Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultimate Care II-Model #LSQ9010PW2. About a year ago the delicate would not complete, the timer would make a humming noise but not advance. So, I quit using that cycle. Then the washer would fill with water and not advance further. I could turn the know and it would make a faint humming sound but do nothing. We replaced the timer but now it's like all of the cycles are off. The tub will fill with water, then instead of washing it begins the spin and rinse cycle. This is with a NEW timer. I'm at my wits end! What should we do?? Please, help. Thank you. Donna
    President:
  • 1,554 Answers
Granting that the timer wiring is not messed up, check the drain while the machine spins and rinses instead of washing. If there's water being pumped out of the drain hose, then the machine is indeed rinsing and spinning and there must be an issue with the wiring of the timer. But if there's no water being pumped out and the machine washes/agitates at the same time spins, then the issue is with the break and clutch assembly. The brake shoes must hold the brake drum and prevent the basket from spinning. The brake shoes are released only when the motor turns in the other direction and the clutch tab push the brake cam driver and release the brake to allow the basket to spin.
Posted on Jul 04, 2010
  • dksmith09 Jul 05, 2010
    How could I check to see if the timer wiring is faulty?
  • Jahn27
    Jahn27 Jul 05, 2010
    Forget about the timer wiring. The wires to the timer are connected by single connector block so there's no possibility of messing them up. As you did mentioned in your post, the tub fills with water and then instead of washing it begins the spin
    and rinse cycle. Confirm first if there's water being
    pumped out of the drain hose during that alleged spin and rinse cycle. If
    there's none and the machine washes/agitates at
    the same time spins, then the issue is with the brake and clutch
    turns in the spin direction and the clutch tab push the brake cam
    driver and release the brake then allow the basket to spin.
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Have a 10 year old Whirlpool Ultimate Care II top loading clothes washing machine. In the "Delicate" cycle, it stops after agitating sometimes and will not kick into the spin empty part of the...
Yes it is a timer issue, and yes the whole timer will need to be replaced. If you are handy it is not very hard. You can order the timer from marcone.com with your model # and it will show you a parts breakdown so you can see hoe to replace it easier
Nov 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care II doesnt' advance through
Lean washer on its back and check for broken wire from the motor wire harness up the back panel.
If you find the wire repair it and make sure the wire harness is secure in the provided clips.
Jan 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Oct 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Estate Whirlpool Washer, model #TAWS850PQ0 fills the tub but does nothing else. It does not agitate or spin, just hums.
if it cuts off the water ok and motor running
it could be a coupling .
possible transmission.
if no motor noise
could be motor .
wiring,
timer.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
592 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
