / 3g).
Dec 18, 2010 | HTC G1
I am also trying to change the extension names but for some reason when I press program the only thing that shows up is "Program No?" what do i do next?
Start by pressing ** and see what the display shows. If it doesn't show anything but beeps, then you have the wrong phone. Try looking for extension 101 or the first phone in the system.
When you find that phone and press program **1234, you'll go into programming. Dial 004 and press ENTER. If you press ENTER again, you'll be looking at extension 101, or you can dial an extension and be looking at a name. Now you spell out the name on the keypad using the letters and the arrow key if necessary and press ENTER (the center of the Navigator button) to store the name. Notice that the 4th time you press a 3 letter ALPHA key, you will get lower case letters. Punctuation is under the 1, * and # keys and Q appears under the 1 and 7 keys :-)
Next steps you to the next extension and you can just pick up the handset and set it back down to end programming.
Carl
Oct 26, 2010 | Panasonic KX-T7633 Corded Phone
Change display names
A problem with answering this question is first that the main SYSTEM keeps this info not the handset, so for the 3x8, 6x16, and 8x24 systems you can do the following (PROVIDED, the installer did not change the passwords to access).
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Press: NEXT Display will read: "B. General Admin"
(NEXT is always the button on the right of your lines/extension list, 2nd button down from top.)
4. Press: SHOW Display will read: "1. Sys speed dial" (SHOW is one key up from NEXT)
5. Press: NEXT Display will read: "2. Names"
6. Press the SHOW Display will read: "Set names"
7. Press: SHOW Display will read: "Show set:__"
8. Enter the extension number of which you wish to change the name Display will read: "<##:name>"
9. Press the CHANGE softkey
10. Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
11. Press: NEXT (if you fail to do this step, the name will not be saved!!!)
12. Press the RLS key
I may be mistaken however I think you have to be on a model M7310, T7316, or M7324 phone (there should be at least one usually at the main desk) in order to program I don't think you can directly do it from the T7208.
Hope this helps.
May 04, 2010 | Nortel Business Series Terminal T7208 -...
My G1 screen goes blank when i close it
First try SOFT RESET
2) Remove Battery
3) Remove Sim Card
6) Press Menu
Press "reset phone"
IF STILL NOT WORKING TRY:HARD RESET
then
May 03, 2010 | HTC G1
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
I have the unlocking code for nokia 5800, how to type in handset
There is your unlock instructions for your Nokia Phone... Enjoy :)
***** DO NOT enter the unlock code more than 3 times on BB5 phones, if you do you will NEVER be able to unlock your phone by code *****
1) Power ON your phone
2) Type #PW+CODE+1# using your keyboard
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
3) The phone will show "SIM Restriction Off," in case it doesn't unlock the phone, you will have to replace step 2 but use 7 instead of 1
4) Device is now unlocked
*** IF THE CODE IS REJECTED, DO NOT TRY AGAIN. ***
Substitute the 1 at the end with 7.
So 2nd time try: #PW+YOURCODE+7#
ie. #pw+000000000000000+7#
The letter P appears after you quickly press 3 times the button star ( * )
The letter W appears after you quickly press 4 times the button star ( * )
The letter + appears after you quickly press 2 times the button star ( * )
The phone shows "SIM Restriction Off" and is unlocked!
May 31, 2009 | Nokia 5800 XpressMusic Smartphone
NORSTAR m7310
To Log Into System Programming:
Using the navigation keys, as displayed below, follow the next simple steps:
Press the RLS key
Hope this helps!
Jun 17, 2008 | NorStar Meridian M7310 Phone
Forgot my security code
ow to Enter Unlock Codes on Nokia phones:
Switch ON your phone without SIM Card
Compose #pw+yourcode+1# ("yourcode" is meant to be the actual unlock code we gave you)
ie. #pw+000000000000000+1#
IF YOU HAVE TRIED TO PUT IN AN INCORRECT CODE 3 OR MORE TIMES PREVIOUSLY & YOU GET PHONE RESTRICTED SIGN, THEN YOUR DEVICE IS HARD LOCKED AND MUST BE UNLOCKED WITH WITH A CABLE AND HARDWARE BOX.
Jan 23, 2008 | Nokia 6233 Cellular Phone
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
Lands Phones Logo
20 people viewed this question
Top SKYPE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a SKYPE Lands Phone Expert? Answer questions, earn points and help others
