Question about Kenmore 77713 Stainless Steel Side by Side Bottom Freezer Refrigerator
Can't change our settings on our Kenmore Elite 7579 refrigerator
We've gone through the manual -- nothing works. We push and hold the button, but no response. The unit has power, but doesn't get cold. Over the freezer control button, there is a "0." Over the refrigerator control button it says "FF." There is absolutely nothing in the manual that says what these mean nor how to change any settings other than "press and hold the button" which we've done, but nothing works. There are literally no other buttons or switches to press.
  • Robert DeStevens
    Robert DeStevens Jul 04, 2010
    Can you post the model number of this fridge (inside the fridge on a sticker on side wall) the stock number 77713 is no longer current at sears. Your display is telling you the fridge is "off" if I can get the spec sheet via the model number I may be able to help you.
  • kimlesure Jul 04, 2010
    I can't help, but we just got a new fridge too, and we are having the same problem. Our model # is 795.79753.900. I found a manual to similar Kenmore online, but not this exact one.
    Not trying to hijack the original posters thread, but I thought I could help him and myself at the same time.
    Thanks!
SOURCE: I have a Kenmore Elite Trio Refrigerator. The
I have the same problem what is the solution
Posted on Dec 22, 2009
rylee_smith
  • 8619 Answers
SOURCE: what does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite model # 795.77564600
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite error message er ff
Posted on Sep 25, 2010
ginko
  • 19396 Answers
SOURCE: what er ff mean at
Hi.
Error ff (er ff) means defective fan detected. Before calling support or before replacing the fan try performing a complete defrost by leaving power disconnected for one day (remove food from inside the unit first). That will fix the problem if the fan was temporarily malfunctioning because of ice formation. If that does not work the fan must be tested before replacement.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Posted on Sep 09, 2011
Reset Change Air Filter Light
TRY TO UNPLUG IT FOR ABOUT 10 MINUTES AND RETRY WHILE HOLDING THE BUTTON.
Jun 18, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hi, Please tell me how to change the temperature on my elite kenmore.
Klay421 --
Which model Kenmore Elite refrigerator do you have? If you have one of the older manual models, the thermostat is located inside the fridge side. If you have a newer model with digital controls you need to press and hold the the ON/OFF button for 2 seconds until the digital displays for temperature for the Freezer and Refrigerator lights. The Up/Down arrows allows you to adjust the temperature. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Kenmore Refrigerators
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Just bought a kenmore elite bottom freezer trio model and display panel shows o ff. Expect this means whole unit is off but manual does not say how to turn ON in the setting the controls section of manual....
I just purchased a similar model and had the same frustration. Finally called the store and it was in DEMO mode. Open the freezer draw and hold down the Ultra Ice & Refrigerator Temp buttons simultaneously for 5 seconds. That worked for me and hope it will do the trick for you.
Jul 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Kenmore elite trio 596.76539500 control panel says OFF.
On a Kenmore Trio 78729 made by LG, open left door and push the Ultra Ice and Refrigerator button simultaneously for 5 seconds. The display will change from 0 OFF to temperature settings.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Mod #76523
The problem is the fan unit that pushes cold air up to the fridg, usually located nere the back of the freezer.
Aug 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dryer stops
your motor switch is gone you can either change the switch or motor you could try tapping the switch sometimes it will free the contact this switch is on the motor
Dec 09, 2007 | Kenmore 659 Electric Dryer
Open Questions:
See all Kenmore 77713 Stainless Steel Side by Side Bottom Questions
Kenmore 77713 Stainless Steel Side by Side Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
