Question about Maytag Admiral Top-Freezer Refrigerator
Refrigerator is running, but fans won't kick on to keep it cooling. Admiral ltf2112arw model. What could be wrong
    President:
  • 1,891 Answers
If fan won't run replace it as they do ware out and this is a very common problem .. mm
Posted on Jul 04, 2010
I have an Admiral LTF2112ARW refrigerator. The refrigerator is working but the freezer won't stay cold even though the thermostat is on the coldest setting. Any suggestions about what is wrong?
ITS NOT A GOOD IDEA TO USE THE COLDEST SETTING CUZ WHAT U WILL GET IS EXACTLY THE OPPOSITE A MORE WARM SETTING. A HIGH SETTING CAUSES THE COMPRESSOR TO OVER WORK IT SELF CREATING TO MUCH COLD IN ONE SECTION TO THE NEGLECT OF THE OTHER SECTION. UR PROBLEM IS NORMALLY THE OTHER WAY AROUND TO MUCH FREEZER AND NOT COLD IN FRIDGE.? BUT i WOULD CHECK THE THERMISTORS IN THE FREEZER. AND ALSO TRY ADJUSTING UR SETTINGS TO MED AND CHECK UR AIR FLOW CONTROL VENT AKA COLD CONTROL THERMOSTAT.
Feb 23, 2015 | Admiral Refrigerators
My Admiral mullion is hot
Probably the defrost element has failed, ice & frost will continue to build up & it's ability to cool will deminish over time. Has to be checked & possibly replaced.
Nov 20, 2013 | Admiral Refrigerators
Not cooling
It's probably either a defective thermostat, fan or compressor.
May 14, 2012 | Admiral Refrigerators
Admiral HMG61139 21.1 cu ft Side-by side refrigerator, not cooling. clicking sound every few minutes. (sounds similar to oven thermostat or relay coming on).
Thier is one of a couple things going on with your refrig.
The start relay on the compressor is bad so what your hearing is the overload thermostat tripping on and off and keeps trying to start the compressor
The fan motor by the compressor called the condenser fan motor is not running to cool the compressor so once and what you overload keep trying to start the compressor but its too hot to start
Finally the compressor is locked up and the overload still keeps trying to start it but its totally seazed and ain't going to run
I hope this helps you to determine what is wrong with your refrigerator,
Gene
Aug 10, 2011 | Admiral 26 cu. ft. Side-By-Side...
My fridge Admiral doesn't make cool temperature.The fan is running but the temperature stay at 19 celsius.What can I do?
<P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>Hi,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN><BR>Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<BR><BR>Refrigerator not Cooling or Fridge not Cooling<BR><A href="http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not</FONT></A><BR><BR>How to Defrost Refrigerator Defrost Timer Problem <BR><A href="http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer</FONT></A><BR><BR><BR>Water Running in efrigerator from Freezer<BR><A href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target=_blank><FONT color=#800080>http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</FONT></A><BR><BR>heatman101<o:p></o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><o:p><FONT size=3 face="Times New Roman">&nbsp;</FONT></o:p></P>
Aug 26, 2010 | Admiral 26 cu. ft. Side-By-Side...
Admiral refrigeration not freezing not cooling
This could be a defrost problem or fan not working all time when compressor is working. What is your model number so I can see what components your model has and then solve your refrigerator problem. Need you to answer so we can get you running, Sea Breeze
Oct 23, 2009 | Maytag Admiral Top-Freezer Refrigerator
Admiral side by side fridge defrosted and no longer cooling
Replace the compressor start relay.
If this does not solve the problem you most likely have a bad compressor.
Your fridge may be under a 5 year compressor warranty.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
Jan 31, 2009 | Maytag Admiral Top-Freezer Refrigerator
Admiral LTF2112ARW cooling problems
First I would make sure the compressor is running.
Unplug the Ref. for about 15-20 min, plug it back in and listen for the compressor to start. You will have to be behind the Ref to tell the difference between the compressor fan and the compressor. If the compressor clicks and doesn't run then the relay on the compressor should be replaced. If it runs then it is probably low on coolant.
Dec 13, 2008 | Admiral 26 cu. ft. Side-By-Side...
Maytag Admiral Top-Freezer Refrigerator Logo
206 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
