Question about Texsport Big Sky Room Family 01327 Tent
Need directions for Texsport Americana Screen
Need setup directions for Texsport Americana Screen Arbor. I've lost original instructions
2 Suggested Answers
melindapo318
SOURCE: how do i put up
the top pole go in the order 123, the outer box is 454, and the big poles are the legs
Posted on Aug 05, 2012
I need to setup my texsport patriot arbor
Hi William, I believe you may be in the wrong forum? Regards John
Sep 01, 2012 | Cars & Trucks
I have a DW402 4.5'' angle grinder and do not know how to remove the blade to install a new one. Could someone help please?
On top of the head there is a button to press to lock the blade arbor. Press it down and turn the blade by hand until it locks in place. Then you need either a spanner wrench or nut wrench depending on which arbor nut you have. Grinders usually come with whichever wrench they need. Most grinders have an arbor nut with two or four holes and require a spanner wrench with two studs that fit into two of the holes to remove the arbor nut. Some have an arbor nut with a hex fitting, like a regular nut & bot setup, that the arbor wrench fits on. If you don't have the proper wrench sometimes you can get the arbor nut off with a pair of vice grips or pliers. You will want to turn the nut in the same direction as the blade spins when the grinder is on to remove it. When you put the new blade on, get the arbor nut hand tight, it is self tightening and will get tighter as you use the grinder.
Jul 18, 2012 | Dewalt Saws
My hp pavilion dv7-4285dx has lost everything, os and all. How can I get it to read the recovery disc I ordered from HP?
What makes you think you've lost everything? Unless you specifically instructed your computer to Format the hard drive, I would doubt very seriously that you have lost everything. Everything might still be there, but a virus has hidden it to make you think you've lost everything. Oh, one more way to lose everything is to interrupt a System Recovery before it completes, or interrupt an Fresh Install of Windows before it completes.
A lot of times the System will think you've lost everything because somehow a setting the bios was changed either by you or some virus and it has set the hard drive where it is not detectable. Turn your computer off then watch the screen to see which key you have to hit to get into the BIOS or SETUP or System Setup.
Once you are in the BIOS scroll through it looking for AHCI that will be associated with disk drives or disk controllers. If it is Enabled, Disable it and Boot your machine. If it is Disabled, Enable it and Boot your machine. In other words just change the settings for AHCI.
Do that and report back.
Mar 22, 2012 | Computers & Internet
How do i put up an americana arbor screen house. I lost the instructions
Aug 13, 2011 | Texsport Big Sky Room Family 01327 Tent
No directions for an old Texsport 0-82 screen tent
Try calling Texsport at 1 800 231 1402 they will be able to help you.
Aug 07, 2011 | Texsport Big Sky Room Family 01327 Tent
Having problem get blade off table saw any hints
Unplug the saw, first and foremost.
Then see if your saw arbor has facets for a wrench behind the blade, and if so, try to find a slim wrench that fits there to hold the arbor while you attempt to loosen the arbor nut that holds the blad on. If that doesn't work, take a stick of wood, like a piece about 3/4" x 1 1/4" x 12-16" long, remove the throat plate from around the blade, wedge the stick between the blade teeth and the edge of the throat slot to hold the blade in place firmly, exerting levered force toward the center of the blade to hold it in place, and using the wrench, loosen the arbor nut. Make sure you are attempting to loosen in the correct direction. Depending which side of the blade the nut is on, some nuts are reverse threaded.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 19, 2011 | Craftsman 10" Table Saw
Im looking for the assembly instructions to my texsport cranfield screen arbor model#02832.
I have the instructions after a couple weeks of emailing texsport customer service. I hope this uploads.
Jul 02, 2009 | Texsport Sport & Outdoor - Others
Texsport Big Sky Room Family 01327 Tent Logo
140 people viewed this question
Top Texsport Sport & Outdoor - Others Experts
Bill Eager
Are you a Texsport Sport and Outdoor - Other Expert? Answer questions, earn points and help others
