Question about Goodman CLJ36AR42 Air Conditioner
I have a PGB036100-1A. The inside fan runs but the unit does not cool the house. It seems like it trys to come but it cuts off. I have a goodman unit.
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: AC Fan outside running slow
The brown wire goes to the capacitor. It probably shorted out with the nicked wire. Replace the capacitor.
Posted on Jun 29, 2009
atocrxr
  • 135 Answers
SOURCE: goodman ck36-1a not turning on
ok, you have turned the thermostat to the cooling setting? and turned the temp setting down, so the blower comes on.
As far as the outdoor unit, first thing to do is check the breaker in the electrical panel, next check the disconnect box, that should be located on the wall near the outdoor unit.
It will have a breaker or a set of fuses, that need to be checked, if it has fuses, they have to be tested with a ohm meter, and you cannot tell anything about their condition buy looking at them.
Good Luck.
Sincerely,
Paul Gibson
Posted on Apr 08, 2010
  • 16 Answers
SOURCE: goodman cpl-j42-1a a/c unit, fan on outside unit
sounds like you have a bad fan motor in outdoor unit or a bad run capacitor ck cap first you can go 1 size larger than listed on motor data plate
Posted on Jun 11, 2010
kingbrizzle
  • 407 Answers
SOURCE: Goodman cpl-j42-1a outside unit fan will not run i
The fan motor on the condenser not working can be a easy fix or the motor itself could be bad. One important thing is, if your condenser fan isn't coming on, but the compressor inside is running, you could cause a lot more damage and may have to replace the compressor also, which could get expensive! I will try to go through a few things to see if any fit your problem.
(WARNING) Before working on any part of the electrical system, or even opening the compartment, please disconnect all power to the unit!
1. Fan motor not running, but compressor IS coming on-
Bad Capacitor- Its a small round or oval part that is inside the electrical compartment on the outside condensing unit. You will have to have a multimeter that reads MFDs to check it. If you do have a meter, take off the connections that or on the Herm terminal, (if you have a capacitor with just two terminals, make sure you disconnect one side), set your meter to Mfds and touch your leads to both terminals. Remember the reading it gives you and compare it to the Mfd rating on the side of the capacitor. It should read something like 15mfds/5% 370v, they vary in sizes, but make sure that your capacitor is running close to what it's rated at, if not, then it needs to be replaced. This is a common reason the fan motor stops working when everything else is still working.
Bad Motor- This can be a little more complicated sometimes since a motor can go bad and not show normal indications. The first way you want to check is to try and turn the blades on the fan motor. It should turn freely with no problem, if it doesn't, it needs to be replaced. You can also check for continuity in the motor with a multimeter, but as I said before, sometimes it can show that its okay, but still have a problem. Sometimes when your fan motor burns up, it makes a loud humming sound when it tries to kick on.
2. Fan motor not coming on, compressor also NOT coming on-
Fuses on disconnect switch- There will be two fuses on most disconnect switches that are inside the disconnect on the outside of the house, usually right by the unit. (Some condensers do not have a disconnect at all, see BREAKER BOX) To check the fuses, you will need a multimeter that has a ohm setting, they should have continuity through them. Some fuses have a small window that you can see if they are blown or not. If so, replace fuses with the same size that was pulled out.
Breaker Box- Simply enough, sometimes your condenser will trip the breaker in the breaker box. Make sure all your breakers are switch to the on position. Sometimes this is all it takes and other times it can mean that there is a more serious problem. (If you reset the breaker and it automatically trips again, there is a short and needs to be left off)
Compressors internal overload switch- If the compressor is running when the fan motor is not, it will eventually over heat which will trip the internal overload switch and shut the compressor off until it cools back down. The best way to check this is to feel the compressor itself and see if its extremely hot. ( An over-heated compressor can cause burns!) The other way to check it would be with a multimeter with a ohm setting to check for continuity within the compressor. You must follow the wires from the compressor to find the terminals where they are connected. Take the connections off and place your leads on the wires, you should have continuity through all three wires.
Of course there are a few more technical things you can use to trouble-shoot, but these are some of the more common problems and answers. Things like the capacitor and fan motor can be pick up by yourself from a local supply store that carries A/C supplies. The compressor has to be bought from a licensed contractor. The capacitor is basic, but the fan motor will need a fan blade puller in order to replace. Hope this helps or at least points you in the right direction. Good Luck!
Posted on Jul 17, 2010
Just cut on 8 year old Goodman CPLE24-1 AC for the summer. Ran 8 hours fine, Next morning noticed outside unit running, very little cool air blowing out of inside floor vents (like the blower fan was...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Apr 12, 2011 | Goodman CPLE24-1 Air Conditioner
We installed a new TCJD36 (3 TON) unit with new A coil. The unit works fine from morning until 4:30 PM. from 4:30 PM to 9:00 PM the compressor does not come on. Inside fan goes on and outside unit fan...
This really sounds like the unit is over heating the compressor to the point of triping the internal high limit switch and just taking that long to cool off before it resets. If it continues to do this go outside and run your water hose over the compressor for at least 30 minutes to cool the compressor down and see if it starts for you then. If so then your unit could be over charged and creating very high head pressures!
Aug 11, 2010 | Goodman CLQ36AR49 Air Conditioner
A/C fan is running but no cool air
Make sure the outside unit is running. If it is then you may need to get the unit charged.
May 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
Heat pump not cooling
You may have a bad running capacitor on the outdoor unit. It is a round or oval can with three sets of prongs on it. Over time they can either become weak or swell due to an overload.
Aug 10, 2009 | Heating & Cooling
Goodman a/c blower runs on auto and humidity problems
Is the air cold inside? You are talking about the fan inside? Have system check for freon but more than likely, it sounds like a t'stat problem. And it's not normal for the fan to run constantly.
Jul 05, 2009 | Goodman CLQ36AR49 Air Conditioner
Jun 29, 2009 | Goodman CKL36AR36 Air Conditioner
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman CLJ36AR42 Air Conditioner Logo
144 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
