Question about LG LSC091PMA Split System Air Conditioner
Thermal shutdown I have had three servicemen work on my A/C. They say it just gets too hot and shuts off. That it is supposed to do that. Do you have any suggestions
    Sergeant:
  • 338 Answers
Its getting hot for a reason and its not suppose to do that. Sounds like they are saying the compressor is getting thermally hot and shutting down? hAVE YOU CLEAN THE CONDESNOR COIL ON THE OUTSIDE? yOU CAN TAKE A HAIR BRUSH AND GO UP AND DOWN ON THE COIL TO CLEAN IT AND USE A WATER HOSE TO WASH OUT THE DIRT. tHEN ON YOUR AIRHANDLER IN THE HOUSE CHECK YOUR EVAPARTOR COIL AND SEE IF IT DIRTY AND CLEAN IT WITH THE BRUSH AND GO UP AND DOWN ON THE COIL AND CLEAN IT YOU CAN USE A SQURT BOTTLE OF WATER TO CLEAN IT. nEXT CHECK YOUR BLOWER FAN THE SQUIRREL CAGE TO MAKE SURE ITS CLEAN. AND IF NOT CLEAN IT. iF THIS DOES NOT CURE IT THEN IT IS A PRESSURE PROBLEM WTH THE FREON.
Posted on Jul 04, 2010
Model GR-242MF. Gets cold but why does it seem to run constantly?
no doubt it needs freon added and usually only certified servicemen can do it
Nov 20, 2015 | LG Refrigerators
How can I fix thermal shutdown of Acer b1-730?
Could be the CPU needs new thermal paste and reseating.this is usually a fail safe designed to protect the computer when the CPU is getting too hot.also check the cooling fan ......blocked vents as this may also cause overheating issues thus not cooling the internals which will activate thermal shutdown.
Mar 18, 2015 | Acer Computers & Internet
Keeps tripping thermal shutdown
Most of the time its just bad (thermo disk) thermal shutdown as you call it. If you dont have any hot water at all just unplug the two wires on that disck and stick them together,this bypass that disk. then have somebody turn on the hot water while you watch the heater for any problems. Let me back up just a little.
Before you do that you must know if its tripping while the water is flowing through the heater if it is then its a weak disk. If it trips a few seconds after the water is shut off then for some reason(usually a bad circuit board) the element is not shutting off and over heating the disk. That means the disk is doing its intended job. Do not bypass the disk ifit trips after the hot water is shut off at a faucet.
Jan 11, 2013 | Stiebel Eltron TEMPRA 12 Tankless Water...
Random shutdowns
It is either running hot or you have a virus or infection.
Sounds like it might be running hot. If it is running hot it shuts off to keep from damaging the motherboard.
If it is running hot it will boot up to windows and let you do things as long as it is cool, but when it gets hot it will shut off and not boot up again until it cools off. That's a sign that it is running hot.
Three things that will cause it to run hot.
1) Dust. Dust in the vents, inside the computer, clogging the fans and dust around the cpu and heatsink.
2) A fan that has stopped working.
3) The Thermal Paste around the CPU and Heatsink has dried up or is too thin to keep the unit cool.
To fix either of the three would require taking the laptop apart. However you could buy a can of compressed air and blow out the vents, but this just pushes the dust inside the computer, but it might work.
If it is not running hot then you have a virus or infection that is shutting it down. Download and install MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
May 04, 2012 | Gateway DX4800-05e (PT.G540X.005) PC...
Yamaha rxv1600 speakers keep cutting in and out when i turn the volume loud
The most likely cause is the audio output semiconductors gets to hot, or bad solder connections, but if you run the volume at half to three quarters the amp will start to clip drawing more power from amplifier the outputs will go into thermal runner way causing a shutdown.
Mar 14, 2012 | Yamaha Audio Players & Recorders
Have a Technics SAAX720 that shuts off fifteen minutes turning on power. Gets very hot quickly
Heat = power or FAULT, in your case I assume you have checked the vents are clear.
If its getting too hot the thermal shutdown will operate to protect the unit and the area around it. These things have the ability to cause fires as they have big power supplies inside, thats one of the reasons why they have thermal protection. Also exposure to heat damages equipment over time.
Maybe try this take it out give it lots of airspace, make sure the connections are all good and try it on low level, if it shuts down again you need to take it for repair. These items are very complicated and require specialist attention.
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | Audio Players & Recorders
My washing a whirlpool awo 10761 front loader,when i switch it on after 20 seconds the ''door locked'' light starts to flash and the programme goes no further
If you can still open the door when it's supposed to be locked it probably means that the interlock on the door catch is faulty.Easier to fix than if the door is locked shut!!...Not a big job but should be done by a qualified tech. See if you can find an independent, self employed tech...Generally cheaper and better than 'Brand Name' servicemen..Good luck..........Nomess
Apr 17, 2010 | Washing Machines
I have purchased compex ADSL modem 16 months back and using regularly, For the last three months I disconnected the internet connection so the modem was not in use. Now I got internet connection but the...
One thing you can do.
Try to download an updated firmware for from the manufacturer of the DSL modem.
In most of the cases this will resolve the issue that you are describing.
Lastly I would suggest to buy new one if it stills does not work
Thks
Uttam
Feb 02, 2010 | Computers & Internet
Notebook fan
Yes most likely as otherwise you would not have been advised to shut down. The processor get red hot is not cooled continuously by the cooler fan. And heat of all sorts is bad for the health of the processor and other components. What I would suggest is to use a Cooling PAD available on Ebay. This is nothing but a tray that has three USB powered fans that keep dissipating the heat with these three fans all the time the laptop is running. Very helpful. Although you spend some money on it, but in the long run it works wonders.
Nov 30, 2009 | Televison & Video
Are all three wires in the power cord suppose tobe
not generally there should be a hot, a neutral and a ground for 110VAC if 220 two hot and a ground, if you are reading voltage on your ground, the braker of fuse should have tripped or blown, and you have a component that is shorted.
Jul 15, 2009 | Dehumidifiers
LG LSC091PMA Split System Air Conditioner Logo
49 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
