Question about Whirlpool Duet GHW9150P Front Load Washer
Has been very loud for the last three weeks, just stopped and has a weird odor like burnt rubber.
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Posted on Sep 28, 2010
What is the bruning rubber odor - new dryer!
Im not familier with that particular machine but it sounds as though bits of the rubber backing you talk about has flaked into tiny bits and moved beyond the drum and into the workings of the dryer moter and heater. Contact with these will produce the smell and slight risk of fire.
The back of the applience will need to come off and cleaned out.How you accomplise this is up to you!!. If you have some one who is very handy at this sort of thing then grt.otherwise leave it to a proffesional. Obviosly compressed air gun is the way to do it.
Oct 15, 2013 | Maytag MEDE201YW Electric Dryers
2000 Ford Escort, oil light came on then lost all gas power and my car would not go over 40 miles an hour. Then my car died and white smoke came out from under hood. I smelt a strange smell before all
gonna guess that the timing belt slipped or broke due to low oil pressure up top..what was the odor..burnt oil. burnt antifreeze or burnt rubber..or did it burn your nose like an electrical fire..repost please
Jan 17, 2013 | 2000 Ford Escort
After extended city driving, get strange burn odor.not rubber, not electrical smell. Then engine power start dropping, pull over and park for 15 mim.,Restartand power returns to normal.No elecctrical...
sounds like you may have a bad caytalatic convertor they will have a bad odor and put a lot of back pressure wich will cause bad fuel mixture and poor power but when you let it sit it will clear up ,pressure will reside and 02 mixture will coorect its self,hope you can use this.
Jul 05, 2011 | Chevrolet Tracker Cars & Trucks
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
My BLOWER MOTOR - last week was making a loud
might have to remove squirrel cage and assem. on new motor
Jan 21, 2010 | Mercedes-Benz E320 Cars & Trucks
Purchased a Hoover Mach 3 upright sweeper which gives off a odor
Return it immediately and run the unit with a store rep as witness.
Dec 30, 2009 | Vacuums
Loud vibration
If it is a frost free check the fan inside. The fans can have bearing failure after a few years thus causing the vibration. Also the compressor underneath is mounted on rubber vibration dampers and if one of these rubber mounts fail then the compressor will start vibrating against the refrigerator frame causing a loud vibration. If none of these apply gently press on the side and front panel of the refrigerator to try and locate the source of the vibration as any where metal is vibrating against metal the side and front panel act as a sounding board amplifying the sound. If you cant locate the vibration then you may have a more serious problem and may need to call a technician.
Oct 09, 2009 | Roper Refrigerators
Kenmore washer odor
The most likely cause of a burnt rubber smell is a worn motor coupler.
Sears parts site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24922200&pop=flush
Go to the sub section with the brake/clutch/motor/gearcase and item # 13 is the motor coupler between the motor and transmission.
It has three parts. 1. A plastic piece with three prongs fits on the transmission input shaft. 2. A plastic piece with three prongs fits on the motor output shaft and 2. a RUBBER grommet with 6 holes fits between them.
Over time, the rubber piece can wear and the two plastic pieces can rub against it at speed causing a rubber burning smell.
Replacing one is easy.
Remove the cabinet, the pump (2 clips) the motor (two screws and clips) and the motor mounting bracket (two 1/2: bolts).
Remove the rubber piece and pry off the two plastic pieces. Fit the new plastic pieces on the transmission and motor shafts. Replace the mounting plate. Carefully line up the six holes as you put the motor back on.
Replace the motor mounting clips, the pump and clips and cabinet.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Washer won't spin anymore
Was it getting loud in spin prior to this?
If so, based on past experience with this model, I would say you need at least a triple lip seal, belt and possibly a transmission.
Nov 22, 2007 | Maytag SAV2655A Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
