Question about Intex Pool & Spa
How do you hook the vacumn to the skimmer?
How do you hook the vacuum to the skimmer?
  • 760 Answers
First connect hose to vacuum head mounted on handle. Put vaccum in water. Take other end of hose and hold over return outlet filling the hose with water until the vacuum floats up and all the air bubbles stop bubbleing. When it sinks again, hold your had over the hose and take it to the skimmer. If you have an adaptor plate for skimmer have it already on the hose. If you don't have one, then remove basket and quickly remove your hand and put hose down ito pipe in skimmer. You will get some air and once the pump recovers, and starts pupming, then begin vacuuming.
Posted on Jul 04, 2010
Testimonial: "thank you at least you gave me a clue. since my husband pasted away trying to learn all this stuff has been overwhelming at times. What does the adapter look like? "
How do you hook up vacuum to pool without skimmer?
Every Pool has to have some type of suction hook it to that
Jul 13, 2016 | Pool & Spa
My pool pump is working great and then suddenly quits?
Do you have an in floor cleaning system? If so, the skimmer might be on a cycle and might not always have suction. Mine does this, and the skimmer (where u hook up the vacuum hose) only has suction for about 10 min. Try flipping your valve arms different ways to turn off the in floor heads
Jul 27, 2012 | Intex Wet Set Above Ground Pool Surface...
How do I hook up vacuum hose to skimmer?
I don't know exactly what vacuum system you have but I found the following link that might help: http://www.ehow.com/how_6304524_intex-pool-vacuum-instructions.html . I hope this helps.
Aug 27, 2011 | Intex Krystal Clear Model 635 Pool Filter...
How to hook up vacuum to sand filter
hooking up the vacuum assembly is done at the poolside skimmer. there is a vacuum plate that goes over top of the skimmer basket, allowing you to leave the basket in place to catch any larger debris. the plate will have a fitting at the top to attach the vacuum hose. before turning the pump on, be sure to bleed the air out of the vacuum hose so the pump does not run dry.
if this is a new thing for you (like you just bought the house with the pool, or something like that), please post any further questions in the comment section, i realize this can all be sort of overwhelming at first, and often the previous owners don't leave you all the pieces you need!
Aug 25, 2010 | Hayward SAND FILTER, PRO SERIES
How do I vaccum the pool? I dont know if I turn the Veriflow to out and then where do I hook in the hose?..Its my girlfriends pool and she just expects me to know. Thanks
Oh then you DO need help. To vacuum you don't need to change the valve setting on the filter, but if there is a valve on the intake selecting main drain/skimmer you can select skimmer only, but I usually only do this after I have the hose primed. . You attach the hose to the skimmer inlet. Usually there will be a round plate attched to the hose that fits into the skimmer ( you may have to remove the basket) If you don't have that round plate on the hose, then you can insert the hose driectly into the bottom of the skimmer. Before you attach the hose, connect it to the skimmer head on the pole. Submerge the head and hose. Allow to settle to bottom. Put all the hose into the pool. Take the other end and hold over the discharge back into the pool to fill the hose with water (prime) until air bubbles stop coming from vacuum head. Then hold your hand over the hose (to keep from loosing prime) and quickly attach to skimmer. You may hear some air, and the pump may stop pumping fully mommentairly untill it is pumping full water again. Now you can select the valve to divert all the flow from the skimmer
Aug 13, 2010 | Hayward SAND FILTER, PRO SERIES
My Ec 50 is brand new and when using the skimmer everything works just fine , but when I hook up the vacuum hose the filter will run for about a minute at 10 lbs pressure then drop to nothing (0). My...
You have air infiltrating the vacuum line somewhere. The hose may have a swivel cuff on one end that must be in the water, not attached to the skimmer. Next, check the gasket on to p of the pump housing. Under vacuum, the gasket may bleed air into the system shutting down the pump flow. Lastly, check the skimmer thoroughly for small cracks. Again, under vacuum it may open and allow air to infiltrate. The only way for a filter to go from 10-0 pressure is if the pump loses prime ie: air infiltration. Hope that helps.. Rob
Apr 22, 2010 | Hayward EC50C Perflex Filter w/ 1.5HP Pump...
Pool vaccuum
are you filling the vacuum line with water before hooking it to the skimmer?
Jul 21, 2009 | Intex Krystal Clear Model 635 Pool Filter...
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Lost vacuum at defrost & vent & floor control.
It does not hook to throttle body , it hooks to a vacumn port on the intake manifold. Follow hose from cruise control module to the tee-three-way connector on firewall. Over time the tee will fall apart and will leak One hose goes to the vacumn port, one to cruise module,one to ac contols.
Jun 27, 2009 | 1994 Buick Skylark
Pool & Spa Logo
719 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
