Question about Singer 7462 Mechanical Sewing Machine
How to Unjam a Sewing Machine
THe material has gone under the plate and has resulted in a jam. How am i suppose to unjam the sewing machine all threads are taken out.
  • 980 Answers
The only way is to cut it away and if the needle is stuck in break to make things easier.
Posted on Jul 05, 2010
How do I unjam a pfaff sewing machine
If possible, try removing the bobbin & bobbin case. That will usually allow access to any thread accumulation.
Sep 26, 2016 | PfaFF Sewing Machines
There is thread pieces under the tread plate and when the machine tries to trim the thread it doesn't and sounds like it's hitting something
Sewing Machine Thread Bunching Up? Here's Why! - Craftsy
www.craftsy.com > Blog Home > Sewing Blog
Jan 21, 2014 - There are lots of reasons for sewing machine thread bunching up, and ... or bird nesting, on the top of your fabric, the culprit has something to do ... Frequent dusting underneath the throat plate and along the thread .... It looks like it's hardly been used but the top thread keeps tangling below the material.
Sewing Machine Needle Not Catching Thread ' ThriftyFun
www.thriftyfun.com/tf80302359.tip.html
Dec 20, 2015 | Sewing Machines
My sewing machine jammed the fabric into the bobbin case and now it won't sew the needle hits the plate under the bobbin case can I adjust this myself
Here are some videos that may help. If not, search the internet for thread jam.
How to Fix Thread Jam Sewing Machine
When Thread is Caught in Sewing Machine Sewing Lessons
https://www.youtube.com/watch?v=tDcBUR0PcyA
If you get it unjammed, be sure to install a new needle as the old one is probably damaged. If there are still issues, the machine's timing may be off and would need professional service.
Oct 23, 2015 | Singer 7470 Confidence Sewing Machine
How do I unjam my machine.
Have you removed the feed dogs and bobbin to check if material or thread is packed underneath?
Aug 27, 2015 | Singer Izek Computerized Sewing Machine
How do I unjam my sewing machine?
I am going to guess that you have experienced a "bird's nest" of the top thread becoming entangled under the needle plate. Gently lift the fabric just enough to see the thread and using a craft knife like an xacto blade, very carefully work at cutting the fabric free. Give the bobbin area a good cleaning. Then be sure to check and make sure the top thread is traveling through the right path before you try stitching again.
Feb 08, 2015 | Sewing Machines
Have a pfaff2036.wife was sewing and it jamed.how what
Try unplugging machine from wall. Remove the tread and needle.
Turn hand wheel backwards, the hook probably has a piece of thread jammed in the race. If you can turn backwards look for the small piece of thread remove it. New needle and rethread plug in and try again.
Oct 08, 2014 | Sewing Machines
Elna SU purchased in 1977 jammed; rotating wheel is unable to move forward
it sounds like the machine needs to be serviced at a sewing machine
shop
May 05, 2012 | Elna Sewing Machines
Consew Zig Zag CN2053R-1 needle bar is jammed
sometimes when a machine jams, the machine jumps time
taking it to a sewing machine shop to be serviced would be a good idea
Apr 30, 2012 | Sewing Machines
The material feed isn't working on the borrowed machine that I am using. Is there an adjustment? I have to feed the material by hand!
Are the feed dogs up? Can you see them moving?
Sew without fabric and you should see the feed dogs moving back and forth under the needle plate. There may be jammed threads in it if it is not moving. Not sure about your machine but most needles plates either flip up or can be unscrewed to check underneath for clogging.
Dec 18, 2010 | White Sewing Sewing Machines
My new ruffling foot keeps jamming my machine
Take the foot off and check for a small burr in the area that pushes the material through. If there is a burr, it will get caught, especially on lace. The burr can be removed with a very fine abrasive stone or the emery srea from a match pack.
Feb 26, 2009 | Brother CS-8150 Computerized Sewing...
Singer 7462 Mechanical Sewing Machine Logo
103 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
