Question about Gaggia Classic Espresso Machine
My precious Gaggia Classic machine has developed a "fatal error". It will not pass water through the shower head. I have tried cleaning, re-priming to clear air block, several times over. The pump appears to be operating well but I cannot get any water through the shower head at all.
    President:
  • 1,618 Answers
Remove the shower, then the 2 allen wrench screws for the diffuser, careful do not loose the spring ad valve seat that is above the diffuser, now turn machine on to see if water will come thru, if water flows, problem is either screen or diffuser blockage, if no water then you need a stronger descaler because blockage is in the boiler, at the solenoid or from the pump. Most likely in the boiler, if you have a boiler gasket go ahead and open the boiler to clear the blockage.
Posted on Jul 07, 2010
Gaggia Classic (3 months old). Suddenly there is steam only, no water flow.
If there is no water from the head then remove the screw and screen, then press brew button, if water flows clean shower, using a pair of plies hold screen over open flame, coffee will burn out of the small holes. If no water after trying above then remove the 2 allen wrench screws and carefully remove the diffuser and seat with spring, now try running the head, if water flows reassemble and you are back in busines, if no water descale machine.
Nov 25, 2010 | Gaggia Classic Espresso Machine
Hi, My Gaggia Classic is not working. No water
try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Jun 29, 2010 | Gaggia Classic Espresso Machine
I have a gaggia classic. I've descaled it and kept it running well for a few years. It now won't let any water out of the coffee filter section - the frother is perfect, but no water is coming out of the...
Remove the screw and shower in the head, check shower for blockage, if it is covered with coffee, hold over an open flame to burn out coffee (easiest way to clean it). If it is clean and you can see through all holes then turn machine on and press brew button, if not water flow, then remove 2 allen wrench screws and check spring and valve(remove carefully) then try the brew button, if no water then blockage is on the inside of the machine use the pic below to clear it will be on the top of the head.
Jan 20, 2010 | Gaggia Classic Brushed Stainless Steel...
No water coming thru machine head
Remove the shower screen and screw then try if water flows clean shower, if not remove diffuser screws and check spring and valve to make sure it is not blocked.
Dec 14, 2009 | Gaggia Classic Espresso Machine
Gaggia baby espresso machine - water comes out of steam wand but not group head. tried priming, cleaning
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Oct 21, 2009 | Gaggia Baby Espresso Machine
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Aug 22, 2009 | Gaggia Classic Espresso Machine
Water wont flow past brew head
Hi there, it sounds like your boiler may be full of scale. There is a copper tube which runs from the group up inside the boiler which can get clogged up quite easily. When you take the group apart you will see that when you remove the shower plate and unscrew the bolt in the middle the safety valve and spring will pop out and then if you get a pipe cleaner or something similar and ram it up through the copper pipe. If this does not work then you may have to dimantle the boiler and give it a good clean out. Also although you say the pump is primed it could still be broken. All these problems usually come from scale though. If you get some descaler and try to feed into the boiler by pumping or running water out the steam wand this may free it up. Any further assistance please get in touch with David at coffeeservice@live.com
I am a domestic coffee machine engineer and have machines of all makes sent to me from all over the UK daily. I specialise in La Pavoni, Gaggia, Elektra, Francis Francis etc. You can get in touch with confidence.
All the best
David
The Domestic Coffee Service.
Jul 06, 2009 | Gaggia Classic Espresso Machine
No water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Jun 18, 2009 | Gaggia Baby Espresso Machine
Airlock in new machine
I have a similar problem, I think. I get water through the steam thing, but not through the brew head. Not sure what to do either.
Oct 07, 2008 | Gaggia Classic Espresso Machine
Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Feb 03, 2008 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
1,666 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
