Question about Acer Aspire 4520-5582 Notebook
Pc acer 4520 problem
"the green light on my acer 4520 comes on on the adapter but my pc will not charge"
  • 162 Answers
Try to clean the Battery contacts using a pencil Eraser. Also, check if Acer has released any BIOS update or Battery check utility. Try using any other compatible battery and check if the same issue persists.
Posted on Jul 04, 2010
Acer 4520 not starting
hmm ..... check adapter , battery then check dc jack , power on switch , then fuses , mosfets , charging chip , ..you must hav multimeter and u knw how to use .. must hav soldering skills, some times smd.... otherwise take it to repair shop
Jan 28, 2013 | Acer Aspire 4520-5582 Notebook
I have an acer 4520 lap top. I can't get it to power up at all. When I push and hold the power button the green light comes on around the power button and the three lights in the upper right side flash...
first remove your battery and try to switch on your laptop with good power adapter if still have the same issue ?? just remove your memory and reinstall after clean your memory if still have the same issue ?? remove your memory and cmos battery and switch on it with a good power adapter.after 2 minute you can re install back your memory and cmos battery and try to switch on it.
Sep 14, 2011 | Acer Aspire 4520-5582 Notebook
I have a Acer model laptop and my doesnt work. How could I fix it?
please check out with the power adapter is connected proper, then check out the light indicate of charging then switch on the laptop
Apr 30, 2011 | Acer Aspire 4520-5582 Notebook
When plugged into power supply and with battery, my battery light shows orange ( as if it were charging ) then quickly to green ( as if fully charged ). * When I push the power button, the...
Your battery is dying from heat. Most likely because you leave it plugged in for too long. I suggest buying a new OEM (not china knockoff) adapter, and replace the cells in the battery or just buy a new batter.
Mar 22, 2011 | Acer Aspire 4520-5582 Notebook
Acer Aspire 4520 laptop: Battery not charging
If your adapter /charger has low voltage it will not properly charge the battery, any battery. Go that route and try another adapter..
Sep 06, 2017 | Acer Aspire 4520-5582 Notebook
Acer aspire 4520 does not power up despite fully charged battery and wall adapter turned on. power light blinks for a moment and all other indicators turn on and immediately go off. What could be the...
Remove ur battery & clean it with water and put it in to ur laptop then press 5 minutes ur power button Then ur laptop get started .
Note : Wash ur battery with clean water .
Mar 26, 2010 | Acer Aspire 4520 Notebook PC
I plug my ac adapter in my laptop usually when you charge it turns the battery light in red then after few seconds turns to green! do you think the charge is not working?
Hello my friend this looks like a battery problem or a bad connection between DC-IN power jack on the system board,first try to wiggle the power cord and if power LED and battery charge LED start flickering then is the DC-IN power jack`s problem ,if its not is battery problem and you should change the battery
I'm waiting for your response
Good luck my friend:)
Jan 27, 2010 | Acer Aspire 4520-5950 Laptop
Laptop still won't turn on, adapter is good, no green light on laptop.
Most have a small board that controls the source of voltage for the unit; battery or adapter, and also monitors the charge state of the battery to avoid damage from overcharging. That board or a fuse on it may have failed. The fuses used are often soldered onto the board and not really user replaceable.
Dec 02, 2009 | Acer Aspire 4520-5582 Notebook
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
Acer Aspire 4520-5582 Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
