Question about GE Security Simon 3 Wireless Home Security System
Hi i have a ge Caddx NX-148E-RF - beeps only on the hour anoying
Hi i have a ge Caddx NX-148E-RF - Programmable LCD Keypad system and my key pad beeps 1min of every hour on the hour how do I stop this
    New Friend:
  • 74 Answers
Press * 2 and it should tell you what the problem is.
AlarmProfessor.net
Posted on Aug 23, 2010
Need Manuel for GE security keypad model # 422-2195 REV B
I don't think we will be able to locate a manual just for the keypad - is there a name or model # for the entire system? Like an NX-# or a Caddx designation?
Nov 29, 2014 | GE Microwave Ovens
We have an NX-148E keypad. Our building has 4 doors alarmed to the panel and the Chime sounds when any of the doors is opened. Is it possible to set the Chime only to sound when 1 of the doors is op
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
Oct 03, 2012 | GE / Caddx Networx Programmable LCD Keypad...
I forgot my password for my Caddx NX-8 Alarm. It was installed in 1999
My caddx nx-8 system, have started going into a instant alarm mode for no reason, what can I check for this?
Mar 30, 2011 | GE / Caddx Networx NX 8 Control Panel...
We have a Network NX148E which was linked to a central minitoring. Just wondering if this can be re programme to link to our mobile instead?
Hello
Yes you should be able to have the system call multiple phone #s.
I would recommend you ask your monitoring company to do this or make a change in your account.To add your mobile #
Once the alarm is set off they need to know first to dispatch police fire or ambulance.
Mar 29, 2011 | GE / Caddx Networx Programmable LCD Keypad...
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
Can I adjust the volume on my GE Networx NX-148E keypad?
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
Mar 28, 2009 | GE Interlogix Dvmre Pro 10 Channel Triplex...
GE Security Simon 3 Wireless Home Security System Logo
448 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Electro Med Services...
Are you a GE Home Security Expert? Answer questions, earn points and help others
