Question about Technics SL-PD887 5-Disc CD Changer
Unit is a 2 channel system. If connected to a 5 channel receiver can it function over the 5 speakers?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 241 Answers
Most 5 channel receivers can simulate some kind of surround effect from a 2 channel signal, so the answer is most likely yes.
Posted on Jul 04, 2010
When I turn my system on, it waits 5 seconds, says "PROT" then shuts itself off.
There could be a short circuit in one of the speakers. This would cause high current flow thru the amplifier and result in self-protect. Disconnect all speakers from the unit and try powering up again. If there is no PROT, then reconnect speakers one by one until fault found or all speakers are reconnected.
Oct 04, 2015 | Samsung Ht- C550 5.1 Channel 1000 Watt...
Onkyo mute channels. When turned on, one or more channels remain mute. Acts like a contact problem; when switched on-off-on multiple times, mute channels may vary
follow this steps and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Oct 11, 2013 | Onkyo TX-SR500 Receiver
Hi, my problem is only the front 2 speakers work i have tried all the speakers in the front 2 connections of the unit & all speakers are working but none when in the rear, center, & sub woofer unit...
Without knowing which receiver etc you have... make sure your "mode" is set to 5 channel, Dolby Pro or similar. And even then, make sure your source is 5 channel. What are you using for an input cable? It needs to be able to provide 5 channel. Standard RCA stereo type cords do not. You need either optical, "coax" or hdmi. Lastly do you actually have a 5 channel program? Many older movies, and standard cable boxes only output stereo, not 5 channel.
May 31, 2011 | Audio Players & Recorders
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Looking to connect 4 speakers to the surround back
Series the speakers, they may not get as much power as you would like, but your receiver will last longer.
Aug 16, 2009 | Pioneer VSX-518-K Receiver
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
Sound from 3 channels only
Hi, first of all did you verify with the manual if it is possible to run a testsignal through all 5 channels?
One of the most common problems in this case is the basic settings of the device. If you don't have the manual, mostly you can download them from manufacturers website. Chances are that for some reason the setting is set 3.0 stereo (also known as 3channel sound) which is always the 2 fronts and the centre speaker.
Best thing to do it is take a DVD with THX on it and run the THX setup, it will send test signal to all channels.
Jan 15, 2009 | Philips HTS3450 System
HTR-6130
Read your instructions book again, when you press 7 that mean you are enter in select speakers you must use 7 then narrow UP DOWN and LEFT RIGHT when you finish you must save by press SET
The easy way to set it up is connect your receiver to TV then you can see the complete MENU on your TV screen
Or you initializer the unit to go back to the default mode, which will set to 5 speakers if you wish to do this look on same model I was post earlier how to initializer the receiver
Nov 28, 2008 | Yamaha HTR-6130 Receiver
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Technics SL-PD887 5-Disc CD Changer Logo
57 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
