Question about Refrigerators
No water to the water dispenser
Model number: GSS25JSRE SS Serial number: mg281724
I changed the water filter and water gets to the filter but, does not go to the water dispenser. Is there a reset button somewhere?
    President:
  • 1,891 Answers
The water goes to filter first . then through water valve to the ice maker or foutain . . ck the valve it sounds like this is your problem .. mm hope this helped ..
Posted on Jul 04, 2010
How do I get the water to start coming out of the dispenser?
check that the supply valve is open, and that any filtration components are current. In areas with high mineral content, filters will clog/become impenetrable quicker than manufacturer specs,blocking water flow.
Dec 27, 2014 | GE Refrigerators
Water dispenser stopped giving water. how do I get water to start coming back out?
have you tried cleaning the filter dispense or replacing it and/or trouble shoot your own refrigerator and then enter your model number
Samsung Frig water dispenser makes loud humming sound when dispensing water. This began after changing water filter.
Check to see if you have rotated new filter in the engaged direction.
I have had a few filters that were defective and were not fully charged. If you have the reciept, take old filter back to retailer and see if you can exchange it for another one. Also, make sure you have the right filter model number. You can check the model number for the filter with your refrigerator model number at Searspartsdirect.com
Hope this helps
Dec 13, 2014 | Samsung Refrigerators
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile PFSS5NJWA SS water dispenser not dispensing water. I tried changing the filter, but it still does not work. I also tried pressing the "reset filter" button. When I press the water...
We have the same model and just had exactly the same problem. The coil behind the fresh produce trays is frozen. There are 2 coils, one provides water for the water dispenser and the other to the ice maker. Looking into the fridge the water dispenser coil is on the right hand side. We unplugged the fridge for a couple of hours and the problem has been solved. Try increasing the temperature of your fridge by a degree or two.
Feb 17, 2011 | General Electric PFSS5NJXSS Stainless...
Profile side by side refrigerator,model #GSC23LSRC SS
If you can get to the line in queston take it loose and blow it out, make sure that the filter has been taken loose prior to doing this
Aug 28, 2009 | GE DBSR453EBWW Electric Dryer
Water dispenser not working
check the water valve on the ref it is in the back on the right side behind the cardboard cover
Apr 09, 2008 | Refrigerators
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
