Question about HP Photosmart 375 InkJet Printer
HP Photosmart 375 printer- error message "Cartridge failed"
HP Photosmart 375 printer- I am getting a message "Cartridge failed. please replace cartridge". Have tried 3 new cartridges and am getting the same repsonse every time. Have consulted HP website but they only refer to faulty cartridges- not sure it is the cartridge though as three faulty new units is a bit too coincidental (given they have been purchased from different outlets at different times). Thoughts would be appreciated
ctf1800
  • 4402 Answers
SOURCE: cartridge failed after replacing it wtwice
unplug and plug back in?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035736&cc=us&lc=en&dlc=en&product=305375&dlc=en&lang=en
are you sure you have the correct one in the correct slot?
Posted on Dec 21, 2007
  • 300 Answers
SOURCE: HP Officejet 5610 All-in-One--Cartridge Error
If a reset hasn't cured this problem you probably need to disassemble the printer and clean the service station and the system board. This normally clear all carriage and cartridge errors, but these machines are quite awkward to take apart.
Posted on May 17, 2008
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Posted on Oct 29, 2008
Joed911
  • 4338 Answers
SOURCE: I have a HP 7410, every time I print I get three error messages.
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find the hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
Let me know if this helps.
If it doesn't, I will research it further. If it does please rate it.
Joe
Posted on Nov 21, 2008
  • 4 Answers
SOURCE: HP Photosmart 2610 printer - had been using the
Have you tried replacing the cartridges all together? That worked for me. I use HP 96 and 97 cartridges.
Posted on Jun 16, 2009
NVM reset for hp photosmart c4780
You can gain access to the service menu...refer to Cartridge Error Clear bypass procedure below (as guidance of how to get in):
For any severe cartridge error related message, on the HP C4600, C4700 or D110a printer models, I suggest you run the internal Tap 41 diagnostics test which will tell you the electrical health of the ink cartridge - in many cases the cartridge is internally electrically damaged and will need to be replaced. In addition, you can temporarily bypass an 'incompatible cartridge(s) or Missing/Not Detected error message by performing the Cartridge Error Bypass procedure...refer to two Youtube videos on how to do this:
HP Photosmart C4600 & C4700 Printers - Tap 41 Diagnostic Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
Low Ink Warning and Other (i.e Incompatible Cartridge) Errors, HP 60 & HP 61 Ink Cartridges:
http://www.youtube.com/watch?v=5_suW3U6e08
Feb 28, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
My printer keeps saying
There is probably a small piece(s) of debris floating around in there. Look very carefully for it with a flashlight. Try to remove it that way.
You can also buy "canned air" available at computer and office supply stores and use it to blow out the printer as thoroughly as you can.
Believe it or not, I have read where a small piece of skin has kept the carriage from moving properly.
Oct 25, 2009 | HP Photosmart 375 InkJet Printer
HP Photosmart 2600/2700 series all-in-one printer problem
Check the expiration date on the cartridge, you may just need a new one. The date is printed on the side of the cartridge. They also just go bad sometimes.
Aug 11, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Cartridge failed
Oct 29, 2008 | HP PhotoSmart 7350 InkJet Printer
Cartridge failed after replacing it wtwice
Dec 21, 2007 | HP PhotoSmart 7760 InkJet Printer
Hp photosmart 375
As the previous message stated, I had the same problem and it was resolved by making sure that I used the original power cable. I couldn't find it at first and tried with three others all with the same error. Finally it was resolved by using the original.
Nov 14, 2007 | HP Photosmart 375 InkJet Printer
HP Photosmart 375 InkJet Printer Logo
142 people viewed this question
Seeker5211
Seeker5211
